M4D M4X deals - Astrolux WP1 and WP2 LEP
will post asap ;)
Hello my dear friends!
Today i present my latest groupbuy!
for all 4 versions you can use my
Code: MC8A6 to receive 25% OFF
all 4 share the same base features – please use my shoplinks for detailed Info!
Product name: Astrolux® S43(S Copper) New LED Strong Light EDC Flashlight
Brand: Astrolux
Model: S43S
Emitter Type: NEW: 4x LH351D
4x XP-L HI
Driver: NarsilM V1.3
Output: LH351D: 3500lm continuous, 4000lm max with high CRI95
XP-L HI: 3600lm continuous, 4600lm max
Light Temperature: 3 options:
LH351D 5000K neutral white
XP-L HI 5000K neutral white
XP-L HI 6500K cool White
Range: 184 Meters
Mode: Including Default UI and Alternative UI.
Detailed operation instructions, please see the following 2 instructions.
Lumens: 0%-100% Lumen
Battery Configurations: 1x 18650 or 18350 Battery (18650 included)
Working Voltage: 2.8v-4.25v
Material: Aerospace grade aluminium alloy
Waterproof: IPX6 waterproof
Color: Black
Weight: 60g without battery
Size: 88.7mmx 27mm (Lengthx Diameter)
Feature Functions: – 4 LED Bulbs
– Battcheck mode displays battery voltage
– Lockout lockoff function
– Charging Indicator
– USB Rechargeable
– Removeable tactical safety harmmer
Astrolux® S43 $28.46
4x LH351D New LED High CRI 95 Strong Light 18350 18650 EDC Flashlight
Astrolux® S43 $32.96
4x LH351D New LED High CRI 95 EDC Flashlight
+ 1Pc 30Q Power 18650 Battery
Astrolux® S43S Copper $32.96
Astrolux® S43S Copper $37.46
Those are great prices for the S43 and S43S's.
I finished the mod of the first SC31B. It's now running Anduril with a FET+1, XPL HI V4 3C - nice output at about 1400 lumens, some decent throw at 19 kcd. Used a 5.6K ohm resistor on the switch LED's and Anduril supports two output levels that seem to work quite well.
NEWs ! M4DM4X.deals is ONLINE!
Read the introduction post and join a new community!
(well - we are the same, but we have a new place ;) )
Honestly, I liked being able to sort through things by manufacturer, type, etc. It made it really easy to find things for myself, family and friends. The only thing I didn’t like on the old setup was the expired codes. Just my .02.
Agreed
we work on those filter options...
have you tried the full text search?
i know many deals need to be added - but maybe one of you wan to ad his last used or prefered deal?
a goal is to have deals, that show what the community approves and votes for
Astrolux MF01S Mini seems to have disappeared?
The light? You might be using the wrong name, remove the S.
MF01 mini.
Yes you are right. I didn’t even realise the mini didn’t have the “S” suffix. :slight_smile:
Full text search? I’ll have to play around with it, but what I’m getting at is take someone that maybe isn’t an enthusiast, or has friends/family they are shopping for gifts, and they know they want a headlamp but they don’t know an exact model. It’s nice to be able to sort available deals by headlamps and see what’s there in a concise manner.
I like the new site and I’m not trying to be negative because I really do dig the idea of letting the community play a big part, I just don’t want you to lose the functionality found in the lists you’ve previously used.
Maybe just searching “headlamp” will narrow things down enough that it doesn’t matter. You do a great service to the community and I do appreciate it. I’ve purchased a decent amount through you over the years. Keep up the good work!
Edit: Just tried text search and it worked pretty good. I used the example above and typed in headlamp and two came up.
Hi Martin! When is the XT45 GB coming up?
Hello, the code M4BG doesn’t work, do you have a new one?
I want to buy a Convoy S2+ and Nitecore Tiki.
Thanks.
@Wrathbringer27
XT45 GB start in a few days (i wait for a price guesstimate)
@woper
try M4X2020 instead of M4BG
(and send me a request if it does not: martin@m4dm4x.com)
the EDC18 short tube is available!
i listed it here: deals.m4dm4x.com
and the EDC18 with code is also there in case you need another one ;) )
please note:
due to corona shipping costs exploded...
neal has no code for the cheap tube so you can maybe add something else you want and use a code there to avoid shipping fee
cya
Martin
What is the XT45?
Amutorch XT45
@Martin Awesome! Thank you!
What is the new code for Astrolux ft03 with SST-40?
I got nothing but expired coupon codes, even at the M4D M4X site.
