Could you please link to it?
Link is in the pic: https://www.aliexpress.com/item/4000205975366.html?spm=a2g0s.8937460.0.0.5bc52e0ezoCgLK
They put a junky driver in it. High, Low, Off. :person_facepalming: They could at least copy it properly. Lol
P50 LED and "Magnalium Alloy Material" - what could be better? :FACEPALM:
almost same price as original FT03
no point of buying and mod
+1. It has been around since end of last year if i remembered correctly.
It does not look like something I would buy but I love how minimal it is:
https://www.aliexpress.com/item/4000076549598.html
I like this one! Are there any models with harder shell (aluminum, steel etc?).
9V battery(6F22) is very common battery that can be bought in almost every type of store and people(especially older generations) would probably like to have this one in a house or for emergency situations.
I would be very interested to see what type of driver this light could have?
The driver:
That’s pretty much it.
It’s a knockoff of the Pak Lite, which has been around for 20+ years. It’s expensive but indestructible, with a 10 year warranty.
New UV light with dual green buttons. Design is not perfect but at least it is quite original.
BOMB. LOL.
Coming from Maxtoch is probably a well built (like a bomb) light!
They have some interesting models (most of them on the throwy side), so this may be one of those too!
Biggest problem with their lights (as with some Amutorch/Shadow lights) is the UI (normally with memory, without ML levels, and with longer press for OFF).
Despite this, their lights seem pretty reliable!
I got a few Maxtochs, worked with Amanda in the past. Their anodizing is 2nd to none. They specialized in hunting and searchlights - mil and services.
This one is more SP36 size with the 3 cells, not 4.
Bomb F1... Perfect for a grenade pouch, as I've used for Q8's!
14500 OR AA zoomie on sale for 19.95 (discount after you add to cart). No idea if it’s any good.
https://www.ledlenserusa.com/collections/sports-activities/products/mh5-1
Interesting light on aliexpress…
XHP70 LED Hardlight Flashlight longrange rechargeable portable aluminum flashlight multi-function hunting outdoor use 26650
US $59.82
118mm length
118x39mm
XHP70
Large Brass switch
1 click on
From on clicks thru L-M-H
Hidden Turbo & blinkies - Double click
Electronic lockout - 3 clicks
Expensive, but I thought it looked kinda slick. Same length as TC20 with a thinner head diameter.
https://www.aliexpress.com/item/32980053768.html?spm=a2g0o.detail.1000023.14.13174a13tkFvaP
Nitecore has similar stuff based around their proprietary 21700, with magnetic attachments:
