groupbuy: Astrolux S43/S43S copper with LH351D high CRI
Hello my dear friends!
Today i present my latest groupbuy!
feel free to ask questions or post your opinion below
for all 4 versions you can use my
Code: MC8A6 to receive 20% OFF
all 4 share the same base features – please use my shoplinks for detailed Info!
Product name: Astrolux® S43(S Copper) New LED Strong Light EDC Flashlight
Brand: Astrolux
Model: S43S
Emitter Type: NEW: 4x LH351D
4x XP-L HI
Driver: NarsilM V1.3
Output: LH351D: 3500lm continuous, 4000lm max with high CRI95
XP-L HI: 3600lm continuous, 4600lm max
Light Temperature: 3 options:
LH351D 5000K neutral white
XP-L HI 5000K neutral white
XP-L HI 6500K cool White
Range: 184 Meters
Mode: Including Default UI and Alternative UI.
Detailed operation instructions, please see the following 2 instructions.
Lumens: 0%-100% Lumen
Battery Configurations: 1x 18650 or 18350 Battery (18650 included)
Working Voltage: 2.8v-4.25v
Material: Aerospace grade aluminium alloy
Waterproof: IPX6 waterproof
Color: Black
Weight: 60g without battery
Size: 88.7mmx 27mm (Lengthx Diameter)
Feature Functions: – 4 LED Bulbs
– Battcheck mode displays battery voltage
– Lockout lockoff function
– Charging Indicator
– USB Rechargeable
– Removeable tactical safety harmmer
Astrolux® S43 $28.46
4x LH351D New LED High CRI 95 Strong Light 18350 18650 EDC Flashlight
Astrolux® S43 $32.96
4x LH351D New LED High CRI 95 EDC Flashlight
+ 1Pc 30Q Power 18650 Battery
Astrolux® S43S Copper $32.96
Astrolux® S43S Copper $37.46
reserved
Does the LH351D really make it to 95 CRI?
Ordered one
Not that I know of, might be a certain bin for it though
Samsung says "90+"
https://www.samsung.com/led/lighting/high-power-leds/3535-leds/lh351d/
How much longer can the S43S sustain turbo compared to the S43?
Is there solved completely inefficient power model as on version with Nichia 219C?
Or old well known but awfull FET+1 scheme like maukka tested Astrolux S43S review (4x 219C, 18350/18650)
Has anyone got a beamshot photo of the LH351D version? Is it more throwy than the Nichia version?
Do these lights have low voltage cutoff? Planning on using some unprotected cells with them, assuming they do, or they’d at least blink to let the user know. Thanks.
I’m sure it isn’t. Not that the nichia is throwy to begin with but the LH351D has the largest die area of any 3535 emitter out there. It’s gonna be more flood then any other emitters offered in the S43 series.
Do you know why your code is giving me 20% ; from canada .
yes
the groupbuy is over... :(
