As EasyB says, the newer linear driver which can now be ordered with Biscotti is the ∅17mm SST-40 5A. The ∅20mm 6A and ∅22mm 6A SST-40 drivers will also be available with Biscotti, as Simon said here.
On the topic of raising the maximum output current for these drivers, and answering Sirstinky's question, since the drivers are regulated it must be noted that each driver mode implies a proportional voltage drop at the current sense resistor. Given that the ∅17mm 5A driver uses a 10 mΩ sense resistor (along with the ∅20 and ∅22 mm versions), we can calculate the driver's sense voltage(s). For the highest mode, 5 A, V = I × R = 5 A × 10 mΩ = 50 mV. So, the driver allows up to 50 mV of drop in its sense resistor (not verified by me yet), with proportionally less sense voltage in the lower modes.
I made a search in AliExpress for 1210 “sense” resistors of adequately low value, found 3 advertisements worth mentioning. From cheapest to most expensive as I see them, including shipping and handling:
All of them sell values which matter here. A few examples for 50 mV sense voltage:
A 56 mΩ (R033) resistor adds I = 50 mV / 56 mΩ = 0.893 A (0.892̅8̅5̅7̅1̅4̅).
A 33 mΩ (R033) resistor adds I = 50 mV / 33 mΩ = 1.515 A (1.5̅1̅).
A 30 mΩ (R030) resistor adds I = 50 mV / 30 mΩ = 1.667 A (1.6̅).
A 22 mΩ (R022) resistor adds I = 50 mV / 22 mΩ = 2.273 A (2.2̅7̅).
A 20 mΩ (R020) resistor adds I = 50 mV / 20 mΩ = 2.5 A.
All of them can be combined in parallel. And bear in mind that while this increases the maximum possible output, remember that you will only reach it for as long as there's enough voltage difference headroom between the input from the loaded battery and the emitter Vf at that current, after spring and contact losses and etc. You also may not want to raise the maximum current excessively, as it will affect the remaining modes proportionally. After adding an R020 in parallel with the stock R010, for example, the 30% mode will raise to 2.25 A and 3% mode to 0.225 A.
At last I'll just add that, if you remove the onboard negative thermal coefficient resistor used for temperature control, please make sure you reinforce driver cooling as much as possible, and take proper care.
If someone else have received that new biscotti driver. I have current 17mm version with 4 modes and will be interesting if we can just upgrade it the firmware. I supposed that biscotti firmware is ported to another micro different from Attiny series.
Ok I will made some close up pictures with my Andonstar micro and will post them soon. But I think marks on micro and transistors was laser trimmed. Also from Convoy store listing we can see markings of transistors but the MCU is it without it. Also it have 10 pins compared to 8 pins of Attiny so the Biscotti firmware is most likely ported to another MCU family.
Biscotti is distributed under GPLv3 license.
This license means that you Simon (as the seller of drivers) are required by law to distribute the sources. Not just the generic biscotti that was the base for you but the exact one that you distribute on your drivers, complete with any changes that were done to port it to that MCU. That is - unless you receive a more free license from ToyKeeper.
Yeah, that driver manufacturer sounds a bit… interesting. Knowing the model of an MCU doesn’t sound particularly secret given every other driver I’ve seen has all the markings on them.
Usually it's easy to trace where VCC and Ground get connected to the MCU, and that, along with the package and pins, can narrow down the choices of MCU's. PIC's are usually one config for VCC/Grnd, different from Atmel's.
It's kind of despicable what's going on here - open source firmware running on proprietary hardware, where secrecy seems to be the goal. Do they really think they have something so special and unique, they want to copy protect the design but use someones else's firmware they don't have to pay for? Of course we know there's lots of stolen ideas/designs there - it's the wild wild west, but a simple flashlight driver? I dunno...
As I understand it, the Chinese electronics market is incredibly competitive, with so many firms making parts for each other and then selling them at a premium to one or discounting the others. Some manufacturers sell to only certain companies with the promise their identity is kept secret, otherwise other competitors might get wise and copy the design or undercut them on pricing. If you’ve ever opened up products from different manufacturers, you get an idea of this. An LG vs Memorex versus a Coby portable DVD player,for example. The LG will have better quality control, probably some better design (more SMD vs through hole) with better parts. The other brands might have cheaper plastics, more theough hole with bodging and solder flux, etc. However, the same company might supply ICs or parts to all the big OEMs. In China everything is counterfeited or copied (even flashlights folks).
