The driver:
That’s pretty much it.
The driver:
It’s a knockoff of the Pak Lite, which has been around for 20+ years. It’s expensive but indestructible, with a 10 year warranty.
New UV light with dual green buttons. Design is not perfect but at least it is quite original.
BOMB. LOL.
Coming from Maxtoch is probably a well built (like a bomb) light!
They have some interesting models (most of them on the throwy side), so this may be one of those too!
Biggest problem with their lights (as with some Amutorch/Shadow lights) is the UI (normally with memory, without ML levels, and with longer press for OFF).
Despite this, their lights seem pretty reliable!
I got a few Maxtochs, worked with Amanda in the past. Their anodizing is 2nd to none. They specialized in hunting and searchlights - mil and services.
This one is more SP36 size with the 3 cells, not 4.
Bomb F1... Perfect for a grenade pouch, as I've used for Q8's!
14500 OR AA zoomie on sale for 19.95 (discount after you add to cart). No idea if it’s any good.
https://www.ledlenserusa.com/collections/sports-activities/products/mh5-1
Interesting light on aliexpress…
XHP70 LED Hardlight Flashlight longrange rechargeable portable aluminum flashlight multi-function hunting outdoor use 26650
US $59.82
118mm length
118x39mm
XHP70
Large Brass switch
1 click on
From on clicks thru L-M-H
Hidden Turbo & blinkies - Double click
Electronic lockout - 3 clicks
Expensive, but I thought it looked kinda slick. Same length as TC20 with a thinner head diameter.
https://www.aliexpress.com/item/32980053768.html?spm=a2g0o.detail.1000023.14.13174a13tkFvaP
Nitecore has similar stuff based around their proprietary 21700, with magnetic attachments:
I like it when they give you a choice of XHP70 and CREE XHP70, hhmmm.
What about these:
What is a P90? And what is a XHP90?
The first one above can do 3500 meters, not bad for a $43, 32 mm head diameter light!
The xhp90 is not from cree, it’s a smaller unknown company that makes a 4 die led on a 9mm x 9mm base. I hear they can’t take much amperage. Maybe 5 to 8 amp.
Nice find!
That 1st one is similar to the one I posted, interesting too with the added display screen feature.
It appears to have the exact same UI with hidden Turbo/Strobe/SOS.
It’s also listed on aliexperess…
P70, P80, P90…
Anxiously awaiting the release of the P100!
Having a P100 bead with 10 gears in a copper (yellow gold?) host is my dream!
Comcrosfly Triple P9
LED Flashlight USB Rechargeable Super Bright Torch Light over 3000 High Lumens, 5 Modes, IPX7 Waterproof-Best Camping, Outdoor, Emergency, EDC Flash light by Comcrosfly 4.7 out of 5 stars 4 ratings 7 answered questions
Price: $35.99 Prime FREE Delivery & FREE Returns
- Light Source: Osram P9 10W LED * 3
- Power Source: Power 26650 Battery * 1
- Maximum Size: 41mm * 103mm
Ultra Bright-High Lumen Flashlight
The rechargeable flashlight uses the OSRAM P9 LED, 3300 lumens, which is much brighter than the other general one.
It's a cheap Amutorch X9, but cheap not just by the price. If you look close at the main pic, it actually has rubbed off anodizing. Weird they'd use a marked up piece for their pics, or maybe the anodizing is so weak, they couldn't find a good sample. It's a little bigger than an X9 and uses optics, not a reflector.
The video for this light shows a SHREPA brand light, anyone know of that brand?
