strange
would placing 2 orders work?
try Code P6BTZU4B also
Tried in 1 order, and tried in 2 separate orders. for 1 order, said restriction on qty. For 2 orders, complained bout the code.
Order placed for SC31B Kit. Thanks
I ordered a SC31B kit last week using the "P6BTZU4B" discount code from post #4974 (I did not use the most recent code "MARTSC31B" from post #4997), but it will take awhile to arrive since I am not an Amazon Prime member.
Thank you for this generous offer.
Ordered SC31B Kit from amazon. I already have one but with th codes itâs just such great value to keep another one at hand
thank you all for your support! :beer:
Olightstore.DE
on non sale days/items: 15% OFF Code: M4DOL15
Neben der I5T Cu wird es am 27. MĂ€rz ab 00:00 Uhr (Wecker stellen!!) auch weitere Angebote fĂŒr euch
-> 31% Rabatt auf die Seeker 2
-> 25% Rabatt auf die I5T Cu
-> 40% Rabatt auf das I5T Cu + Seeker Bundle
-> 40% Rabatt auf die S2R Baton II (19-21 Uhr)
Olightstore.COM
on non sale days/items: 10% OFF CODE: M4XOlight10
Sale is starting on March, 27th 0:00 AM â you might need to set your alarm!
25% OFF the COPPER i5THello my dear friends!
banggood.com just listed some new flashlights and i bring the groupbuy to my fans and friends!
please click my links to read the full Info on the shop page!
My code: MC8A6 gives you 25% OFF on all 6 items!
AstroluxÂź C8 SST40 5000/6500K
2200LM 7/4modes A6 Driver
Long Thrower Tactical LED Flashlight
+ 1Pc 30Q 3000mAh Power 18650 Battery
AstroluxÂź C8 XHP50.2
5000LM 6500K 7/4modes A6 Driver
Powerful Strong Floodlight Tactical Flashlight
Strong Floodlight Tactical LED Flashlight
BLF A6 SST20 4000/5000/65000K
1300LM 7/4modes
EDC LED Tactical Flashlight 18650 Mini Torch
BLF A6 SST20 4000/5000/6500K
1300LM 7/4modes EDC LED Tactical Flashlight 18650 Mini Torch
+ 1Pc 30Q 3000mah Power 18650 Battery
Servus mitnand!
Ich habe von Sofirn einen netten Deal fĂŒr eine tolle Lampe bekommen.
-> die Narsil software ist âeinfacherâ als das âverspieltereâ Anduril und damit auch fĂŒr weniger technikaffine Anwender gut geeignet
Sofirn SP36
6000 Lumen, USB C LadeanschluĂ, 4x XPL2 LED, NarsilM V1.2 Treiber
inkl. 3x 18650 Li-Ion Akku
Mein Code: RE7EGFON bringt den Preis auf âŹ53,99
- Die SP36 ist eine kompakte Taschenlampe die mit ihren vier XP-L2 LEDs bis zu 6000 echte Lumen leistet und damit ein Allroundlichtbild mit bis zu 361 Metern Reichweite erzeugt. Das ist weit mehr Licht, als man fĂŒr die meisten AktivitĂ€ten benötigt.
- Die Lampe ist mit dem gleichen Treiber wie die Sofirn Q8 ausgestattet und verwendet die neueste Software, NarsilM V1.2. Damit ist die Bedienung sehr leicht, die Helligkeit kann einfach stufenlos verstellt werden. Bei Bedarf kann die Lampe aber auch mit festen Leuchtstufen programmiert werden.
- Ăber den verbauten USB C Ladeport kann die Lampe die drei Akkus mit bis zu 2 Ampere bei 5 Volt intern aufladen. Das erspart ein externes LadegerĂ€t und vereinfacht den Ladevorgang erheblich.
- Die SP36 ist durch die Verwendung von 3 Akkus wesentlich handlicher und leichter als Lampen mit 4 Akkus. Daher ist sie auch lÀngere Zeit bequem zu halten oder in der Jackentasche zu transportieren.
- Lieferumfang: SP36 LED Taschenlampe, 3x 18650 Li-Ion Akku mit je 3000mAh, Ersatzdichtringe, USB C Ladekabel, deutsche Bedienungsanleitung und unser freundlicher Kundenservice !
DE/EU onlyâŠ.?
it depends on your country if they deliver to you...
Looking for a new code for the Astrolux FT01. Last two times ordered they failed customs and now the coupons have expired. Great lights they fit the Streamlight Stinger holsters perfectly. The tail part even flairs past the leather tube holding them in there. Much lighter, shorter, brighter, and longer running than the Stingers they replace.
best working atm...
type | brand | model =my link to use | code | price | shop |
FL | Astrolux | FT01 | AC18 | 56.30 | banggood |
lowest was 49.99 in the autumn sales
Amazon.DE: Sofirn C8G KIT 27,59 âŹ
Servus mitnand!
ein neuer Deal fĂŒr Euch!
Sofirn C8G Thrower
2000 Lumen CREE XHP35 HI LED
mit 21700 Batterie
mein Code: UROINF3O dein Preis: ⏠27,59 (45.99)
- Neue Funktionen: verbesserte Bedienung, Akkustandsanzeige durch beleuchteten Seitenschalter, Temperatursteuerung, Maximalleistung bis zu 2000 Lumen.
- Dies ist eine Thrower Taschenlampe. Die CREE XHP35 HI LED mit neutraler Lichtfarbe erzielt eine Reichweite von 565 Metern. Mit 2 Lichtgruppen und bis zu 6 Leuchtstufen leuchtet sie weiter als eine C8F Taschenlampe.
- Betrieb mit einem 21700 Li-Ion Akku. Mit beiliegender AdapterhĂŒlse kann auch ein 18650 Li-Ion Akku benutzt werden.
- Hergestellt aus einer 6061 Aluminiumlegierung mit anodisierter OberflĂ€che und gemÀà IPX8 wasserdicht. Die C8G ist bestens fĂŒr verschiedene OutdooraktivitĂ€ten wie z.B. Wandern, Campen, Erkundungen oder auch fĂŒr die Gassirunde geeignet.
- Lieferumfang: Sofirn C8G, 4.000 mAh 21700 Akku und LadegerĂ€t, Lanyard, deutsche Bedienungsanleitung, AdapterhĂŒlse, 2 Ersatzdichtringe
Interested in a code for the new S43s with LH351D if you have one
will post asap ;)
Today i present my latest groupbuy!
for all 4 versions you can use my
Code: MC8A6 to receive 25% OFF
all 4 share the same base features â please use my shoplinks for detailed Info!
Product name: | AstroluxÂź S43(S Copper) New LED Strong Light EDC Flashlight |
Brand: | Astrolux |
Model: | S43S |
Emitter Type: | NEW: 4x LH351D 4x XP-L HI |
Driver: | NarsilM V1.3 |
Output: | LH351D: 3500lm continuous, 4000lm max with high CRI95 XP-L HI: 3600lm continuous, 4600lm max |
Light Temperature: |
3 options: LH351D 5000K neutral white XP-L HI 5000K neutral white XP-L HI 6500K cool White |
Range: | 184 Meters |
Mode: | Including Default UI and Alternative UI. Detailed operation instructions, please see the following 2 instructions. |
Lumens: | 0%-100% Lumen |
Battery Configurations: | 1x 18650 or 18350 Battery (18650 included) |
Working Voltage: | 2.8v-4.25v |
Material: | Aerospace grade aluminium alloy |
Waterproof: | IPX6 waterproof |
Color: | Black |
Weight: | 60g without battery |
Size: | 88.7mmx 27mm (Lengthx Diameter) |
Feature Functions: | â 4 LED Bulbs â Battcheck mode displays battery voltage â Lockout lockoff function â Charging Indicator â USB Rechargeable â Removeable tactical safety harmmer |
AstroluxÂź S43 $28.46
4x LH351D New LED High CRI 95 Strong Light 18350 18650 EDC Flashlight
AstroluxÂź S43 $32.96
4x LH351D New LED High CRI 95 EDC Flashlight
+ 1Pc 30Q Power 18650 Battery
AstroluxÂź S43S Copper $32.96
AstroluxÂź S43S Copper $37.46
Those are great prices for the S43 and S43S's.
I finished the mod of the first SC31B. It's now running Anduril with a FET+1, XPL HI V4 3C - nice output at about 1400 lumens, some decent throw at 19 kcd. Used a 5.6K ohm resistor on the switch LED's and Anduril supports two output levels that seem to work quite well.
NEWs ! M4DM4X.deals is ONLINE!
Read the introduction post and join a new community!
(well - we are the same, but we have a new place ;) )
Honestly, I liked being able to sort through things by manufacturer, type, etc. It made it really easy to find things for myself, family and friends. The only thing I didnât like on the old setup was the expired codes. Just my .02.
