I don’t even own this light but your driver is making me want one now! Nice work LoneOceans
I’d be interested in maybe 1 ore more at the right price and also the aux led boards
loneoceans I just wanted to quickly comment and say that your electronics skills are outstanding. Not only are your circuits complex and functional, your board layouts are clean and a pleasure to look at. It’s been a joy following along with the stuff you come up with.
I will be in for 4 but I cant fill in the spread sheet.
I’m in for 2, maybe 3. Absolutely zero color preference, I’d go with
cheap but don’t mind if the community votes to upgrade to a more expensive one, I’ll still be in.
As mentioned by others, your Google sheet document is set to read only so we can’t fill it in.
I think the idea is to comment on the cells, and then loneoceans will go and commit the comments. That keeps us from editing others’ cells. That’s what I did anyway.
I’m in for at least 1. 3A constant current should play very nicely with the copper version
Thanks everyone for your comments, support, and kind words. It looks like even within a day, we have sufficient interest to go forward with this group buy. I'll collect more interest over the next few days to finalize on the total cost and soldermask, with the goal of getting the boards as cheap as possible for everyone.
Answering some questions - first, you do not need a pogo-prog for this. The driver will be pre-programmed with Anduril by me. It will be ready for installation. However, if you want to play around with the firmware, you will need one. Details are in the first post above.
Second, for the spreadsheet, you cannot edit the cells. This is to preserve safety of the data entered. Instead, right click the cells and comment. I will go through the cells to fill them in.
If you are interested, comment on the spreadsheet instead of replying to this thread. I will not be transferring interest from this thread to the Google sheets!
Finally, there is no plan yet for assembled AUX LED boards. Right now you can order them yourself on OSHPark and populate them in yourself. I am working on documentation and details for that.
Hope this makes sense!
Thanks for the update. You note that the minimum output on your boards is higher, what is the current at the minimum?
I think I signed up. Thanx!
In for one or two
In for one or two as well
I take 1
interested but the bs form won’t cooperate with firefox for android
Looks pretty cool. I should probably sign up too… in part so I can have one, but also so I can do testing and make sure any future code changes work on it.
I still can not add comment to the spread sheet. Is it because Im not on a PC?
Intrested in atleast 2
Seems interesting. Would like to get at least 2pcs, but hoping shipping fee will not be “too” expensive, since I’m on the opposite side of the USA…
In for 2.
It probably is best not to state your interest here. It just clogs the useful information in the thread and could lead to people thinking that’s the proper way to sign up.
