One of loneocean’s projects was pointed out to me yesterday, but not that one. Glad to see he focused on efficiency. I had done some reading and was confused to see how prevalent linear regulators were in high-power drivers, since that’s just about the worst option for efficiency and made no sense for items where I assumed minimizing heat and maximizing runtime would be desirable.
If my little pocket lights do well, I may look into larger and possibly multi-cell units, but one favorite part of my job is working on what I want to work on. I don’t need to squeeze 5A out of a single 18650, and I don’t need 800 brightness modes, and I don’t particularly care to leverage someone else’s fancy-feature interfacing, so that’ll take a very back burner to just making something that runs a long time and doesn’t break. My design philosophy is Simple, Durable, Reliable. Y’all enthusiasts probably have different priorities than us normies.
PWM on small currents has the advantage that the tint does not get ugly with low currents, most LEDs suffer from it
Also a true DC moonlight current ages the LEDs quite significant compared to higher currents, you can read up the physics,
many manufacturers write in their projector lamp LED line up (like CFT90 500mA) a minimal current to stay within lifespanof the LED
Also in PWM-ed CC on very low currents you can achieve a lower output brightness with better efficiency and stability staying out of the DC voltage drift of the OPAmp
Right, I understand the issue of color drift with low-current low brightness. One of the first buck drivers I looked at to build around was fairly robust for efficiency and PWM modes but it’s hard to find anything designed to work below 4.5V
I did not know about increased wear on the LED during low current use. Seems counterintuitive given the assumption of heat as a primary failure mode, but as you say, can’t beat physics. I have only prototyped a low-current build of my driver (waiting on the PCBs for a full-current test) but the driver, since it’s optimized for higher currents, gets a bit twitchy at low currents. Since voltage regulation is independent of the LED’s current path, a more complex driver could integrate a FET for PWM and use something like occasional mid-pulse measurements (possibly with pulse stretching if necessary) to maintain stable voltage such that on-time current remains constant over time.
But to do that on a 17mm driver while keeping low resistances for efficiency would probably require moving some things to the PCB underside. Right now it’s all a single-sided board, 2-layer, all passives 0603 and up so pretty easy to assemble with the equipment I have. My robots are supposed to handle 0402 but parts that small are hard for humans to work with so setup, testing and rework would suck.
One of my guys specifically wants a low-brightness (~25-50lm) version for using around the house at night, so I figured on tweaking parameters a bit for lower currents and using a different LED (max 240mA) that I already have a whole reel of.
I do hand assemble small components like 0402 on all my driver sales,
the key are very nice tweezers (the BT-15) and a very bright work light and rest your wrist on the working surface
My last 17mm design contains only 0402 passives plus nice big power parts
I would always go double-sided on 17mm it gives you enough room to place a nice big inductor on it,
I have seen drivers pushing 25W through a 4x4mm inductor but you simply lose efficiency
And room for some nice 1206 input/output capacitors size matters here a lot
at DC currents of 2.5A you can get along with a SOT 323-3 MOSFET
A sort of low moonlight 1mA or less is very desirable
Time is probably more of a factor for me, since I have to pay people to work, so I prefer 0603 parts. I hand-assembled hundreds of boards for a couple years before I could afford a robot.
I’m using a 5x5mm inductor, DCR 29mOhm.
Once I have something working I’ll look at a more complex setup with two-sided boards, if it’s necessary. As designed it’ll do everything I want it to do, and then some. The only concern would be how it handles low brightness.
Yes very low output is a thing that is on 17mm a challenge, often you are MCU limited with only 8Bit output so minimum is 1/255 while the buck or boost chip can handle 1:5000 dimming
Or you can’t use a nice buck chip without a small charge pump to supply it 5V operating voltage, there are for example Buck/boost chips that have sort of small caps on both sides of the inductor to supply it internally with a higher voltage than the battery can deliver to drive the switching MOSFETs to get low internal resistance
I have not posted it yet but I am about as far as with the 17mm buck with a 17mm Buck/Boost that can deliver in buck mode up to 4A and boost 2.5A
I considered a charge-pump to get above 4.5V but the good compact drivers didn’t separate power-in from control-in.
The microcontroller on my test board uses a 10-bit ADC to measure current and a 10-bit PWM to set output voltage. The compact PIC I’ll be using has a 16-bit PWM but I haven’t determined yet its speed versus resolution so I’m not sure how granular it’ll be on the final product, but even 10 bits is 0.1%
Nice, TPS63020. That’s the same part I was looking at for a potential buck/boost driver.
Hi, this sounds like an interesting project. I’m happy to hear the plan includes making the source code public.
People can be very picky about user interfaces. As you said, UI issues are much of what prompted this project… and different people like very different interfaces. So if possible, I’d suggest trying to make sure the driver has code available and can be reflashed pretty easily.
That concern may be a bit lower-priority for this though, if the goal is to make a tactical-style light with just one or two modes on a rear clicky switch, with a minimum of 25 to 50 lumens. There doesn’t seem to be a lot of overlap between the tactical crowd and the fancy firmware crowd.
It would probably be a good idea to include low-voltage protection though, and possibly thermal regulation too. Zoomies and P60 hosts like the WF-501B don’t have very good thermal dissipation, so 2.5A sustained could cause damage.
The microcontroller I’m planning to use does have an internal temperature indicator. It’s not terribly well calibrated so would be best as a threshold monitor rather than a continuous-range thermometer. Provision for ramping down power or even a full disable above a certain temperature would not be difficult. A more complex driver could utilize an external sensor on an I2C bus but that would require a micro with more IO.
For my own use, I’ll probably stick to single-mode or, at best, a two-mode with low and high. My code commenting is thorough so adding or editing brightness modes as a third party should be fairly simple. I’ll probably code in a strobe mode as an example but won’t use it past testing. Implementations with single-mode, multi-mode brightness and multi-mode including strobe modes will be available for customization.
When you say “tactical-style”, what exactly does that entail? I’m really just looking for a particular size that’s handy to put in a pocket. I don’t like all the modes and I don’t like all the jagged protrusions things specifically advertised as “tactical” seem to require. If I did go in on a batch of something like the 501b bodies I’d see about custom-maching the bezel to get rid of pocket-snaggers.
I’m finding it difficult to locate a zoomie light body with a smooth bezel also. The one I have to test with has an aluminum pill that threads into place so it should be better than the P60 at transferring heat to the body. That insert in the 501b has me worried about its ability to clear heat. But I won’t be able to do burn-in tests until my PCBs are in hand. Just found out they’re completed but haven’t shipped yet.
Regarding fancy firmware: feature creep is not my friend.
Right, there’s more than one definition of “tactical”… but I’m not talking about “tacticool” with sharp edges everywhere designed to hurt people. I just mean something with a mechanical tail button for overhand or cigar grip, and a very simple UI. Usually these have forward clickies (tap while off for momentary use) instead of reverse clickies (tap while on to change modes), but not always. Usually they have one mode, or a small number of modes without memory, with high first.
The entire category of P60 lights is a popular type of tactical lights. They were originally designed to protect incandescent bulbs from shock and insulate the user from its heat, while also making it easy to swap out the light engine. With LEDs though, the P60 design has become far less popular and many people migrated to smaller designs with integrated pills for faster thermal transfer.
As for what is popular these days… er, Zak and /r/flashlight maintain a nice list of popular lights.
If SolarForce was still around, I’d suggest looking there for P60 hosts. They made some of the best, and for pretty decent prices… but they closed and I’m not sure if anyone is making quality P60 hosts any more. It seems like most of that market moved to tube lights like the Convoy S2+.
About zoomies, the best one I’ve used is a Jax Z1. It may be a bit large though, and zoomies in general are typically somewhat specialized instead of general-purpose. I mostly use mine to scare away noisy owls without disturbing the neighbors.
If I’m looking at the right thing, that Z1 is definitely without sharp edges, but my pocket won’t accomodate a two-inch bezel. The lights I have to play with are in the 25-30mm neighborhood which is pretty comfortable so I’d like to stay in that size range.
It’s probably pretty crappy by y’alls standards but back around 2012 I picked up a couple of single-mode lights in some branding or other (I believe Small Sun ZY-C84) of this body. One was stolen and the other burned out but I still have the body and it was about the only thing I found that fit all my criteria for size, general appearance, function and non-stabbyness.
I wouldn’t mind being able to offer a fixed reflector option as well in a similar form-factor. P60 body is just what I have on hand to mess with (and also what I know I can acquire in bulk) but isn’t a design requirement. I lack the machining infrastructure to make my own at present, but maybe someday.
I would guess, based on your linked list of popular lights, that 18650 “Duty lights” would be most likely the category I’d try to work in. “Simple operation” and “reliability” are two of my favorite things to design for. My best friend is a first responder, daughter of a cop and an ambulance driver, and she’s already asking about getting some lights for volunteer firemen and as door prizes at fundraisers. I would enjoy being able to offer customizable packages for her people.
Also got word my prototype PCBs should arrive on Monday so I’ll get to start testing next week. Still need to adjust my code for the different microcontroller but that shouldn’t take long.
Couple sample bodies arrived from the factory yesterday so hopefully soon I’ll get a board populated. It’ll take a few hours to update the program for the right microcontroller but hopefully next week I have something working.
Not sure how I didn’t notice when tracking down parts, but the micro I had in spades in 8-SOIC and have been programming with for years is also available in the tiny QFN package so I’ll just be getting that one instead and not have to adjust the program. There’s a lot of benefits to coding in assembler but the main drawback is lack of portability. Should have some results next week.
My regular work has been slowing down, and I know I’m new to the community and have zero reputation but I’m considering looking at design work and bidding small-batch jobs. I get PCBs from a US factory and have pick-and-place and reflow equipment with my assembly business, so I can bid small manufacturing runs of outside designs if anyone’s interested.
The emitter that are usually paired with these drivers are the Cree XHP70.2 because it is very efficient and very high output in 1 single emitter package.
The Convoy M3 is an example. The Convoy M3 does not have very good thermals.
The convoy M3 uses a 30mm diameter driver board. However if you could make a 20mm board which the Convoy L2 host uses, it would be exceptional host because the entire head is a solid pill for the emitter.
If you are designing an economic driver for mass production, probably 5A is a good balance. But if you are looking for something special, 8A+ would have a unique demand.
XHP70.2 is what I’m looking at for the project, so that’s just about right. I’m still working with 17mm but if it’ll fit in 17 it’ll fit in 20. I’ll start with what I’m looking at for a 4-5A boost (with thermal-limit ramping) and if it works well I can start digging up a design for a bigger one. If I want to.
Looking at a 6A high-efficient buck driver also. Nothing exotic so not terribly expensive.
I’ve been told I should look into a FET tailswitch for Convoy builds too, which will definitely help with efficiency for those high draws. Guess I should buy some Convoy lights so I know what everyone’s talking about.
