Quick Question, I tried searching but didn’t find exactly what I was looking to find. Can you use Samsung 35E NON button top? Do I have to use a button top cell? I’m not trying to add magnets or solder, etc.
Sanyo NCR18650GA’s work. Do not know what other flat top might fit. But do not let a muggle insert a battery upside down, the LT1 Does not have reverse polarity protection.
If I remember somebody modded theirs to a proper USB c port, by adding 5.1k resistors to certain pins. There is a deluxe version planned with a full size USB port out
I enjoy candle mode, especially with the ‘orange silicone dog bowl’ shade(thanx for the link goshdogit) I did a runtime test in low candle mode starting with 30Qs@ 4.2v. After 21days - 24/7(total of 504 hours) the onboard voltage reported 3.4v.
I was amazed the LT1 only used .8 of a volt in 21days……… it took 4.5 hours to recharge back to 4.2……
Yes, I would really really like to have some of these lamps. Years have past since I first accepted these lamps. Multiple instances of lighting problems have passed into oblivion.
Yes, I could solder parts. But I will not. I will not accept multiple versions of a product lacking real detail from the vendor or attempts to solder. I used to do that sort of thing. I am old and I will not screw around with this lamp. If, as currently delivered, I just will not buy one until after all the screwing around. That is not what I wanted decrepit om the developers. Years have passed. I can (and have) respected the massive private work making these lanterns. And I have accepted the process. I have done this sort of development at levels way beyond the scope of this project. I got it.
It must work without a soldering iron.
Releases of manufacturing versions must be clearly defined with clear release version features.
