I guess I really need to try the 2 fish. I have been using the 2nd one shown for a couple years. I love the fact that some light require the tail cap be screwed on after it's in the mount so there is absolutely no way the light is going to fall out no matter how stupid you get on your bike.
The ones you have are good ones, E, just not as versatile as the TwoFish. If you are going to keep the light and mount on, and if you have smaller diameter bars, those work great and are very solid mounts. But they won't fit most newer road or mountain bikes, which have larger diameter bars. I have the wing style flat top bars on my roadie, and no way is that mount going to work. Same with the ones cehoward has - work great on older bars. My steel Lemond will accept both of these types and I'll use them on it.
By the way, I got 4 of the TwoFakes from DX and they work good, but not quite as good as the original. For some reason, the rubber on the DX ones is a little too slick, so you have to rough it up a bit with some sandpaper to make it stick better.
I also have 3 on the way from CNQG, which has them slightly cheaper than DX, and ship time is better: http://www.cnqualitygoods.com/goods.php?id=1111
I feel that the TwoFish takes up more of the road shock than a firm mount . This may be better for the flashlight .
Or not .
As long as you tape wrap your batteries to prevent battery rattle or movement and therefore mode switching , you shouldn't have a problem .
It works great , it's easy to adjust the snugness of the batteries and ...
It's Budget .
Welcome to BLF, picklebp!
You said tape up your batteries..??
I've always run some shiney advertisment paper in with my batteries ..usually it's madse out of some junk mail that has high sheen and a little bit or thickness and i cut a half round or just a slice and run it down next to the cell to take up extra space ...do you really tape up your batteries ?..masking tape ?
Thanks for all the comments guys I just was surprised how good a 2$ twofish was ..I'm not saying it is the best thing made but it seems like an easy one that everyone ought to have ...they are probably less than 2$ too if you search and search :P
E1320 I agree I liked the fact that once the light was tighted down on the second one ..there weren't no way the light was coming out unless you had an axe .
Between rides i know you like the open top ones as well My question was ...they swivel ??..Ok swivelling isn't a bad thing if it works ..are they that tight ?.
The reason for the thread was to say ...Wow two fish 2bux whodathunkit
thanks for the imput
Yes, the swivel ones are good. The ones that don't are too cheap.
Those 2 c8's look cool
I run the open clamp thingy exclusively for over a year now on my 2 bikes, they are great for 23.5-25.4 mm flashlights like the C8,P60 lights, Hugsby P31(with clip) and most of the time the Fenix E21 which has a 25.4 mm head that fits perfectly. I also own 2 two-fish that collect dust in my flashlight accessories box. I like the ultra-fast mount and demount speed on the open clamp thingies.
Thanks for the tip about the paper inside the tube.
I've been using the DX two fish version for a while, but dislike mounting and dismounting each time. I will get the clamp type next. If you get the 2-pack it's $0.50 cheaper: http://www.dealextreme.com/p/universal-adjustable-bicycle-mount-for-flashlights-23mm-diameter-2-pack-56320
Does anyone know of a cheap or DIY seatstay mount to mount a rear light like this: http://www.dealextreme.com/p/3-led-safety-bike-tail-light-2xaaa-2975?item=30
Ok between rides here's your shot ..are you suggesting the manafont ones that swivel over the DX ones that don't ?
Or am I missing something ?
i like the thought of easy removal since my lights are worth more than my bike .
My favorite makeshift bike mount is..two clamps rubberbanded together .,,best part is the ability to just open the clamp and pull the light .
i don't know vectrex ....I have to go with a member who has a picture and name that says I BIKE..
it looks like you're both liking the same mount .. one swivels the other doesn't
This morning, I had a little slippage from the two fish knock off. It was raining, and I had a big light in there too. On the other hand, the M10 right beside the big light, didn't budge.. When I state slippage, I mean the mount is tilting forward, as in rolling on the bar.
Recently I have received the second (by reading some E's posts giving positive feedback :) ), now I have to wait until I go out at night and try them.
My experience with the "TwoFish", is that is really versatile, but it shakes a lot, and more with heavier flashlights. Sometimes oncoming drivers flash long lights and I think it's because the shaking of my flashlights points to them while shaking.
They are my choice too for the 18650 lights. However, when we move up to the 26650 lights, the open thingee is straining. That is why I go with the two fish for the bigger dia lights.
See....and i thought this was gonna be an easy one .
I got my 2fish the other day and when I pulled back on the Velcro i realized it was really grabbing onto the light and there was no way it would spin in the mount ,,,the light does have extra groves but No knurling ...I was really impressed ....
maybe we could get this down to only 3 or 4 mounts to recommend
can we agree on the ones that are truly foul. ( ones to avoid ) ??
This is the non-swivel version: http://www.cnqualitygoods.com/goods.php?id=1109
The weakness in this one is at the bottom. The rubber is too flexible and is not strong enough to allow you to tighten up the screw sufficiently.
This is the swivel version: http://www.cnqualitygoods.com/goods.php?id=1116
The plastic used on this mount is heavier grade, which allow you to torque the screw down.
Both of these mounts work, but the second one just worked better in my experience. They are both very cheap and I don't expect they will last that long if used repeatedly, so if you are going to use them, buy several. As cehoward mentions, they don't work with larger diameter (26650) lights. And as I mentioned, they don't attach well to large diameter bars.
Hope that helps.
This being a forum, I don't think we'll ever truly agree on anything...
I did a mini review on this subject a while ago - https://budgetlightforum.com/t/-/7696#comment-151701
Well, I really don't see what can break on the non-swivel version.... the rubber is too soft to break... for me is more likely that the screw rusts through than the plastic failing on me. A friend of mine also uses these and he does 6000 KM on bikes almost every year. The only downside I can think of is the restricted diameter of the flashlights that it can be used with. I do trust the clamps a lot more than the velcro of the 2fish. I will try to post some pics of really heavy duty used clamps on the weekend.
I was looking at my two fish and they have a name in small writing on the side and a patent pending number .. the name is Huntlight .i wonder if mine are better than the average or clone two fish ..???
I think I have the same and I remember finding a Czech company with that name...
Aha, got an answer, I think!!
IMO, the real two fish is better than the clone, no question. But to what degree or how much better?
Example of clones. I have the clone of the Shadow JM05 and JM07. It is known fact that the the originals are better, but are they TWICE as much better as the price dictates?
I just ordered about 5 more two fish clones. The cost me $1.77 each. Whereas, the real two fish cost something like $7 each. The clone is 1/4th the price. Is the real two fish 4 times better?
Dam, I found myself rambling on and on.. Forgive me..
