Finally received an order for food grade silicon tubing and installed on the Water cooled MT 35 light.
The workshop is portable as we are still renting a small house.
The tubing wanted to kink so I made something from .005 thick ss shim to keep it round in the sharp corners.
After several attempts and failures it finally fit correctly.
I’m finished for now until I find the correct SBT90.2 and see if Lexel will make a driver for it.
Wrapped the battery tube with tennis racket tape for a better grip. Also added a simple switch on the pump.
congrats
what mods produced that result?
If interested in the option to program those Novatac Spa Defense models (they come set up as 120T, but can be changed to 120P configuration), there is info in this thread.
And if you want a Titanium bezel, they are available from RPM (guessing you can make your own too).
my latest mod cut the output in half, XP-L to 3000k 219b in a Thrunite T10t (in the middle).
pic is a link to teardown
Those are tools for a lathe and milling machine . I am practicing to get good enough to make flashlights , for myself . Can’t seem to get making the small , fine threads I want yet . I’m getting there slowly .
Modded an Amutorch AX4 quad to run a FET+1 Anduril driver. Fairly simple mod, stayed with the stock SST-20 4000K's - I thought they look relatively above avg for SST-20 4000K's, smooth tints in the beam, yes - slightly green at low modes, not as much as I've seen from other SST-20's though.
This quad reflector light with SST-20's has a tighter hot spot than triple or quad TIR optics, brighter,maybe wider spill.
AX4 on the right, AX3 on the left, AX2's in the middle. If you didn't know, I'm a fan of the Amutorch lights:
More complete view of my Amutorch collection:
AX4 tear down. Classic driver mounted switch:
Dry style thermal grease - needs to be replaced:
The driver cavity is extremely tight. This quad light is the same length as a FW3A so sacrifices are made. I used the hot air station to removed the ground brass ring off the stock driver. The driver board is CK's design from here: https://budgetlightforum.com/t/-/37376/6600, which turned out to be about perfect fit
Reflowed:
Had to move the switch to the very edge, resulting in the back feet not making contact to the pads. Patched in solder/jumper wire to bridge the gap. tested the switch, then epoxied the switch in place to give it back support, keep from breaking/bending as these switches tend to do:
Didn't end up working reliably. Somewhere between 5-10 clicks, it stops working, the let it cool, get another 5-10 clicks with stopping again. So, got bad solder joint on the patch work, and it's epoxy sealed up now :FACEPALM: (I'm using this moji a lot lately...). Used 36 AWG to patch the patch, taking advantage of the exposed metal tabs near the top of the switch:
All good now! Working well with Anduril, temp calib, voltage calib.
I replaced a low profile driver spring with a brass button, and added a 22 AWG bypass to the tail spring. New 22 AWG LED wires, that are pretty short.
The light does get red hot in a few secs, as expected.
Does about 3000 calibrated lumens at turn on (VTC5D cell), drops quick. I measured 20 kcd throw, taken at 5m. Stock I measured 2500 lumens, 17.5 kcd on the same cell. I'ts not much of a power increase, but getting Anduril on it was the main reason for the mod.
Titanium Tool modded for deep pocket clip. Love this light but couldn’t stand the clip that came with it so I made my own. Well Benchmade made the clip, I just made it work with the light lol.
First holes I drilled didn’t work as planned so I just opened the lanyard loop a little(might just remove the loop all together since I’ll never use a lanyard with this one anyway).
It doesn’t tail stand now but this is my work EDC light, tail standing is not in this guy’s requirement.
Simple mod: Modded an old early-model grey Emisar D4.
Reflashed the stock firmware to the latest version of Anduril.
Replaced the stock 10622 optic with a slightly throwier 10621.
I was hoping to replace the stock SST-20 high CRI with ones of better tint, but turns out I don’t have any with better tint that aren’t already sitting in an FW3A.
