DBSAR
(DBSAR)
February 27, 2020, 10:27pm
10765
Both of those actually, but i use the Eceen 10 watt mostly for charging the LT1 during the day. (been using that model & testing it for nearly a month, and its able to charge the LT1 every day to full charge, even on a partly cloudy day. I have 2 Eceen 10 watt units, and other models as well i use & tested.
DBSAR
(DBSAR)
February 27, 2020, 10:29pm
10766
As long as they are a good quality model that can supply an actual 10 watts of power or higher like the Eceen 10-watt, or any higher wattage models are usually good. (research & reviews usually helps.
alternety
(alternety)
February 28, 2020, 3:58am
10767
This could be useful to those looking at the interface for USB-C. It is about the Pie fixes to the new interface.
JoeRodge
(JoeRodge)
February 29, 2020, 5:38am
10768
Quick Question, I tried searching but didn’t find exactly what I was looking to find. Can you use Samsung 35E NON button top? Do I have to use a button top cell? I’m not trying to add magnets or solder, etc.
MNLegoBoy
(MNLegoBoy)
February 29, 2020, 5:41am
10769
JoeRodge:
It has to be a button top, or a flat top with positive terminal above the wrapping
JoeRodge
(JoeRodge)
February 29, 2020, 5:42am
10770
So a VTC6 would work? I can’t think of anything else that is protruding. Maybe a Sanyo 3500?
MNLegoBoy
(MNLegoBoy)
February 29, 2020, 5:47am
10771
I have no clue, I remember there were one or two dollar told that would work, as they have the terminal slightly above the wrapping
JoeRodge:
Sanyo NCR18650GA’s work. Do not know what other flat top might fit. But do not let a muggle insert a battery upside down, the LT1 Does not have reverse polarity protection.
Dekzter
(Dekzter)
March 3, 2020, 8:27pm
10775
So I know I’m late to the party but are there any deals still available for this light?
MNLegoBoy
(MNLegoBoy)
March 3, 2020, 8:36pm
10776
AliExpress will probably have some deals, there might be a coupon for sofirnlight.com
JoeRodge
(JoeRodge)
10777
Sofirn told me it will be back in stock at the end of April.
MNLegoBoy
(MNLegoBoy)
March 3, 2020, 8:37pm
10778
I’m finally getting mine today, almost 100 days later
Dekzter
(Dekzter)
March 3, 2020, 8:48pm
10779
Just ordered it from AliExpress for pretty much the exact same price as the GroupBuy. Thanks!
MNLegoBoy
(MNLegoBoy)
March 3, 2020, 9:55pm
10780
Glad you got one, hopefully your doesn’t get lost
alternety
(alternety)
March 4, 2020, 1:20am
10781
Is there any information on a version that has a proper USB C interface?
Or (even better) an advanced version that includes the full USB C plus additional goodies/accessories.
I have waited for years for the product (was around #150 ). Still looking for a version without issues. I want three identical devices.
MNLegoBoy
(MNLegoBoy)
March 4, 2020, 1:17pm
10782
alternety:
If I remember somebody modded theirs to a proper USB c port, by adding 5.1k resistors to certain pins. There is a deluxe version planned with a full size USB port out
whopist
(whopist)
March 4, 2020, 2:09pm
10783
That is great news!
I thought mine was the last hold out.
JoeRodge
(JoeRodge)
March 4, 2020, 11:04pm
10784
alternety:
What are the issues? Is it because you can’t USB c to c? Is that even an issue?
Not trying to come off rude I’m genuinely curious.
