Let’s put the superstition back!
This Friday the 13th you are lucky!
Only one day, the most mystical and superstitious day of the year, you can buy any product in our online store with a discount of –30%!
Repeat…DISCOUNT ON EVERYTHING!
Thin, lightweight and stylish Armytek Zippy is now 3 in 1. Multi-flashlight Zippy Extended Set, which has no equivalents, is suitable for daily use, services or camping. Durable steel ring allows to carry the flashlight with keys. Removable stainless steel clip is securely attached to clothing or belt. Rotatable 360° headmount with magnet and plastic clip for cap make it possible to use the flashlight as a headlamp. Strong magnet in the mount securely holds the flashlight on metal surfaces. Built-in Li-Pol battery is easily charged with Micro USB cable.
–160 lumens of light, wide beam angle of 110°.
-Beam distance up to 15 m.
-Indication of battery charge level and charging process.
-IP67 standard: highly reliable protection from dust and submersion to 1 meter for 30 minutes.
-Unique fully glowing body and 4 colors to choose from.
-Possibility to charge the device with Micro USB cable and built-in Li-Pol 100 mAh battery.
–5 years no-hassle warranty.
“Sorry, it seems that we have no shipping options available for your location.
Please check your shipping address and contact us if everything is okay. We’ll see what we can do about it.”
Nico- You will get that message on backordered and out of stock items, found out by troubleshooting what was in my cart lol.
Armytek- Just received my wizard WR, so far super impressed! Not clear in the manual but when strobe is on that removes firefly move correct, so turning it strobe off would turn on firefly? When is the warm version going to be on the store for order?
Summer is almost here. It’s time for warm evening bike rides, night hunting and hiking.
People will return to live communication and outdoor activities soon.
To make your preparation for active leisure more pleasant, we give a 15% discount on ALL:exclamation: Armytek flashlights and accessories, including the new 2020 products and time-tested models.
Save your time and money - order a new flashlight at a special price till May 10 and be ready for exciting adventures!
Hurry up, the bestsellers are in stock!
Use the link below to buy with the discount
Hello! Light weight, reliable, long-range flashlight for searching operations. Additional accessories represented by weapon mounts and original remote switches are designed for comfortable usage of flashlight in different conditions. Here are the brief description of the lights.
P. s. there is a hidden promo code( with 30% discount) in the text.
Barracuda:
Brightness up to 1150 OTF Lm.
Beam distance up to 775 m.
Up to 30 days of work with two batteries 18650 Li-Ion.
Barracuda Pro:
Brightness up to 1500 OTF Lm.
Beam distance up to 800 m.
Up to 500 days of work with two batteries 18650 Li-Ion.
Thanks for the reminder! I spent so much time trying to figure out why I can’t change the turbo mode and then I realized Armytek mistakenly sent me the Barracuda Regular version not the Pro version :person_facepalming:
But with the Dobermann, it was set to Turbo 1 instead of Turbo 2, which is why my measurements were so low. I will recharge my batteries and retest it. Thanks for the tip!
One of the reasons I haven’t purchased anything since my Wizard Pro… Awesome headlamp by the way. Almost perfect. Just wish I would accept primary cells as a backup source.
Same here. I’m waiting for a better shipping price before placing my order. Anyone know how often items are shipped from the US warehouses and therefore the shipping price is $10?
I believe it used to be able run on CR123A cells, but no longer advertises that feature. I suspect that is due to the addition of onboard charging, to prevent users from attempting to charge primary batteries. I would not be at all surprised if the light actually runs fine on them, but I don’t know if anyone has tested it, which could risk damaging the light. If it does work without harm, you would certainly want to be careful not to habitually attach the charger.
Hello!
We have prepared a small game for you.
You need to find out which model of the flashlight is in the photo.
The first person to write the correct answer will get a 35% promo code.
