BOMB. LOL.
Coming from Maxtoch is probably a well built (like a bomb) light!
They have some interesting models (most of them on the throwy side), so this may be one of those too!
Biggest problem with their lights (as with some Amutorch/Shadow lights) is the UI (normally with memory, without ML levels, and with longer press for OFF).
Despite this, their lights seem pretty reliable!
I got a few Maxtochs, worked with Amanda in the past. Their anodizing is 2nd to none. They specialized in hunting and searchlights - mil and services.
This one is more SP36 size with the 3 cells, not 4.
Bomb F1... Perfect for a grenade pouch, as I've used for Q8's!
14500 OR AA zoomie on sale for 19.95 (discount after you add to cart). No idea if it’s any good.
https://www.ledlenserusa.com/collections/sports-activities/products/mh5-1
Interesting light on aliexpress…
XHP70 LED Hardlight Flashlight longrange rechargeable portable aluminum flashlight multi-function hunting outdoor use 26650
US $59.82
118mm length
118x39mm
XHP70
Large Brass switch
1 click on
From on clicks thru L-M-H
Hidden Turbo & blinkies - Double click
Electronic lockout - 3 clicks
Expensive, but I thought it looked kinda slick. Same length as TC20 with a thinner head diameter.
https://www.aliexpress.com/item/32980053768.html?spm=a2g0o.detail.1000023.14.13174a13tkFvaP
Nitecore has similar stuff based around their proprietary 21700, with magnetic attachments:
I like it when they give you a choice of XHP70 and CREE XHP70, hhmmm.
What about these:
What is a P90? And what is a XHP90?
The first one above can do 3500 meters, not bad for a $43, 32 mm head diameter light!
The xhp90 is not from cree, it’s a smaller unknown company that makes a 4 die led on a 9mm x 9mm base. I hear they can’t take much amperage. Maybe 5 to 8 amp.
Nice find!
That 1st one is similar to the one I posted, interesting too with the added display screen feature.
It appears to have the exact same UI with hidden Turbo/Strobe/SOS.
It’s also listed on aliexperess…
P70, P80, P90…
Anxiously awaiting the release of the P100!
Having a P100 bead with 10 gears in a copper (yellow gold?) host is my dream!
Comcrosfly Triple P9
LED Flashlight USB Rechargeable Super Bright Torch Light over 3000 High Lumens, 5 Modes, IPX7 Waterproof-Best Camping, Outdoor, Emergency, EDC Flash light by Comcrosfly 4.7 out of 5 stars 4 ratings 7 answered questions
Price: $35.99 Prime FREE Delivery & FREE Returns
- Light Source: Osram P9 10W LED * 3
- Power Source: Power 26650 Battery * 1
- Maximum Size: 41mm * 103mm
Ultra Bright-High Lumen Flashlight
The rechargeable flashlight uses the OSRAM P9 LED, 3300 lumens, which is much brighter than the other general one.
It's a cheap Amutorch X9, but cheap not just by the price. If you look close at the main pic, it actually has rubbed off anodizing. Weird they'd use a marked up piece for their pics, or maybe the anodizing is so weak, they couldn't find a good sample. It's a little bigger than an X9 and uses optics, not a reflector.
The video for this light shows a SHREPA brand light, anyone know of that brand?
Thanks, I thought it looked familiar but couldn’t place it. Besides the optic vs reflector difference it also has Osram P9’s instead of SST40/XPLHI, I’ve been seeing this P9 in more lights recently, I know nothing about it, I have to read up on it.
Was going back through this thread to catch up and found ^ this post ^
I have this light too, but mine is the Ultrafire UF-Y1 from fasttech…
Got it because of the unique “fine machining” style knurling, was hoping it would be as nice as it looked in the photos and it actually is pretty much, so for that reason I really liked this for a host until I took it apart (it has the same faults as the aliexpress version)
I too planned to swap out the angry blue emitter and wrap the “mini drop-in” to fit better in the head, but it really needs a power boost and elimination of strobe mode.
And I also have that Ultrafire U-F10 mini Zoomie with the (same?) e-switch tail driver, in the thread for that light I remember someone giving it a boost by stacking a resistor on the driver, also vaguely recall some trick to eliminate the strobe mode or make it one mode, I’ll have to read up on that again.
What effect does swapping the resistor on the ledboard from 50 to 220?
Without knowing the details of how the driver works, there seems to be a few generalities to drivers. Like in the picture above, see the big R100 resistor? The large size gives it a higher power/wattage rating so it can handle more heat. The R100 label means it’s 0.100 ohm which means it’s a sense resistor. Manufacturers use these types of resistors to fine tune the max output. The general trick is to reduce the resistance to get more power, but you have to accept you might burn up the driver. You want to go down just a little bit, maybe replace it with a R090 or stack a R600 on top to create 0.090 ohms. Stacking resistors involves tricky math so I usually use a calculator like this. See what the effect is. Brightness may go a little or none at all. If you have a backup driver you keep going lower to find the limits. Maybe 0.75 will make a noticeable increase it output or the driver might burn up. You typically want to take very small steps or find other people who have already experimented on that light and use their recommendations.
Ps, looking at the driver above, unless there are more components on the other side, appears to be a single FET driver and the sense resistor is just to limit output.
To me that resistor just seems to be like current limiting resistor in series of that sot23 device which maybe is transistor.
