Unno, never saw it done in cheap LED bulbs. Maybe that Bedtime Bulb in another threadā¦
Yeh.
And thatās back to the same problem. LED bulbs are like LED Christmas lights, ie, no filtering, just nasty pulsed 120Hz (or worse, 60Hz) lighting.
Yeh.
Fwiw, I got (won) a set of these Amazon.com which I quite like.
But theyāre also pulsed AC vs filtered DC.
You could spend more on a stinky little 10ĀµF filtering cap than for a half-dozen LEDs.
I used to have half a dozen of those. Eventually they all got spotty and faded and became useless. I dunno why.
Hang on. I need another remedial moment.
Most of my LED experience is with flashlights. There, I really hate noticeable PWM. Iāve literally tried two kinds of LED light bulb. One had a soul-crushing flicker on par with the worst PWM. The other seemed okay but I moved out a few days after I installed it. Will all LED light bulbs flicker with the alternating current? If so, whatās the fix?
Unless a LED bulb is advertised as being āflicker-freeā, assume itās got a nasty 120Hz flicker of about a 5% or less duty-cycle.
No fix. Might not run on DC, canāt really crack one open to add diodes/caps/etc.
I did an extensive search in 2015 and settled on this gem:
https://www.amazon.com/gp/product/B002VF9POY/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
It has a dusk-dawn sensor AND a motion sensor. So the bathroom is dark unless someone walks in. You then have 60 seconds to sit still before it will shut back off. It is flicker-free and 2700K too. Oh, and they cost me $8 each
5 years old and still loved
Maybe Iāll get the joke when I am older. Right now I look at it and wonder why heās waiting for something to happen
Heās sitting on the bowl, motionless. Motion-sensing light turns off after a while, and heās gotta wave around to light it up again. (Sometimes you just got time to kill.)
I worked in a place where my office had one of those. I was shielded from the sensor by the monitor, and yeah, unless Iād remember to āwaveā every 5min or so, itād shut the lights off on me.
But how could a poop possibly take longer than 20 seconds?
Reading, crossword puzzles, etc. By the time youāre finished, itās time for round 2.
I guess bathrooms bore the crap out of me in record time
Young peopleā¦
I picked up one of these from Walmart awhile back: https://www.amazon.com/GE-38628-Designer-Farmhouse-Entryway/dp/B07C57YLPR
2200K. Equivalent to the old 7 watt incandescent night lights in brightness and color temperature. For a nightlight, itās very bright. No idea which emitter theyāre using.
Iām interested in any suggestions for a battery powered night light or <1 lumen as we donāt have power plugs in the right places. I used to use a Nitecore NU30 headlamp which lasted about 3 weeks on <1 lumen (about double the runtime specification), but the battery died after 3 years.
Need to be off-the-rack?
Preferably, yes!
These are really good. And if you catch their 2-for-1 or 40 percent off deal, which comes around fairly often, theyāre reasonably priced.
https://www.mrbeams.com/mr-beams-amber-stand-anywhere-light-mb750a
Not sure if anyone wanted one of these but
I had one of these as a gift and it comes in a very nice warm 3000k light. Rechargeable and has auto turn off for 3-5 minutes of light on. Found many cheaper alternatives if you hunt in the right spots in amazon.
It uses a 14mm star in my unit which I could always swap to something nicer but the stock LED is good enough for me
Just hunt for Faucet Tap Drippy Night Light Voice Activated
Usually the voice activated are usb rechargeable and the non voice activated are 3x AAA battery types.
Thanks, Iāll check it out.
