They are indeed!
The ones I like the most are the 4000K Luxeon and the 3000K Luxeon V2. Actually I am thinking about getting a triple of 3000K of these
It is a very pleasant beam and tint! I guess Luxeons will be, after all, my favourite Leds
Osram CSLPM1.TG (aka white flat 2) is now available in higher 6P flux bin, that should be about 10% brightness increase compared to 5P (according to datasheet and previous measurements - about 1800lm @ 7.5Amp):
https://led4power.com/?s=cslpm1&post_type=product
16mm DTP boards are out of stock, new batch of gen2 boards are expected by the end of March ( about 1.5 month later than planned because of virus thing).
Neven what about CULNM1.TG restocking?
Where can i find gaskets for the 4040 CULNM1.TG ?
I'm not sure about CULNM1.TG restocking, I will try to source some.
There are no gaskets currently available for 4040.
And ask for the culpm1 as well?
I'll try.
When will the Luxeon V 4000K be in stock again?
Luxeon V 4000K is in stock again, CAT code is V13F (same Vf bin as 5700K so they can be mixed), mixing 4000K+5700K is added as option for all 4x and 6x boards:
https://led4power.com/product-category/leds1/lumiledsluxeon/luxeon-v/
Perfect, thank you.
I plan to have new 16 and 20mm DTP boards in 3030,3535 and 4040 footprint format,and possibly 3x,4x 20mm 3030,I’m not sure about the rest, demand is too low.
Neven,
I hope you are doing well. Any update on the 3030 4x 20mm boards?
Due to current situation, those boards will not be available for some time, 16mm 3030 DTP are back in stock, next are 3030,3535,4040 20mm Cu DTPs and 3535,4040 16mm Cu DTPs.
Thanks for the update Neven.
Are there any plans for 20mm triple 3030 MCPCB?
Same answer as in post 1291.
Will you be selling SBT90.2?
Depends on interest, but it's an expensive LED, additional problem is custom DTP PCBs have to be made and those have large min. order quantity, so I'm not sure it's feasible.
If you would just sell the bare led, people could buy the 20mm DTP SST-90 board from kaidomain. But I know that your policy is to always offer the option of the led reflowed on a board.
IIRC it’s law rather than policy, something about not being allowed to be a reseller.
Edit: Yes, explained in post #1233
Thanks, I read that too and forgot about it.
I’m amazed i remembered.
Going back to your point though it doesn’t have to be an MCPCB that’s sold with the LED, it could be sold with just a gasket, or something else for minimal cost. Wire, even.
