Sorry for the silly question. I thought LED with high CRI is a great feature. Are those blue/green gaskets designed to do the opposite of high CRI by adding blue/green tint?
The light out the front doesn’t shine through the gasket so effect on tint is minimal if any I believe.
But say you have the light on full power then change to ML, you’ll have more tinted colour output than white light for a while.
the glow from the gasket, when the light is off, makes it easy to find the light on my nightstand.
the glow has very little actual illumination distance… I do not feel it changes the CRI of the LED
I especially love my acqua blue color gaskets from CRX! Highly entertaining
I can see the dim glow on my nightstand, in full darkness, even without precharging the glow gasket. Ambient daylight is sufficient to charge the gasket enough to be visible by the bed, in the dark.
Thanks gentlemen, I didn’t know about glow gasket and misunderstood its purpose. I though it was a kind of filter to alter the light tint
Is the glow permanent? does the glow gasket get power from the battery? Is this a similar design than some tail click button that has a led that glows weakly when the light is turned off? Sorry I saw a post somewhere for this design but don’t remember which flashlight model.
Nope, its just molded polymer that had glow-in-the-dark powder mixed in. Like watch lume or little GITD toys.
There are powered “aux LEDs” that can be a single or many different colors depending on their design. The newer Emisar and Fireflies lights have these, and Lexel (maybe others too) here sells boards so you can add them to other lights like the FW3A.
the glow is charged by turning on the flashlight, but the glow is not battery powered
the highest brightness immediately after charging fades quickly (less than 1 minute)
but the residual dim glow remains sufficient to locate the light in the dark.
Even if I do not use the flashlight to charge the glow before bedtime, ambient light during the day, (iow leaving the light sitting on the nightstand 24/7) is enough to make the glow retain sufficient brightness to locate the light in the dark.
Just got my aqua gasket and tail cap from CRX. Fast delivery even amidst covid issue! Great quality. Great care and detail in packaging. Love it. Highly recommend CRX! Thanks CRX!
