[♛ Group Buy] Convoy M21C and M26C XHP70.2 Thrower 21700 Flashlight Group Buy (3 colors) - Deal is ALIVE NOW!
Thanks for the clarification.
Now wondering how it compares to the M3. Driver and UI description let me think it’s the same driver… and i could not get used to it because of the long press to change mode which made cycling through modes slow and fastidious. I guess i got spoiled or touched by Andùril. Do you know if Simon updated the driver?
Interested
Will M26C fit 21700?
Probably not, M26C is 8mm shorter than M21C. Moreover, M26C only allow unprotected (short) battery type.
No. But if you unscrew the tube from head 3mm or more it work, no waterproof.
Tested on my M26C sst40 and Sofirn 21700/4000 from C8F (flattop unprotected).
I’m down if I can do Bossetti driver (is that what it is called?)
You probably mean Biscotti as available on he S2+.
Not sure it can handle a XHP70.2.
Interested in one.
Biscotti driver for XHP70.2 will be available soon according maker and also OP reflector
Yup, i heard that news too.
Is it possible to disable memory mode? If so I’m in for one.
Order placed.
Thx for the help.
WOW!
So, I will wait for the M26C/XHP70 with Biscuit driver!
ah yes, the famous biscuit driver
Best with coffee.
Sample has arrived few hours ago.
Show us!
Coming coming!
Can someone confirm if the M21C and M26C are the same light just threaded for different diameter battery tube? Or are there differences in head/reflector shape/size? If not, all things being equal, the performance between the two should be the same?
I do not have M26C 70.2 with me but from my observations:
  1. Driver is identical.
  2. M21C has much more radiating fins than M26C.
  3. Base on my memory of my old XINTD/ convoy x3, M21C might have deeper reflector.
  4. Highly doubt the host(shell) parts are interchangeable... The most bezel if lucky.
Thus, there might be some marginal differences in terms of performance.
M21C and M26C have exactly the same reflectors
