Hello! The most popular flashlight the Wizard. At the moment we have four models of the Wizard and now we compare it. All flashlight have sphere of usege, for example: fishing, hunting, camping, car repairs, and other. Here are the brief description of the lights.
P. s. there is a hidden promo code( with 30% discount on the all product) in the text.
ARMYTEK WIZARD MAGNET USB
Brightness up to 1000 OTF Lm.
Beam distance up to 119 m.
Up to 100 days of light with one power source.
ARMYTEK WIZARD PRO MAGNET USB
Brightness up to 1800 OTF Lm.
Beam distance up to 130 m.
Up to 200 days of light with one power source.
ARMYTEK WIZARD PRO MAGNET USB NICHIA LED
Brightness up to 1400 OTF Lm.
Beam distance up to 97 m.
ARMYTEK WIZARD WR MAGNET USB
4 LEDs: amazing beam of red light up to 250 OTF lumens and white light up to 1000 OTF lumens thanks to 2 LEDs for each color.
5 brightness modes for each color, easy operation with one button and double click for switching between white and red light.
Beam distance up to 97 m for white light and 41 m for red light, up to 15 days of light with one power source.
Hello! We know that you like Quiz. You should to answer the questions. If you right to answer, we give you promocode with discount.
The first person to answer the question correctly will receive a promo code in message.
P.s. promo codes are valid until March 1
Questions:
What the flashlight: he has beam distance up to 15 m and 5 years no-hassle warranty? (discount 5%)
How many motes the flashlight Elf has? (discount 10%)
Which depth can the Prime lights be submerged? (discount 15%)
Which battery we use with the tactical flashlight Viking Pro? (discount 15%)
How many lm Tiara C1 Pro magnet USB flashlight has? (discount 15%)
What Doberman Green flashlight weight without a battery is? (discount 20%)
What is the hotspot:spill of the light in headlamps? (discount 25%)
What is included in complete set of Barracuda flashlight? (discount 30%)
What is the length of the flashlight Partner C4 Pro? (discount 35%)
The Candela Peak Light of the Wizard Nichia?(discount 40%)
*Please keep in mind that promotions and promocodes can not be applied together.
For any help or assistance feel free to contact us.
Anyone interested in Armytek flashlights. I posted output and tint measurements for the entire collection of Armytek flashlights with warm white emitters.
Miniature, multifunctional and powerful Zippy Extended Set is available for pre-order! Zippy Extended Set is a 3 in 1multi-flashlights with unique capabilities. 4 times brighter than analogs, incredibly durable and Micro USB rechargeable. Zippy Extended Set with headmount with magnet for both wearing on head and fixating on metal surfaces, steel clip for clothes and plastic clip on cap is perfect for daily situations, services and camping.
• 4 times brighter than analogs: 160 lumens of light, wide beam angle of 110°
• Thin and lightweight body (9 mm and 12 g) protected against mechanical damage by stiffening ribs
• Micro USB rechargeable built-in Li-Pol battery
• Indication of battery charge level and charging process
• Dust- and waterproof (IP67 standard): withstands submersion to 1 meter for 30 minutes
• Unique fully glowing body and 4 stylish colors to choose from
• 5-year no hassle warranty
Let’s put the superstition back!
This Friday the 13th you are lucky!
Only one day, the most mystical and superstitious day of the year, you can buy any product in our online store with a discount of –30%!
Repeat…DISCOUNT ON EVERYTHING!
Thin, lightweight and stylish Armytek Zippy is now 3 in 1. Multi-flashlight Zippy Extended Set, which has no equivalents, is suitable for daily use, services or camping. Durable steel ring allows to carry the flashlight with keys. Removable stainless steel clip is securely attached to clothing or belt. Rotatable 360° headmount with magnet and plastic clip for cap make it possible to use the flashlight as a headlamp. Strong magnet in the mount securely holds the flashlight on metal surfaces. Built-in Li-Pol battery is easily charged with Micro USB cable.
–160 lumens of light, wide beam angle of 110°.
-Beam distance up to 15 m.
-Indication of battery charge level and charging process.
-IP67 standard: highly reliable protection from dust and submersion to 1 meter for 30 minutes.
-Unique fully glowing body and 4 colors to choose from.
-Possibility to charge the device with Micro USB cable and built-in Li-Pol 100 mAh battery.
–5 years no-hassle warranty.
“Sorry, it seems that we have no shipping options available for your location.
Please check your shipping address and contact us if everything is okay. We’ll see what we can do about it.”
Nico- You will get that message on backordered and out of stock items, found out by troubleshooting what was in my cart lol.
Armytek- Just received my wizard WR, so far super impressed! Not clear in the manual but when strobe is on that removes firefly move correct, so turning it strobe off would turn on firefly? When is the warm version going to be on the store for order?
