That command is probably best put in the #initCmd tag.
Handling modes requires two type of settings:
One to read the actual mod: #askMode :SENSE:FUNCTION?
And a coupe of commands to select modes: #cmdMode VAC VOLT:AC
abort;
*cls;
conf:volt:ac
The VOLT:AC is what the meter answers to the #askMode command and the lines below the #cmdMode command is how to select that mode.
Finally you remove the #cmdMode that you do not need
If you get this worked out you have a full configuration for the meter.
I’m getting ;; –410,“Query INTERRUPTED” error message if I try to switch the meter operating mode via the popup menu.
Also, adding the SYSTEM:REMOTE command to the #initCmd results in the same error
Writing these commands, such as CONF:VOLT:AC in the input field in the program works fine.
I read here, that there needs to be a short delay between SCPI commands to avoid this.
edit: For the measurement to work on other modes than VOLT:DC, I had to change the #askValues to READ?, because MEAS? just switches the meter to the default VOLT:DC mode.
You can try sticking a “;*ESR?” after the commands that need a delay, if this do not work I will add a delay function.
You can put many command on the same line with ; (semicolon) between them. The software will split them and send them on at a time. Anything with a ? will for a wait for the answer.
Could you have forgotten to restart the software after editing and saving the definition?
I have added a delay function, use [time_in_millis] as a SCPI command, this means it must be on its own line or with semicolons before and after it.
I.e. either this:
*cls
[1000]
SENSE:FUNCTION:ON “PER”
or this:
*cls;[1000];SENSE:FUNCTION:ON “PER”
for a 1 second delay. The minimum is [1] and the maximum is [9999], no spaces is allowed inside the brackets.
Yes, I did. It has version 0.13 on the About screen (You can reach that from the configuration page). It is a bit hysteric about the format, if there is anything but bracket numbers bracket it will ignore it.
The SCPI output part will split into separate commands on all ; and newlines, then it will remove leading and trailing spaces. What is left is checked for the delay function and else send to the meter.
I’ve been logging for 24 hours straight and this thing is rock solid. Haven’t gotten the delay commands to work yet so switching the operating mode isn’t happening for me.
Yes, that’s what I noticed. I get no errors with any of the other commands such as :sense:function:on “volt:dc”, only the bracketed delay command triggers the error beep.
I just checked in the 44401A manual and did not find the function:on command anywhere. It looks like you have to use function “range”, not function:on “range” and can optionally stick a “sense:” before the function
The sense:function:on “volt:dc” or “volt:ac” still works fine without error for changing the DMM mode. It doesn’t matter if I leave out the :on part at the end or include it. Conf:volt:ac or conf:volt:dc also work.
So the problem is not the SCPI command for changing mode. It’s the delay. And if I omit the delay command (in brackets), then the meter reports the –410,“Query INTERRUPTED” error.
Would it be possible to make the program realize the mode used if I switch the mode manually. Now if I type in the sense:function “volt:ac”, the program doesn’t realize that it should be measuring ac even if I type in sense:function? to query it.
I can see that I may send a empty line to the meter in some circumstances, I will fix that.
The meter uses the #askMode command to check what mode the meter is in. There is some code to trap manual mode changes, but it do not work at the current time (This will, of course, also be fixed).
Beautiful! Mode switching from the popup menu with delays works fine now.
One more suggestion: I’d like the logging to start immediately. If I choose the 10sec option, it takes 10 seconds for the first entry to be written. Also a numeric input for the logging sample rate would be nice (I’d like 0.5s , 5 sec and 30 sec at least).
Bug: at least for me the slope for /h doesn’t work.
If you get everything working, please give me a copy to include.
The #author tag works, you can try it and check “Configuration, About”
It is already support, instead of using the button write a command: #log interval
There is a couple of command and the help window will show them if you type a # character.
The command window supports 3 types of input:
SCPI for the devices
Regular commands, they all start with #. I will be adding many more later on.
Expressions/statements, they start with = and are very similar to the calculator window, except you are guaranteed to have all the columns names for devices as variables with an updated value.
Missing “break” :person_facepalming: , it will be fixed in next version.
