M4D M4X deals - Astrolux WP1 and WP2 LEP
Hi Martin!
Just saw the code for the On The Road 311. It is around 12€ higher than on their AE store without the code, and still 9€ higher with the code…
Banggood is…expensive these days…
Thanks for the codes, though :+1:
this? https://s.click.aliexpress.com/e/_dXtCnj5
good price indeed!
Precisely! BG is way higher, even with codes :zipper_mouth_face:
Every time some catastrophe occurs of any level happens, the market falls and bankers rake in millions like in 2008.
Watch ” The Big Short ” and see these greedy bastards in action.
Hello my dear friends!
Thank YOU for showing interest for the new Lumintop models so we could get them!
Just use the provided Links and Codes below to go to Nealsgadgets.com for more Information and to purchase the Item you want!
LUMINTOP HL3A
2800LM EDC LED FLASHLIGHT HEADLAMP
ANDÚRIL UI
CODE: NDHL3A gives you 25% OFF
TLF/BLF FW4A
GREY CREE XPL HI 3600LM EDC LED FLASHLIGHT ANDÚRIL UI
CODE: M4DFW3A gives you 20% OFF
aaand:
free deep carry clip for orders placed March 10-17
LUMINTOP GT MINI PRO
3500LM 750M 18650 THROW EDC FLASHLIGHT +18350 TUBE
NEALSGADGETS C8+
KM CSLNM1.1G THROWER LED FLASHLIGHT
Martin, thanks!
Any details on the C8+? What the UI is? What the amps are? What features the driver has? The CSLNM1.1 is quite different from the CSLPM1.1, yet the listing has only the spec of 700 lumens/1000 meters spec listed, so which is which? We know one of those LED's has better throw, less lumens so the #'s can't be the same.
I was stupid and bought one of the ones in the Other Flashlight category last night because I missed out this time. Who knows what the difference between the one in there and the C8+ section item is…
i got the base one with aluminium MCPCB
the driver is a 8x7125 l-m-h-strobe-sos :(
i get 450 Lumen and 139 kCd
Ahh, ok. So that means 2.8 amps. 139 kcd is 745 meters - not close to 1000 meters spec'd. Ouch on the UI! Agree :(
Something is quite wrong there... You are only gonna get so much out of the LED with 2.8 amps. For me that leaves only one option - driver replacement. Was wondering about that alum MCPCB option. Maybe the ones with copper MCPCB have higher powered drivers? I wouldn't risk 4-5 amps on an alum MCPCB, unless it's DTP.
1000 meters is 250 kcd. Dunno, may be do-able with 5 amps W1? Probably...
Funny, not sure you were around in the HD2010 and C8 days, maybe 2012-2013 or so. But the HD2010 was known for it's direct FET driver - a rarity to get high amps out of a stock light at the time. They used the same driver in other lights like C8's, UltraFires, and other brandless lights. The amps were only limited by the springs, LED wires, and battery resistance. So one day I used a hot cell in a C8 with that driver, but of course the LED was on a cheap alum MCPCB, and the LED de-soldered itself while running the flashlight! Thos cheap alum MCPCB's are a heat trap for sure!
He also has copper MCPCB
and i asked hin to get a better driver for next batch ;)
but for the privce a nice host to paly with (or still impressive muggle light!!!)
Will have to disassemble the other one and get a 5A convoy driver… I think I have a 20mm WF1 on copper MCPCB around somewhere. So realistically I’m just buying a host, blah.
C8+ w1 is sold out …. the price is very good at $23.99
I got the one from here:
But yeah nobody wants the Alu one lol
Order placed for the HL3A. Thanks Martin :+1:
All depends on the quality of the alum MCPCB. Charging $4 for a copper one is a bit high but I'd rather pay it then take chances with a pricey Good LED on a unknown aluminum one.
instant blue @ 5.4 A ;)
wut? I thought official limit is 4.5-5 amps, but to push it, up to 6 amps is being used. Instant blue? You mean if it's on a poor alum MCPCB?
what about this:
Now torture test. Torture for this emitter will be any cell in Samsung 30Q rang or better if used in FET DD setup which of course will pull a lot of current. So in mine test emitter survived over 7A of current draw for more than 3 minutes(for couple of times). After cool-down it did not loose initial properties(performance remained the same) which implies that emitter is very robust. This were mine results. I also found that mine test subject had best performance at around 5.8-6A (1200FC)
This was posted here in the OP: https://budgetlightforum.com/t/-/53735
What driver did you recommend they use? If sticking with 8x7135 at least offer it with the 12 group 55 mode driver from the xpl c8. The 4 mode 5a driver from the sst40 convoys would be sweet
Is the current driver the one where its lo-mid-hi and it blinks on low after 3 seconds?
How many amps is the current w2 model getting?
do you get what you ordered? bg is working normally?
neal and banggood send what is on stock
only some manufacturers (their suppliers) are delayed with new items)
