I received my E02 and E03. Both seems OK.
E02 came in retail package, E03 has a simple cardboard box.
The E04 clip is a trash. Diffrent than advertised and not fits to the groove well. It tends to pop out. Simply not designed to this light. I wrote the seller asking for a good one.
The E02 clip is original and fits perfectly.
Striker Mini use the classic tactical user interface. You can control it by one hand easy.
Light modes are very simple, high, low + hidden strobe.
tail is tactical forward-clicky switch. slightly tap to turn the light, release it the light will go out. Full press till a click sound is heard to constantly turn on/off the light. quickly double half-press activate hidden strobe. If you want constant strobe, full press it. The strobe frequency is 20Hz, full power, enough to blink
Striker Mini is positioned as longest range edc flashlight in its class. utilizes a high efficiency osram nm1 led, adopts dual sided AR coated 99% transmitteance toughened glass lens and SMO aluminum reflector with vacuum plated to get a max. 635 lumen output, max. 430 meters about 1411 feet beam distance.
Striker Mini is Multi-Fuel pocket EDC flashlight. the circuit design a wide working voltage: 0.9 v - 4.2 v
the package included one piece Mankerlight type-c USB 920mAh 14500 lithium battery. of course, also accept other brand 14500 lithium battery, Ni-MH AA battery, Alkaline AA battery and other AA-size batteries on the market.
and Striker Mini adopt mechanical switches, no electronic switch, different with the competitors on the market.
turn it off, no drainby, ideal as PSK, or emergency using etc.
Mini size & lightweight is perfect for every day carry. it is ideal as personal EDC gear.
Thanks for your advise. Now it is second batch. next batch we will consider other emitters but need some time to test.
If we make other color body, any advise to make which surface finish of stainless steel striker bezel we should.
black body, we make stainless steel natural color, anti-fingerprint.
army green body, we make PVD black on stainless steel striker bezel.
Red body, which color surface finish is better match?
It is first time for us to make two direction body clip.
Striker Mini adopts 304 stainless steel with black coating.
It feature striker mini easy carry. you can attach it to the backpack, tool bag, front pocket etc.
You can also attach it to the edge of hat for hands-free use during activities.
We also make lanyard hole on pocket clip, so you can connect a lanyard, easy carry.
Of course we have also make two lanyard hole on tactical ring.
though Striker Mini is ultra-compact, we design high efficient dual constant current circuits(non-PWM), which is huge different with the competitors on the market. most AA size flashlights on the market have one constant current circuit if using only AA. but for Striker mini, no matter which battery the end users use 14500 li-ion battery, or Ni-MH AA battery, or Alkaline AA battery or other AA size batteries on the market. the constant current circuits enable Striker Mini have the constant brightness beam without flashing.
Though Striker Mini is ultra-compact size flashlight, we have also integrated advanced temperature regulation module on driver PCB. We don’t reduce the cost of materials to catering the market. We make copper MCPCB and all-in-one alumium housing. The employed thermoelectric separation technology ensures heat generated from the LED and circuit is transferred to the exterior rapidly through an accommodated copper substrate. driving the Osram KW CSLNM1.TG LED to its fullest potential while extending its life span.
