2xAA driver?
So I found my old Dereelight Javelin 2xAA P60 host and I figure I should build it. I really only see two options out there, both on Fasttech. One is a 5-mode 800ma driver the other is a single mode 500-800ma driver. Are there any other viable options? Initially I was going to yuji an old P60 but all of my old spares look brand new. Hate to gut a brand new bulb… I’d like to build something very simple with a low mode and a high mode, no memory. In a perfect world I’d like to pull 1C from a pair of eneloops on high but given the lack of options I’m sure I won’t get that lucky…
I like that 1-mode 800mA driver. Works nicely with 2×AA. (Less current with 1×AA.)
I’ll probably try it, just want to be more versatile. Any thoughts on best moderate to high CRI LED for 800ma drive current?
’351, ’219B, unno.
I like the 4000k LH351D 90 cri for its high output and decent beam color.
The 5000k is decent also. Retains lots of output with high cri.
KD has a few boost drivers, here’s a 17mm http://kaidomain.com/S024883-17mm-0_9V-3_6V-3-Mode-Boost-Driver-Circuit-Board?
Interesting, I just picked up a Malkoff MDC 2AA body and VME head and I need someone to build a custom P60 dropin for it. I couldn’t really find a driver, do you know any users capable of building a P60 with a 2AA friendly Top quality (the Malkoff body and head weren’t cheap, need top quality components) driver?
I wouldn’t exactly call them a quality boost driver, they are a decent boost driver in my opinion.
I mentioned a few more in this thread. Recommend me a 0.9-4.2V driver - #7 by moderator007
Try making a new thread asking for a modder to mod your light. They may even have something in mind that would work even better.
Thank you!
I have one of these in a single AA light that works on a 3v lithium battery:
http://kaidomain.com/Flashlight-DIY-and-Tools/Circuit-Board-Driver-Board/S025059-CF-17mm-0_9V-3_3V-4-Groups-2-to-5-Mode-Boost-Driver-Circuit-Board
It’s not brilliant but is ok and does have fast-ish PWM (when i first got it i thought it didn’t have PWM but started noticing it in reflections) and i haven’t used it that much so can’t comment on longevity, but it is the best option i’ve been able to find, has a couple of group options, and is much better than the slow-pwm, badly spaced drivers you’d normally get in AA lights so definitely worth a look.
I did have a problem with the driver but it looked to be under a very specific circumstance which shouldn’t happen in normal operation.
Mentioned in this thread:
