Emisar D3AA is available now
Please for XHP35 Hi 4500K CRI80+ :heart_eyes: :heart_eyes: :heart_eyes:
This would be a great KR1 option!
I just want to second what ToyKeeper replied to this. What she and I are talking about is not a thrower, but an EDC light that’s more throwy than a D4. It may or may not have more maximum turn-on throw (it probably would using an SST-20), but able to do a given amount of throw (e.g. 5000 candela) with less heat and battery use. My first choice of optic would probably be a textured reflector, which loses a tiny bit of throw for a smoother beam.
The Lumintop FW1A is similar to what we’re describing, but I think Noctigon could do a better job. A slimmer host would be ideal, but the same host with a slightly longer head to accommodate the single optic would work for me.
I see no point in smoothing out a beam intended for max throw. An XPL-HI in a SMO reflector looks great to me - I have many modded XPL-HI V2 5D's and V4 3C's in SMO EDC's, all have a good look'n beam. SST-20's have to be CW/low CRI to get decent throw. The 95+ CRI SST-20's don't throw well.
The point is an all around versatile beam, not maximum throw.
Max throw is not the goal of what I suggested, and given TK’s inclusion of the LH351D and clustered E21A quad on her list of suggested emitters while excluding the White Flat and Boost HX, I’m going to assume she’s having a similar thought. The goal is to be a good EDC light that’s balanced. The D4 is very floody. A White Flat in a 20mm reflector is very throwy. Somewhere between those extremes lie most popular EDC lights, like the Zebralight in my pocket as I write this, or the Lumintop FW1A. Hank has never made a light in that class - perhaps it’s too ordinary when Hank is often pushing the limits, but I’d buy one.
As for high-CRI SST-20s, I have one in my XinTD C8. It’s not far off what an XP-L HI would do, and the better color rendering helps some objects to stand out against their backgrounds. I could put a Boost HL and a FET driver in that C8 and it would throw a lot farther, but it wouldn’t be more useful to me.
Those of us talking about clustered (almost-touching) E21As are familiar with the Cree XHP series, Nichia 144A, and other single-package multi-die emitters. We still want the clustered E21As.
I think the optimization Clemence came up with was to position them slightly too deep in a throwy optic or reflector. That does lose a bit of throw, but smooths out the beam pattern. People who want clustered E21As will generally be happy with that tradeoff.
Why bother? Because E21As are beautiful. They’re prettier than 219Bs, and that’s hard to do.
TIR can be very throwy depending on size and design, Fireflies E01 is a perfect example of this. Parabolic reflectors and TIR optics follow the same physical laws and have the same limitations.
E21A quadtrix model would be an insta-buy for me, it’s’ very easy to smooth the beam out with some DC Fix if people are bothered by a donut hole (and with an OP reflector + Hank’s talent at reflector design it shouldn’t be that bad anyway).
I ask you to think about the production of a battery accessory for NOCTIGON 4*18650 METEOR M43 and EMISAR D18. To use flat top batteries.
Good idea, that’s actually the Convoy 4x18A flattop adapter, i am using it on my BLF Q8 :wink:
Maybe Hank (or Simon) is willing to sell it as replacement part
I would expect the E21A should work fine with a quad Carclo. I don’t know what the throw would be. Carclo’s website indicates not much better than a 219C. I would have expected a bigger difference.
I mean version with quadtrix board like Virence makes with the emitters centered in a reflector.
It has already been said, but just to confirm… The idea is to make a general-purpose daily-carry light with a beam which is balanced and beautiful. It is not meant to maximize throw or lumens. It is meant to be small and practical. The beam would ideally be around 10 or 12 cd / lm, with the beam blended well enough that it would not have any sharp edges or a rainbow effect. This could require a frosted lens, frosted optic, or de-focused reflector.
The D4S beam is pretty close to what I have in mind. However, the D4S is 32 to 39 mm in diameter, and I’m hoping for a much smaller light which is more like 21 mm — basically as small as possible with an unprotected 18650 cell. Also, I would blend its beam a little more because the edges of the D4S hotspot are a bit sharp.
I suggested E17A / E21A because they usually make the most beautiful beam. However, there are other nice options too. I particularly like Nichia 219B, XP-L HI, and XHP35 HI. These are all good at keeping a consistent color throughout the entire beam… unlike rainbow beam LEDs like XP-G3 and XHP50.2.
That’s all just ideas for later though. For now, I’m really looking forward to the KR4 with XP-L HI and E21A. :slight_smile:
Geez. How cruel of you to make me want a thought up flashlight. Who do we have to petition to make it happen?
Ok, think I've been hit over the head enough. Sounds all good, but not for me. For a compact single LED, I'd rather have decent throw with decent tint. The triple and quads have enough throw and flood mix for me in a compact size.
I do agree the XPL HI's have one of the best even tints over the beam pattern - Hank's V2 5D is my favorite, and even the V4 3C isn't bad for a "C" tint for a bit more output. Wish he had a V3 4D to fill the gap - it seems to be MIA...
+1 on 4A or 4D too!
The advantage to having a higher cd/lm than the Carclo 3x and 4x can offer is that you can reach out to longer distances for MUCH longer before stepdowns, and don’t have to set the output to high to see to any given distance for that matter.
Hank. That’s what we’re doing, here, now, in this thread.
Otherwise, maybe Zebralight, but their UI doesn’t compare well to Anduril, or Lumintop, but the FW1A gives up some quality to hit its price point.
I’m not sure what counts as “decent” for you, but I expect XP-L HI would be an option if Hank made such a light. If based on the KR4 host, that would give it a bit more throw than the FW1A. IF based on the slimmer host TK described, it would have a bit less.
The E21A cluster option would have more output and less throw. It would have to be slightly defocused to have the most aesthetically-pleasing beam. That would be minmaxing for pretty the way a K1 with a White Flat 1 minmaxes for throw.
