TomE, I know that a while has passed since your post, but did you take any photo of the driver and the structure of the head?
Would a “normal” driver (lets assume with a different UI) be suitable for this light?
Also, how should I measure the parasitic drain? I have a small multimeter now, but don’t know how to meausure that…
Yes. Pics to follow in a couple mins - updated now. Guess I didn't post these before, I'll post all I took:
Tail springs:
Driver springs:
I swapped the thin 24 AWG with heavier (think 20 AWG?)
Stock MCPCB all clean:
It's chunkie for sure:
Can't get to my notes right now, but might have gotten a bump from the wire mods - pretty sure that's all I did, plus cleaning up any issues with the MCPCB, MX-4 grease, etc.
A 3 board boost driver - lot of electronics. Notice the R050 and big cap are there twice? Interesting...
For parasitic drain, I have 2 meters capable of doing it. Typical DMM's have a mA or uA setting - for mine you must move the probe connectors - as marked on the DMM. Remove the tailcap and bridge the batt- end to the tube. Be careful though - don't turn the light ON while connected this way - it may blow a fuse, because the low amp measuring mode in the DMM is sensitive to high amps. With my NarsilM lights, I blink the main LED twice on turn ON - that can fry some DMM's. Forgot details but pretty sure it only risks the low amp measuring mode. Some are fixable as well.
Least this is the way I do it - might be other methods.
For the driver, it sure is do-able. The switch is connected off the base board which might work better. A piggyback driver running NarsilM or Anduril could work, but, (big but) you can't run an XHP70 or any 6V LED on the one cell. Maybe a 3V XHP50.2 but LED positioning would have to be worked out, as well as LED height.
TomE, thank you very very much for the detailed photos and the explanations as well! Awesome
That surely is a different driver architecture, but it also seems to show the reliability that Wuben wanted to give to this flashlight! I am no good in electronics, but I noticed the R050 there!
I will check if I can measure the drain, as I am also learning this. But maybe I will try it first in another light with more or less the same specs ( just to check if I know how to do it)!
Hum, about the driver…well, I start to see too many things I don’t know if would be able to do … :person_facepalming:
I thought I’d be able to change the driver only, without piggyback, but that and the LED swap…I may incur into a delicate path for my knowledge.
I need to re-think what I was thinking as this light is “precious” and is serving me well, so I don’t want to ruin it…
Thank you very very much once again for taking the time to post the photos and the explanation! :face_with_monocle:
Hey there. I was wondering what you would expect the benefits of a second 26650 would be. I’m trying to decide between this and the Wuben A21, and if a second battery option would equate to significantly better runtimes it might be enough to tip the scales. If it increases brightness but doesn’t significantly increase runtime then it probably wouldn’t be worth it.
The 2 x 26650 will of course give you more runtime, even on high! I see me charging it less since I started using the flashlight with the 2 cells.
I am not sure it if will give higher output and I don’t have and exact way to measure it. But runtime will be longer with it
I don’t have that flashlight, maybe some of our other members has and can help with that
Sounds like this might be the direction I should go. I’m getting a little sidetracked by Olight having a Xmas sale tomorrow, but the T70 seems like the direction to go if I want brightness AND runtime. How did you get your extension tube? I don’t see it for sale anywhere. How much did it cost?
This is, at least, a good flaslight if you want some “sustainable lumens” for a while. Currently I am using it with the “stepless dimming” mode activated do that I can turn it ON/OFF with just one click.
About the tube + extra cell , it was sent to me by Jelina from Wuben for review purposes. Maybe you can contact her through the user profile: http://budgetlightforum.com/user/20745
Check if they still have those tubes. BG and GB don’t seem to have it and AliExpress doesn’t have it too as far as I know!
About the UI…Olight will win over this, I am sure! Still the T70 is a great light that I can rely on if I go to the “wilderness” :smiling_imp:
You won’t regret getting this light
Super reliable, one of my most gorgeous lights due to the camo pattern !!
I also became to like using the light in the ramping mode, with a settled output for ON/OFF use. The ramping is not so fast as Anduril, so it may be a bit troublesome using it but with just a defined output it will be a nice light!
I’ve had my eye on this one for a while now. When I found out about the Fasttech promo my eyes lit up, I got amped-up, and did the triple click turbo on that order button!
It’s going to feel like forever and a month, waiting for it to arrive.
When I ordered the T70, Fastech showed it was in stock and would be shipped out in three days. Three days comes and goes, and then it said it would ship out in six days. Six more days come and go, and it said out of stock. My order did not get shipped out.
It still has not shipped out even though it shows in stock now, and being packaged for shipment, for the past five days. How long does it take to put in a box and ship out, apparently more than five days.
I decided to wait it out, because it was an excellent price. I have been in contact with them, and all I hear is sorry, sorry, please be patient. I will probably never purchase anything from Fastech again.
Hum, yeah, the ramping is not something like what we have on the Emisar or FWxA lights! Also, it is not what we have/had on Sofirn lights.
It is slower and is only Up or Down, not allowing reversing the way we’re ramping.
I learned to use it more on ramping, though, using it as a “single mode” flashlight. I have it configured that way, and when I want to make it act faster, the triple click from on to jump to stepped levels is helpful. Then, I normally switch back to ramping, for the “single mode” use.
That was also what I did with my Sofirn SP32A (before the driver go “puff”), I was using it as my “indoor” flashlight, just on turn On/Off way.
I do hope you enjoy the flashlight though, as it will stand out in the collection for sure, both for the looks and the reliability
I got mine yesterday. (Prize from the Old Lumens contest.) Black with the extension tube and 2 cells included.
I like it. Wuben always seems to space the levels out nicely. The machining, etc. is superb. It’s bright. The ramping is okay, just different from what many others do. It would be better if an “UP” ramp could be interrupted and the ramp direction switched to “down”. It is a nice size in the hand. The 26mm diameter cell has always been attractive to me for that. Until the last few years though it was not easy to get a “good” one with high mAh capacity.
I guess you’re spot on about this light! It has great quality and reliability too
The ramping…could be more friendly as you say, but if you want to use it as a “single mode” flashlight it works great!!
And with ~10000mAh to use (when using 2 cells), it becomes a light to carry on a trip to the mountain side, to camp, to fish,…
About a year ago I took it to a trip to the mountains in jeeps, with friends, and when the bar light of the leading jeep failed, it was the T70 that created a spotlight to guide us through the dark!
I’m glad you also like it and enjoy it because you deserve :+1:
