Hah Martin! I rcv'd the SC31B and very impressed! Easy to mod with a std size 20 mm driver to run Anduril, easy to upgrade the LED as well. Want to order another but Amazon US coupon doesn't work and your BG coupon says expired. Any luck in getting another coupon code for US? Don't care of Amazon or BG. Thanx!!
how many do you want?
Hhhmm, maybe take 2. Kit not needed.
M4BG coupon doesnt work, please edit this out!
thanks
use m4x2020
thx bro
Hello my dear friends!
Today i got a new SOFIRN deal each for Amazon.COM and Amazon.DE !
(using those links above for your regular shopping donates some traffic to me without added costs for you! )
more traffic means more likely to get more deals…
Sofirn SC31B KIT 50% OFF
1000 Lumens, 5 Modes
Rechargeable LED Flashlight 18650 Battery Included
50% discount makes $12.49
my code: MARTSC31B (use in checkout)
Sofirn C8F für € 34,79
Leistungsstarke taktische Taschenlampe mit
3 XP-L-LEDs, maximal 3500 Lumen, 21700 Akku, 4 Lichtgruppen, 1 bis 7 Lichtstufen 2 Schalter
inklusive Akku , USB Kabel und Ladegerät!
Mein Code: 3IYGA27Y zieht 40% ab!
(gilt bis zum 7.4.!)
bitte meinen LINK ZUR LAMPE NUTZEN
Thanx Martin! Ordered one, wouldn't let me order two but that's ok.
strange
would placing 2 orders work?
try Code P6BTZU4B also
Tried in 1 order, and tried in 2 separate orders. for 1 order, said restriction on qty. For 2 orders, complained bout the code.
Order placed for SC31B Kit. Thanks
I ordered a SC31B kit last week using the "P6BTZU4B" discount code from post #4974 (I did not use the most recent code "MARTSC31B" from post #4997), but it will take awhile to arrive since I am not an Amazon Prime member.
Thank you for this generous offer.
Ordered SC31B Kit from amazon. I already have one but with th codes it’s just such great value to keep another one at hand
thank you all for your support! :beer:
Olightstore.DE
on non sale days/items: 15% OFF Code: M4DOL15
Neben der I5T Cu wird es am 27. März ab 00:00 Uhr (Wecker stellen!!) auch weitere Angebote für euch
-> 31% Rabatt auf die Seeker 2
-> 25% Rabatt auf die I5T Cu
-> 40% Rabatt auf das I5T Cu + Seeker Bundle
-> 40% Rabatt auf die S2R Baton II (19-21 Uhr)
Olightstore.COM
on non sale days/items: 10% OFF CODE: M4XOlight10
Sale is starting on March, 27th 0:00 AM – you might need to set your alarm!
25% OFF the COPPER i5THello my dear friends!
banggood.com just listed some new flashlights and i bring the groupbuy to my fans and friends!
please click my links to read the full Info on the shop page!
My code: MC8A6 gives you 25% OFF on all 6 items!
Astrolux® C8 SST40 5000/6500K
2200LM 7/4modes A6 Driver
Long Thrower Tactical LED Flashlight
+ 1Pc 30Q 3000mAh Power 18650 Battery
Astrolux® C8 XHP50.2
5000LM 6500K 7/4modes A6 Driver
Powerful Strong Floodlight Tactical Flashlight
Strong Floodlight Tactical LED Flashlight
BLF A6 SST20 4000/5000/65000K
1300LM 7/4modes
EDC LED Tactical Flashlight 18650 Mini Torch
BLF A6 SST20 4000/5000/6500K
1300LM 7/4modes EDC LED Tactical Flashlight 18650 Mini Torch
+ 1Pc 30Q 3000mah Power 18650 Battery
Servus mitnand!
Ich habe von Sofirn einen netten Deal für eine tolle Lampe bekommen.
-> die Narsil software ist “einfacher” als das “verspieltere” Anduril und damit auch für weniger technikaffine Anwender gut geeignet
Sofirn SP36
6000 Lumen, USB C Ladeanschluß, 4x XPL2 LED, NarsilM V1.2 Treiber
inkl. 3x 18650 Li-Ion Akku
Mein Code: RE7EGFON bringt den Preis auf €53,99
- Die SP36 ist eine kompakte Taschenlampe die mit ihren vier XP-L2 LEDs bis zu 6000 echte Lumen leistet und damit ein Allroundlichtbild mit bis zu 361 Metern Reichweite erzeugt. Das ist weit mehr Licht, als man für die meisten Aktivitäten benötigt.
- Die Lampe ist mit dem gleichen Treiber wie die Sofirn Q8 ausgestattet und verwendet die neueste Software, NarsilM V1.2. Damit ist die Bedienung sehr leicht, die Helligkeit kann einfach stufenlos verstellt werden. Bei Bedarf kann die Lampe aber auch mit festen Leuchtstufen programmiert werden.
- Über den verbauten USB C Ladeport kann die Lampe die drei Akkus mit bis zu 2 Ampere bei 5 Volt intern aufladen. Das erspart ein externes Ladegerät und vereinfacht den Ladevorgang erheblich.
- Die SP36 ist durch die Verwendung von 3 Akkus wesentlich handlicher und leichter als Lampen mit 4 Akkus. Daher ist sie auch längere Zeit bequem zu halten oder in der Jackentasche zu transportieren.
- Lieferumfang: SP36 LED Taschenlampe, 3x 18650 Li-Ion Akku mit je 3000mAh, Ersatzdichtringe, USB C Ladekabel, deutsche Bedienungsanleitung und unser freundlicher Kundenservice !
DE/EU only….?
it depends on your country if they deliver to you...
Looking for a new code for the Astrolux FT01. Last two times ordered they failed customs and now the coupons have expired. Great lights they fit the Streamlight Stinger holsters perfectly. The tail part even flairs past the leather tube holding them in there. Much lighter, shorter, brighter, and longer running than the Stingers they replace.
