The switch has very nice action, does not require excessive force.
The size is small, and the weight is low, 69 grams w 16340.
The ramping and output bear improvement because to ramp up it is almost not noticeable as the brightness changes, and the max output is just 75 lumens (no difference on LiIon vs CR123). I like the lowest mode of 0.4 lumens, much better than the supposed 5 lumen spec, for me.
the light has a very nice scalloped bezel. The beam is OK, nothing too impressive, with a shadow around the fuzzy corona.
tritiliscious
driver, Version 10 (no strobe, no sos, no lockout)
GDP or Q5?
selbuilts pic for LED reference, pic is a link:
note O ring on large diameter portion of piston
compared to O ring on Driver 11.2 version
These require much higher pressure to operate.
contemplating my navel
and a driver swap to 11.2
and a 3000k 219b swap ā¦
need liquid courageā¦
I prefer that the original V10 driver has no lockout from press hold form off
but the V11.2 driver has much better ramping rate and output rangeā¦ not sure what part of that is driver and what part is the LEDā¦
EX10 Ti GDP
w 16340 Lumintop USB rechargeable Protected ICR. 68 grams
min 0.4 lm
max 75 lm (70 lm w cr123)
EX11.2 w XPG and black pocket clip
w 16340 Lumintop USB rechargeable Protected ICR, 61 grams
min 0.1 lm
max 350 lm (150 lm w cr123)
There has never been a factory titanium EX10 (Iām 99% sure on this). I thought yours was a KUKU creation but I just remembered it was sold by Unique Titanium as a small custom run. The maker was RUSSTANG from CPF.
At that time, Nitecore was still a small company and only produced AL lights. If I remember correctly, they had the Defender, the EZ serie, the EX10 and D10, all in AL.
Keep it, take good care of it, I think only about 20 were made.
You bring me back souvenirs from CPF 2007-2008, thanks for the memory !
Iām quite certain this is not the original piston. The batch sold by Russtang all had that defect. Yours came from Steve Ku or Jeff Hanko (if I remember correctly that was 10-11 years ago !). He offered slotted piston, also 4sevens (again, I can be wrong with this one) had some custom batch offered in small amount where you could buy only a slotted piston.
Also, at that time, CPF user Precision Work offered a service where he would mill a slot to existing piston. Later, I think Nitecore came out stock with slotted piston but only on a special D10 edition. If you want to push your investigation, I think a good start would be to determine if your piston is TI or SS.
So, overall, you are even luckier to have a so nice specimen !
I also saw a post by russtang stating he had slotted pistons and would install the trit, sold though his store, Unique Titanium. I speculate he had more pistons slotted after the first ones came out off center.
not sure how to tell Ti from SSā¦ curiousā¦
I have EX11.2 and EX10 Ti
the tube in the Ti is 1 gram heavierā¦ the tubes are not identical, the heavier one has a trit. Neither tube is magnetic. The EX11.2 tube is much shinierā¦ guessing its SS, but no clue reallyā¦
new questions
where to get a brass plated spring, it is softer than the silver spring, that I find too stiff.
and how to I spin the pill out of the EX11.2?
here is a how to video, but that D10 pill is not quite the same
The piston in my EX11.2 was aluminium.
The bezel too.
I can tell ti from ss or alu by the feel, ti has that slightly grippy feel to it.
If you have a couple 9v batteries or such, some baking soda, some wire and a cottonbud you can test anodize a small area to see if it is titanium.
Colour will change on contact.
The pill on the EX11.2 slides out the front.
I used to use AW 16340 cells as they were a bit shorter and worked well with the PD, longer cells can be difficult.
Yeah it comes out the front and is much easier to do simple emitter swaps than the Nitecore D-10's.
So the ex-10 ti is a golden dragon emitter ?
I wonder if that the offset slot isn't a mistake.Maybe it was just an easier way to cut a slot .I'm guessing someone with enough talent to create the ti lights isn't going to screw up repeatedly like that .
Nice lights that had all of my attention right before I joined BLF. All my lurking was in high end customs on CPF and an intense interest in Nitecore D-10's and ex-10's.
Didn't realize there were only 20 of these made .Glad to see it go to someone who will appreciate it .
I came here to see your pics and post on the Ti EX10. Seems like you are teaching me a few things about this light. I did not realize this was a light created by Russtang. From the pics provided by the seller, I thought it was a one-off prototype made for David Chow of 4Sevens.
Both the D10 and EX10 are reprogrammable. A couple of CPF members were doing it, but quit.
CPF members ādevā and ānightshadeā.
My last queries of them both revealed they were not doing the mods anymore. The nightshade D10 I lost had a copper heatsink, custom springs and a new ATtiny13V with slowed ramping feature. Wished I would have bought another but it wasnāt cheap.
Old post I saved:
Thatās how it all started.
Also, somewhere I have saved the original EX10 circuit schematic.
IIRC, that should be archived on CPF too, if it wasnāt lost to their almost endless crashes.
Since you guys are taking about the drivers, is there a resource for replacement drivers for the D10 R2? I have found nothing, Nitecore canāt help either. I had an Energizer leak in mine, with the head downwardsā¦ I cleaned it but the pcb traces are now exposed since the acid ate the board coating. I donāt trust the components to last. I have to somehow re-surface and nickel plate the piston inside alsoā¦ Itās badā¦ but I love this light too much to abandon it. This D10 was my red pill. I was thinking of making my own driver. Thanks for any help!
