More like is the reflector factory open yet so that lumintop can get the parts to build lights lol.
Last I heard they were still on lockdown but that was a week ago.
I inquired for a friend, to get a code and he said they were shipping next monday.
Which was actually last Monday. SO theoretically yesâŚ.
Right on, maybe Iâll get my tracking numbers soon
Itâs been 10 days and my light hasnât moved from Hong Kong. How long is the wait time for it to ship out of Hong Kong?
It is very slow right now, there are very few flights due to the lock down right now so packages go out as space allows. From what I have seen this is adding a few weeks to the shipping process internationally, although larger packages will be delayed more then smaller ones.
I have a few things on order as well and they are also held up waiting for shipment out of the country.
Anyone have any recent data points they can provide, for delivery times from Neal to the US? Still patiently waiting on my GT90!
Not for this light but
1) Ordered Mar 16, 2020 - Delivered Mar 26, 2020
2) Ordered April 09, 2020 - Arrive at international airport to abroad-HONGKONG - CHINA - April 13, 2020
There are very few international flights right now due to the virus. This is greatly slowing shipping to the point a lot of companies are just shipping by boat.
I have several orders from overseas that are held up waiting for transport right now, some going on close to a month so far.
Nothing we can do but wait.
Finally got my GT90 flashlight, but it doesnât work. Who do I contact to get it replaced? I emailed Neal but no response. Anywhere I can send the light to be fixed?
It doesnât work at all? That is very strange. That is very rare to not do anything as they are tested at the factory. Normally it is some small issue that slips by.
The batteries are fully charged to 4.2v? All inserted properly?
Does the switch LED light up?
Batteries are fully charged and inserted correctly. Green light doesnât turn on
Ok, the switch LED is a very basic function, The most likely reason for it not turning on is that the driver is not getting power.
I would check the ends of the carrier to make sure it has the correct voltage. Then make sure the driver is screwed down properly. Also try pressing the carrier down onto the driver manually without the battery tube installed and see if it makes contact like that and turns the switch LED on.
Oh, also make sure the carrier is installed the correct direction, the âbutton topâ end needs to face the driver.
If none of that works, the next step is to manually apply voltage to it with wires if possible, positive to the center contact and negative to the retaining ring for the driver.
Like this.
You press the carrier manually so it makes contact. Make sure the screws on the carrier are not loose.
Since itâs a 3v led, only one battery is needed.
Yeah the flashlight is dud. I donât know where to send it to get repaired or replaced. Still waiting for response from Neal
I tried the carriers from the GT70 with the greens cells, the led switch turns on , but the flashlight wonât turn on
Uh oh
That is really strange that not even the switch LED will turn on. Something would have to be seriously wrong for that to happen and shocked it would of made it threw QC.
I can fix it assuming I can get any needed parts from lumintop, which could be hard right now due to shipping delays from china. I have worked on a few other lights for them over the years.
I actually have a few GT90 conversion kits that I talked them into selling me on the way now. Possible the kit would have the parts needed to fix it.
Neal has been super busy, seems all the factories over there have been pressed into service making masks and other such items and are only able to work on flashlights at night after hours. You can also try contacting Leo@lumintop.com.
If you want to just send it to me to look at, send me a PM and we can go from there.
When did you do that? Before or after you had issues? That would of instantly killed the LED as the GT70 carriers are 12v and the GT90 is 3V.
In this case there is nothing I could do right now as the LED will have to be replaced and hopefully it did not also kill the MCU.
If you used the GT70 carriers on the GT90 you killed the light yourself (Chibim did kill it as well using the wrong carriers)
The voltage of the GT90 is 4,2V (cells parallel) whereas the 70 needs 3S1P (correct me if Iâm wrong)
The GT / GT70 is 4S (so 16.8V fully charged).
