[Review] Convoy M21C ( XHP70.2, 1 x 21700) - Excellent performance and regulation # Outdoor beamshots included
Can you measure the diameter of the driver?
I think it has something to do with the fact that the way we perceive light isn’t linear but logarithmic.
So having a level between 50% and 100% would hardly make any difference.
Keep in mind I could be totally wrong :slight_smile:
Please Simon, give us an OP reflector for this light!
Have you taken the driver out yet?
Are you going to?
I'd like to see photos of it outside the light.
The one photo of it inside the head doesn't reveal much.
What's on the top side?
I don't see it on the AE Convoy Store
@bilakos, could you clarify if you measured current into or out of the driver, please?
Hello Jared and sorry for the late reply!
Yes, I can confirm that I measured just the input current and not the output.
As you’ve mentioned in your previous replies, the driver seems to be capping the max current on turbo in order to not fry itself.
Do you have a size comparison?
This seems like a nice all around light from convoy.
8.87A from a mostly charged battery means about 33W input. Assuming 90% driver efficiency that is 30W to the LED. Looking at the xhp70.2 test (from Texas ace) it looks like maybe it’s sending about 5A to the LED at 6.16V.
For those saying they want an OP reflector, the xhp70.2 beam really looks fine from a smooth reflector so I don’t think that’s a big deal.
No apologies needed! Thank you! :slight_smile:
Is the driver a secret that you cannot post photos of other than the one of it inside the head.
The driver is the heart of the light so info about it is important for full review.
We like pictures!
FWIW the TC20 is much less throwy based on the beamshots here and the size of the reflector.
I second that.
This light has me interested. It’s about time we had more lights using decent switching drivers from good-quality manufacturers like Convoy.
It would be nice to see more photos of the driver, though I’m going to guess from the specs and testing that it’s using the tried and tested TPS61088 .
Would also like to see an OP reflector version. I’m usually an e-switch guy, might drill one of these for a side switch…
ok ,i will produce OP reflectors
How does this compare to an L6?
Would this be a good SBT90 host?
Thank you, I will definitely buy a few when the OP reflector version is available.
Thanks for listening to feedback from enthusiasts and customers.
not brighter as L6,and the diameter of the reflector is a little small ,so the beam is more floody.
The reason I have not used SBT90 is that the brightness is low and the price is very expensive
Nice… thanks.
Simon, is Convoy M21C xhp70.2 with Biscotti firmware ?
