I recalibrated the temp senor and set the max temp to 50 degrees Celsius, it’s still stepping down straight away when Turbo activates. I’m using a 40T and it barely gets warm. I absolutely hate Anduril having no setting to switch off the step down like NarsilM
Try to cheat with calibration.
Tell on first step that there are 10 degrees against real 25, as example. So if you set +20 on second step, real step fown level would be 65.
When does it step down? Mine is at 20 seconds with temp set to 65. Apparently the thermal code needs to be adjusted for some lights. Fireflies just used the same code from another light (PL47 I think). Not sure if the FT03S has the same problem but it does the same thing.
Yeah that’s right, entirely forgot about the FT03S issue. It’s just a shame that manufacturers aren’t thoroughly testing the firmware on their lights first.
Step down after 3 seconds is definitely not temp firmware issue, the heat can’t flow that fast to the MCU
Its either voltage stepdown or wrong calibration
I have seen on some of my Anduril lights strange thing. After battery change, if i step up in stepped mode up to 6th level, light flow go down. If I switch off and on flashlight everything works well.
It seems to only work correctly if I set the temp to 13 degrees and the step down to 50. The other lights work perfectly. It’s very annoying having all these issues with Fireflies.
