I have a pair of them, the other has a KW CULNM1-TG (BoostHL) and I measured it at 125kcd, so somewhat over 100kcd for the Black Flat sounds in line with that.
Does the hotspot in this beamshot from about 6-8ft look normal? The hotspot corona looks lopsided and fuzzier(?) than I expect, but it’s my first super thrower. Maybe it’s normal?
That beamshot looks good to me, even better than mine actually - better centered. Mine has a similar non-circular corona (not sure if corona is the right name...).
I’ve adjusted the reflector position on other lights if it had shifted during shipments. But you have to be careful not to be exchanging a tiny bit of adjustment for some dust or a smudged reflector or lens.
Maybe a tiny bit off centered (possibly a tiny bit of slop in the centering ring or cantered) usually when tightening the bezel, the reflector will move or canter the reflector a bit, due to the friction/torque of the bezel. You could try smacking it in your hand to get the reflector to move over a bit to equal out the corona, or loosen the bezel, let the reflector self center, press and hold down onto the glass lens and snug the bezel gently and see if that helps?
Usually I’ve found that fine-tuning a thrower ends up being largely a matter of loosening the bezel slightly, maybe slapping the light around a bit, and tightening the bezel. The focus typically changes slightly while turning the bezel, so the last bit of tuning involves knowing when to stop turning.
If the focus is close enough that this sort of thing matters, though… that means it’s already focused pretty well.
IIRC, my K1 had a slightly imbalanced corona, but I simply twisted the bezel a little and it changed to a nearly perfect circle.
The D1S was in a class of its own when it came out in terms of being as compact as possible while keeping the 50mm head size. Then the lumintop GT mini came out with very similar dimensions.
I might like to see the updated D1S keep the 50mm head but be made for 21700 cell. This would make it unique again and give it a power/runtime boost.
