The 4800mah one is strange one. Some people measure 3700-3800mah, while others measure 4800-5000mah. You can read about it starting here.
BTW, you may not want to drive the C8F to the maximum simply because it builds heat quicker and gives you less turbo runtime. I think you’d be okay using a high capacity battery so as to limit turbo output. If you really want to max it out, try a high drain.
The cells under the wrapper are local chinese brands and usually kept secret.
Probably the highest quality, highest performing cells are the ones from LG, Panasonic/Sanyo, Sony/Murata, Samsung and Molicel.
You’d be better off with the Sofirn 4000mAh 21700 for the Sofirn lights.
The real lumen rating of the Sofirn’s are
C8G - 1700
C8F - 2850 to 2950
The C8F draws up to 10A on Turbo. The EC01 draws up to 15A so I have no idea what the Sofirn 21700 can achieve as no one has reported tests on more demanding lights.
I’d recommend something like the Samsung 40T for best performance of the EC01.
I'm getting an internal resistance reading of 75 mR on a Sofirn button top 18650. That seems pretty high. Is it because it's a button top or because of the cell itself? The cell came with a Sofirn SP31 V2. Thanks in advance.
I’ve seen button tops in general really mess up charger measuring devices. The results would be all over the place even exceeding the max resistance of the display. I removed the button top and added a solder blob and that fixed it (30Q). Other button tops would be fine and show what they should. So it could be the button top. It depends on how it was attached, the amount of power used and the pulse time to weld it together.
You can’t trust the resistance reading then, most chargers aren’t an accurate measurement.
I have the same charger and can get 125 and others 35 using the same battery.
Button tops also raise the resistance, some more than others. Last year I purchased 120pcs Sofirn 18650’s to find the buttons could easily flick off with a knife. Very poor soldering job. The batteries are almost as good as a Sanyo NCR18650GA with the button removed.
They are a rewrapped cell because Sofirn is not a battery manufacturer. This does not mean it’s bad, though. It comes from a chinese battery manufacturer and generally speaking their chemical mixes tend to be slightly not as good as a company like Samsung.
The 40T is a top notch cell, but it’s usually more expensive than a chinese battery. The cheapest I’ve seen the 40T is about $7-$8 each plus shipping. If you paid noticable less than that, I would be suspicious if it’s a real 40T.
Can you add a picture of each cell? I didn’t know Sofirn sold a PLB cell. The common PLB cell most are familiar with is the 5750mah. Pictures might help to clear things up.
The Sofirn PLB 5000mah is this one, right?
The High Drain you tested was this one that says 25A on the label?
Even though the older PLB 5750mah (Shockli 5500mah, etc…) was better than this new one (higher continous amps 20 vs 10-15, plus higher capacity) this newer 5000mah is still beating the cells Sofirn uses in their HD version? Man, that’s high praise to PLB. I wish they hadn’t discontinued the older, better cell.
I was rather disappointed the older cell had been discontinued as I had placed a bulk order from my supplier. I had to then change to these PLB 5000mAh but I’m not disappointed.
