Clemence, you caught the wave...
Interestingā¦but too large for the 20.6 mm diameter light that waits for it.
ADDED: though without the corner LEDs the following 12 would have just 0.42 mm larger diameter than 9ā¦.
ADDED: About 10-12A when driven off 16340? A hottie.
Too sleepy to continue, will post the beam shots tomorrowā¦
[Clemence]
^ That looks like exactly what Iām planning on doing: RGBA quadtrix (in an S2+).
Iām hoping to find a better 4-channel driver than the single mode per channel model that kaidomain sells, but even if not, I will enjoy experimenting with these.
Clemence, is that 4x4 still going to be 35mm? If so, it wonāt be able to fit in any flashlights
That 4x4 E21A requires big 13mm LES class COB optic to work properly. With smaller than 35mm (ideally 50mm) the wiring will interfere and creates artifacts unless special flat wires which is not common is used. With 30mm diameter itās uses are even more limited. And another reason is the heat spreading factor which is a very important factor for non isolated thermal pads in E21A. Larger the diameter is better. Above thermal simulation shows that to get into BLF output range (8500 lumens in R9080 or 12.000lumens in R70), 0,21mm (6 oz) thick copper trace is needed (with current best IMS available)
[Clemence]
Without corners it has LES not much bigger than XHP70.2ā¦
Yes I know, and itās designed to work with 4 - 16 LED
[Clemence]
BTW a 21 emitter config like that
would have merely 0.4 mm (3.2%) larger LES diameter than than a 16-up.
E17A Color mixing (Red, Green, Blue, Amber)
White matte PVC LED holder only
20mm Plastic aspheric, 15mm focal length
20mm 10Ā° polished surface, plain TIR lens
20mm 15Ā° frosted surface, plain TIR lens
20mm 25Ā° microlensed surface, convex center TIR lens
20mm 30Ā° frosted surface, convex center TIR lens
20mm 40Ā° microlensed surface, convex center TIR lens
20mm 60Ā° microlensed surface, convex center TIR lens
20mm 90Ā° frosted surface, plain TIR lens
20mm 110Ā° microlensed surface, convex center TIR lens
[Clemence]
A best color mixing are produced with elliptical TIR and VR16S1+2 different CCTs parallel led. I tested sm303+sm653 may be 95% dissolves on both, only minor singularities on edged. Non-elliptical TIR does performing mirred of source.
Please returned VR16S1 on store
LES is not my only concern with all my module designs Agro. Voltage flexibility is mainly limits the design. Beam profile can still be altered by optics, easier than voltage.
[Clemence]
Yes, I will later
[Clemence]
Wow, no donut hole with the 30dg Lens? But the Beam Has a weird shape the 15dg frosted lacks.
Clemence, what are the chances of making some 14mm*1mm quad E21A MCPCBās for Olight mods?
In general, I think a smaller OD board is useful in a handful of applications. Something in the 10-14mm would be nice.
Has someone hijacked virence store?
I see some jackets on sale thereā¦
high cri jackets
Is there any update on shipping to the US? The Indonesia Post website shows the US in annex 2, for which they say (courtesty of Google Translate):
I see EMS is the expedited option. Is Export Post the standard shipping option, or is standard shipping still not available to most countries?
Also, I would appreciate hearing confirmation the site is ok. Are the jackets another product Clemence is intentionally selling?
