Not my mod. A FW4A mule with 12 Samsung LEDs (LH351D?):
Wow, that is crazy, 10,000 lumens!
I wonder how long you can hold it for on max before your hand melds with the aluminium!
Is there an 18350 cell that can put out that much current?
samsung q30 can put out 20amps
sony vts can put out 30amps
irun samsungs in my fw3 and fw1
ive also got 6 sony vts that are great, but nothing that warrents me putting them in
You need to look at the listing carefully and read what I wrote carefully - 18350 cell
ah its to early and im only on my 3rd coffee
ok well i use a efest 18350 700mAh battery in one of my convoy s2 , it got full brightness draws about 5 amps, i read its max output is 10 amp
this should be good for about a very very short amount of time on full power
If that’s the case I can’t ever see that light reaching 10,000 lm with a short battery.
10,000 lm / 12 leds = 833 lumens per led
According to Texas_Ace’s tests you need more than 1.5amps to reach 800 lumens.
12 leds * 1.5amps = 18 amps
So something capable of 20 amps (the 18650’s forsh mentioned) might see the specified output but not happening with short cells
18350 battery 15A 1200mAh Flat Top Li-ion ORBTRONIC 15amp for 5 seconds on and 30 seconds off,
yeah like you say pal, 18350 is proberly not possible drawing 20 amps, and really who wants to have a torch that can go full power for 1 seconds, unless your making some kind of strobe that blinks twice a minuite!
Ok, that was really weird……… I was looking at your photo forsch and rolling my fw3a (normal) between my two hands thinking, suddenly it came on and off a few times, the started doing alsorts of weird flashes! It wouldn’t switch off and i had to unscrew the head to stop it………
I have no idea why - maybe it was jealous!
Maybe some kind of cpu freeze or something
The plastic ring is something from b&q type shop for 10 pence (cent)
Water pipe washer , 22mm 24mm outside , I had to sand the inside a bit
But it works so well
It maybe needs cleaning a bit and the colour isn’t great , I’d like blue or green or something
But it works for now
I have a Keepower 1200mAh 18350 that I managed to suck 14A from. So I guess it’s possible with an even better battery. For about 7 seconds until it’s empty
See forsh’s post #1279 (5 seconds on 30 seconds off).
Also I think 20 amps is the minimum requirement to reach 10,000 lumens.
I’ve just jumped on this because that guy must be measuring in Chinese lumens. Theoretically plausible but technologically not possible.
chinese lumens are the best lumens, i had a torch from wish, that had 90000 lumens! it was super bright and only drawing 5amps
im not sure how they measure the lumens, maybe look at the light and say, yeah that about a million lumens!
Got a 2nd FW3A from a generous BLF member here. Previous owner had tried to customize the body but ended up hitting a dead end. Mainly the center body had been stripped of anno & had an uneven finish. I reworked it with various grades of micromesh from 1500 up to 12000. Now it’s more of a satin polished finish. I originally planned to do a twisted scoring, but I’ve found the aluminum is rather soft and wouldn’t likely hold up to an even scoring. Later on, I may give it a go with a Dremel. I’m tempted to try a finish like I did on this vintage Pilot mechanical pencil:
(original body was a smooth satin finish metal alloy)
Installed a GITD optic surround, a lanyard ring, and an o-ring for added grip. The lanyard ring doesn’t anchor down, spinning freely. Tried using a few different o-rings, but it doesn’t work (they get squished out). Looks like a special washer may be called for. Some photos, with the first two showing this FW3A next to my first one.
FWIW, no beam shots but FW3A #1 is Cree XP-L HI 3D, #2 is Nichia 4000k 219C.
Would soda blasting take the ano off ?
Probably, but I don’t have the equipment or space to do that. I am going to try a few powdered abrasives hand scrubbed.
I’ve got a soda blaster at work , maybe I’ll try it later today , I quite like a alu finnish
Draino and hot water will remove the ano in under a minute
