Hank_Wang
(Hank Wang)
March 2, 2020, 12:47pm
485
pepinfaxera:
March, 2, 2020, we have come back to work, everything is back to normal.
Great, Fantastic . Glad to hear you’re doing well after all that’s happened too.
I need two Noctigon K1, W2 (Osram CSLPM1.TG): 1400lm, Lux: 550Kcd,
Dark brown and Creamy
I am: JOSE EGUILAZ TIESTA, Gijón, Asturias, Spain
In two packages, by topic Customs
In the Spanish Forum, “https://www.forolinternas.com/index.php” they love you and you are highly recommended.
regards, pepinfaxera
Thanks, will send the order into two packages.
Kevin_Z
(Kevin Z)
March 2, 2020, 3:03pm
486
Because V1 doesn’t use anduril.
bquinlan
(bquinlan)
March 11, 2020, 1:03am
487
That is exciting news! I like the Noctigon K1, but it is too large for most of my uses. I would love to see an improved D1S.
maukka
(maukka)
March 21, 2020, 12:04pm
488
More details please!
<p><span style="font-size: medium;"><strong><span style="color: #ff0000;">The boost driver upgrade is available for the quad version of XP-L HI, SST-20, Osram W1/W2, Nichia 219B R9080 versions, each LED receives 2A current. The driver is not...
Anduril boost driver with 4x LEDs in series would be a dream…
Wow, we need details!
- Which LEDs available?
- Inner tube? Double spring looks interesting.
- Flashing pads for firmware update?
- RGB aux LEDs?
- Available accessories?
- Tritium vial included or only the slot (important for import)?
Looks like a FW4A with switching driver and aux LEDs.
I think I’ll take a cyan one with lanyard ring, short battery tube and steel bezel.
Hank_Wang
(Hank Wang)
March 21, 2020, 12:49pm
490
Well, I did not mean to release it until it’s ready for sale.
Currently, it’s still under testing.
It’s Linear 5A + direct drive, almost the same LED & TINT options like the D4V2, except there will be
a 8 pcs LED mule version, as well as a E21 quad version later, I wish to send one E21 version to you for reviewing.
Hank_Wang
(Hank Wang)
March 21, 2020, 12:52pm
491
SammysHP:
- RGB aux LEDs?
The pocket clip and lanyard ring are both included in the price.
5A constant current+DD drive, RGB aux LED like D4V2.
ch1ir
(ch1ir)
March 21, 2020, 12:54pm
492
This this amazing, I’ve had my D4 for a year and is still my favorite light, Hank I’m very excited to get my hands on one! It is so sleek looking!
I’m going to say that is the signal spring instead of a tube…like the NovaTac lights use…
Thank you, Hank! Awesome light.
KawiBoy1428: The spring doesn’t look like it’s long enough for the full tube.
oweban
(oweban)
March 21, 2020, 1:10pm
495
This is jaw-dropping :o
Screaming for a good deep carry clip though IMO.
Love the options of mule and E21A.
DrDevil
(DrDevil)
March 21, 2020, 1:12pm
496
Agree, this looks amazing.
Maybe one short inner tube connecting to the spring for both the long and the short Battery Version?
Nichia E21A ? This would be mine :heart_eyes:
ch1ir
(ch1ir)
March 21, 2020, 1:14pm
497
In lights what does mule mean?
SammysHP:
If you look at the pic blowd up, the big spring looks like it is retained by an isolation ring maybe made of rubber or plastic, keeping the spring located against the driver signal trace away from the driver ground ring and from falling out???…. just an one eyed observation…
Hank_Wang
(Hank Wang)
March 21, 2020, 1:19pm
499
SammysHP:
The outer bigger spring is used to push the inner tube, so that it will have secure contact with
the tailcap, and the inner tube will not fall off when you change the battery.
Right on… :+1: Nice Job Hank!
DrDevil
(DrDevil)
March 21, 2020, 1:24pm
501
[quote=ch1ir]
Mule means no reflector or optic.
Something like Amutorch AT40 mule Version for epample or Zebralights Headlamps have Mule Versions
https://budgetlightforum.com/t/-/59408
ch1ir
(ch1ir)
March 21, 2020, 1:27pm
502
Woah, thank you, I was assuming I’d get 2 or 3 sarcastic posts, guess I need to join the mule club, Hank thanks for always being on top of the FL game
pennzy
(pennzy)
March 21, 2020, 1:41pm
503
I ho.pe Emisar’s e tail switch is more reliable then the FW3A. While mine eventually settled in, I never really trust it.
Need a Crenelated Bezel…to see the glow when bezel down and the tail cap trit at the same time…
