Cool, I like it! :+1:
I traded the fw3d I modded for this fw3a. I didn’t know it could pulse till I tried the different modes. Super happy with it
Quick question.
I just swapped emitters in mine fw3a from lh351d 4000K cri90 to sst-20 3000K 95cri.
It looks 2x dimmer on turbo than before….
Is it normal, that sst-20 produce less lumens?
Mike
SST-20 definitely produces less lumens, but the tint is very nice.
I’d assume that the change from 4000K to 3000K is making most of the visual difference. The Samsung emitters definitely produce more output, but not 2x more.
I was thinking 2x seemed like a lot too. I know there is a big difference between the XP-L and SST emitters.
Thanks, it seems that is normal.
Tint and colour reproduction of sst-20 is really nice. I can live with less lumens
Mike
I agree with you. At first, I was very disappointed in the output, and the heat a little bit, but after getting used to it, I really like it. The tint is great, and honestly, it is not nearly as bright as the XP-L, but still plenty bright.
In one of my FW3As, I had to change the o-ring for the button stiffening mod to a larger diameter one. This was because I got accidental activations. It’s been about a week with the new o-ring and, so far, no accidental activations.
Not my mod. A FW4A mule with 12 Samsung LEDs (LH351D?):
Wow, that is crazy, 10,000 lumens!
I wonder how long you can hold it for on max before your hand melds with the aluminium!
Is there an 18350 cell that can put out that much current?
samsung q30 can put out 20amps
sony vts can put out 30amps
irun samsungs in my fw3 and fw1
ive also got 6 sony vts that are great, but nothing that warrents me putting them in
You need to look at the listing carefully and read what I wrote carefully - 18350 cell
ah its to early and im only on my 3rd coffee
ok well i use a efest 18350 700mAh battery in one of my convoy s2 , it got full brightness draws about 5 amps, i read its max output is 10 amp
this should be good for about a very very short amount of time on full power
If that’s the case I can’t ever see that light reaching 10,000 lm with a short battery.
10,000 lm / 12 leds = 833 lumens per led
According to Texas_Ace’s tests you need more than 1.5amps to reach 800 lumens.
12 leds * 1.5amps = 18 amps
So something capable of 20 amps (the 18650’s forsh mentioned) might see the specified output but not happening with short cells
18350 battery 15A 1200mAh Flat Top Li-ion ORBTRONIC 15amp for 5 seconds on and 30 seconds off,
yeah like you say pal, 18350 is proberly not possible drawing 20 amps, and really who wants to have a torch that can go full power for 1 seconds, unless your making some kind of strobe that blinks twice a minuite!
Ok, that was really weird……… I was looking at your photo forsch and rolling my fw3a (normal) between my two hands thinking, suddenly it came on and off a few times, the started doing alsorts of weird flashes! It wouldn’t switch off and i had to unscrew the head to stop it………
I have no idea why - maybe it was jealous!
