For an emergency use or little use which type of battery should i use?
42 posts / 0 new
Madeeon
Last seen: 2 weeks 1 day ago
If i want an emergency light for leave it inside the car, which kind of battery should be recommendable? I mean, you can’t leave a 18650 or a NiMh battery inside the light. I don’t know about the consequences but, seems not recommendable do that.
On the other hand, what if i want a keychain? I carry on with me everyday but the use is for specific moments. Would it be convenient leave inside an AAA/AA battery? Should be better an USB rechargeable battery like we do with our smartphones? What specific name have this kind of battery?
Sirstinky
Last seen: 1 hour 42 min ago
A good quality li-ion like an 18650, 14500, 18350, or 21700, kept at around 3.6v will hold that charge for a long time. It is not remedied to leave a nicad, alkaline or nimh in a light (or anuthong) with potential parasitic draw because it can cause the batteries to leak. A nimh like an Eneloop or something similar thats low self discharge will also hold a charge for a while. Some flashlights have built in batteries, but enthusiast grade ones usually don’t.
Madeeon
Maybe the solution to leave an EDC inside the car is to unscrew the tail, not to cause some problems if it is inside the car for a month there, without using and with a 18650 inside the light. Is this correct?
What about a keychain light, you use for specific few moments? I suppose you can’t just unscrew the tail, maybe the light could fall to the ground.
raccoon city
raccoon city's picture
Last seen: 3 min 25 sec ago
It gets so hot here in the summer, I don't think it would be a good idea to leave a flashlight with batteries in the car.
I EDC four different flashlights, so I just use what I have on me.
(Only one of the flashlights is impressive.
The other three are just backups in case the battery dies.)
toddcshoe
toddcshoe's picture
Last seen: 14 hours 46 min ago
I carry 2xAA lights in both cars. NiHh to be more exact. Have had them in there for years now with no problems. They see the extremes in the winter as well as the summer. I top them off once a year unless they are used and required more charging. I have never had a single problem. Don’t know if this would somehow degrade the cells after wards but I haven’t seen anything that would make that statement true.
"Everywhere I go, there I am"
Enderman
Enderman's picture
Last seen: 50 min 17 sec ago
If you get good quality abtteries they won’t be as delicate as you think they are.
A typical nimh, alkaline, or li ion can survive pretty hot or cold temps.
xxo
Last seen: 4 days 20 hours ago
energizer ultimate lithiums in AA/AAA sizes and CR123A (ones made in the USA) are the best way to go for a light kept in a car. These will work in extreme temperatures, both hot and cold and they don’t leak.
Hobbyfotograaf
Last seen: 1 week 2 days ago
Alkaline batteries are very reliable, just replace the batteries every 2 or 3 years to prevent them from leaking if they are not used.
I have a 4x AA headlight in the car, it will only be used for emergencies, and i replace the alkaline batteries every few years.
There is a piece of plastic between one of the contacts of the batteries to prevent them from draining (that headlight has an electronic switch and there is a very small current drian when it is not used).
I use these and never had problems with leaking cells:
https://lygte-info.dk/review/batteries2012/Aerocell%20AA%20UK.html
These Aerocell AA are only 1,99 Euro for 8 cells (Lidl).
So it is only 1 Euro for every 2-3 years that the headlight stays in my car next to the spare wheel.
flydiver
Last seen: 2 days 42 min ago
Absolutely disagree with leaving an alkaline battery in any kind of device for long periods, especially devices subject to extremes of temperature. I’ve simply had way too many leak and destroy the device.
Primary lithium or CR123A would be my first choice. Huge shelf life, decent output, very little chance of leaking.
2nd choice is a good quality LSD NiMh. It will suffer a bit in the long haul due to less than optimal care but that’s just part of the price.
LiFe lithium is lower voltage but pretty robust. Some lights might be just fine with that.
I think your choice of lights is about as critical as the battery for this application. You want simple, robust, without parasitic drain.
Madeeon
I was just curious , because i know all of us have an emergency light inside the car. My question was about how they do, considering that is not convenient leave batteries inside the flaslight.
·How work Primary lithium, CR123A and LiFe lithium?. Do you have to charge them like any other 18650 or Nimh?
·I would appreciate some recommendation of battery for a keychain that i would use for few specific moments. I was looking for some usb rechargeable battery. I would choose AAA/AA if there is no any danger considering the Nimh would be inside the flaslight for a long time due to my use.
Thanks!
flydiver
Primary means non-rechargeable lithium. Use them just like alkaline, but they have a much longer shelf life and are not likely to leak. I use them in things like smoke alarms, thermostats, and some remotes.
CR123A is higher voltage lithium primary, same diameter as a 18650, but about half the length. This kind of light would work well if you wanted a tiny light with better output than AAA. I see not problem keeping them in a car. They are often used in photography where you could ruin very expensive equipment if it leaked.
LiFePo4/lithium-ion phosphate is a type of rechargeable lithium, a bit lower voltage (3.3v) and lower capacity, but is more robust than Li-on. Some people don’t think it’s a good idea to leave Li-on in a car….just in case.
I have a few LiFe from an old use but not sure I’d go out of my way to get them. LSD NiMh is probably more generally useful.
I have a small AAA twisty with a NiMh eneloop that’s easy to get at in the car for regular use in the dark. I also have a AA NiMh eneloop headlamp in the trunk if I have to have hands free and do some work that will take longer or need a lot more light. NiMh are very unlikely to leak. They will slowly discharge so it’s reasonable to pull them out and cycle them 1-2x/year. Decent batteries should still last a long time. Only use LSD NiMh for this, otherwise they will be discharged when you want to use them.
Sirstinky
Primary batteries aren’t rechargeable. You throw them out when discharged.
Madeeon
I think for the moment i will go with the NiMh for Keychain and emergency use inside the car. Maybe further in time when i know more about CR123 batteries i’d try.
For the NiMh AA i know Eneloop and Ladda. For the AAA option are there any good options?
Thank you so much for your help!
brewster
Last seen: 11 hours 25 min ago
For AAA size NiMh again the choice is Eneloop or Ladda. Maybe regular Eneloop is better than Ladda (or the equivalent Eneloop Pro) for this purpose, because they have less self-discharge.
I use lights with CR123A or AA lithium primaries in my vehicles, as recommended by several earlier posts.
Some flashlights that are standard with a single 18650 Li-ion cell will also take 2x CR123As.
DHart
Last seen: 1 day 4 hours ago
It has been stated, for many years now, that lithium primaries are the best choice for leaving in vehicles for extended periods of time – thus, that has been my choice… for many years. Otherwise, I use Li-Ion rechargeable almost exclusively. With Eneloops in the few lights I have which aren’t able to handle Li-Ion.
jon_slider
jon_slider's picture
Last seen: 13 min 28 sec ago
I have an AAA light in my car, loaded with Eneloop
I have an AAA light for my keychain, also loaded with Eneloop.
every few months, I change the battery in the car light… I have never had the light not work. It stays there during freezing winters, and hot summers.
It would be better if I used 1.5 volt Lithium Primaries, for example Energizer Ultimate Lithium, but those are expensive, and not rechargeable. That makes me reluctant to actually use the light..
They are the best choice for an emergency light left unused for years at a time…
I prefer rechargeable AAA or AA Eneloop. In my practical experience, they work even if left in a hot or freezing car, long term. With appropriate battery changes periodically.
I do not recommend leaving any 3.7volt LiIon in a car, that means no 18650, 16340, etc
I use lights with 16340 batteries for the majority of my needs, but IF I was going to leave one in a car long term, I would change the battery to 3 volt Lithium Primary, called CR123.
It is a BAD Idea to use lights with TWO CR123.. Lights that use only ONE battery are safer.
"High CRI lights for sale":http://budgetlightforum.com/node/72660
hank
hank's picture
Last seen: 44 min 32 sec ago
This, absolutely, when the earthquake shaking stops and you really need a working flashlight, those will be the ones you reach for.
Once you sort out the chaos, your NiMH will sustain you and the neighbors for a while — assuming you have a solar panel and big 12v battery, or a car power plug, and some battery chargers handy that it will power. Oh, and the usual advice, never let your vehicle’s gas tank fall below half full.
Oli
Last seen: 6 days 20 hours ago
Are there examples of a problem with a single battery 18650 flashlight in a vehicle because of high, low temps or length of time? I’ve searched in the past and I can’t find them.
nibble
Last seen: 3 hours 51 min ago
What I have in my cars is an AA flashlight ready to use with a LSD NiMH, and 2 separate alkaleaks AA as backup in a zip-lock bag. Cheap as hell. Once a year I top up the NiMH and check the alkaleaks to replace them if have leaked or have low voltage (very rare). They withheld temperatures of >50 C in the summer without a problem. Wouldn’t feel comfortable doing that to any li-ion battery, not even primary ones.
jon_slider
missGoogle told me primary lithium has a bit wider temperature range than eneloop:
The Energizer® Ultimate Lithium™ (-40ºF to 140ºF).
Eneloop (-20ºF to 120ºF).
I believe cars can get hotter than 120F.. depending..
but yes, eneloop works fine in my car, in my real world
mild winter temps of 20F
pleasant summer temps of 80F
have never put a thermometer in my car.. where my flashlight is… hmmm more corona time entertainment..
you made me look.. lol
maybe 18650 are not going to blow up in a car:
http://budgetlightforum.com/comment/217730#comment-217730
bfksc wrote:
fengstar wrote:
Hey guys I have a quick question, is a 18650 powered flashlight “safe” to use and leave in a car? I live in California, which is not too hot and not too cold, but I suspect temperatures in the car could exceed 100f on some really hot days. Is this kind of temperature ok for a 18650 battery?
It is perfectly safe to leave a Li-Ion 18650 in a car, hot or cold. It won’t explode or cause issues in that regard.
However, high heat is very bad for Li-Ion cells especially when fully charged, as it reduces recharge capacity even when not used. Since an 18650 is being used in a flashlight, it will be charged to 100% and then stored in the hot car. This is the worst scenario for a full charged Li-Ion cell. Keeping it at normal room temps or even cooler is better for longevity (charging to 40% and then storing in a cool location is the best method). It won’t cause any dangerous issues, but the life of the cell will be greatly reduced when left for weeks or months in a hot car. After just a couple of hot summers with minimal use, the cell will start to show serious capacity loss, which is a waste of such a good battery.
As others have mentioned, a low self-discharge (LSD) rechargeable NiMH cell like Eneloops are fine for a hot/cold car. They will hold a charge for quite a while and no issues with life cycles from the heat.
Itsme
Last seen: 19 hours 39 min ago
The only thing I have to add to this thread is about cold temperatures and manual lockout. I used to leave several lights with 18650 30 Q’s in them as part of a winter survival kit. I would always do a manual lockout so as to not have any drain while not in use. This past winter on a very cold night (about -25 C) I needed to use one of the lights. When I twisted the tail cap to once again use the light, the grease on the threads as well as the O ring were both frozen and the O ring tore and needed to be replaced once I warmed up the light. Not a big deal but something to consider if you may encounter the same conditions as I did.
AmbientSix
AmbientSix's picture
Last seen: 22 hours 43 min ago
Alkaline are all crap nowadays. Top of the line name brands leak. I vote primary lithium like a cr123 if you are keeping it in a car. Close second would be NIMH but I think the lithium primary would hold a charge longer and have an expiration date you can always check. I would not leave a rechargable li-ion of any type unattended in a car. Unless you are trying to get rid of that car.
Eagletac D25C, Nitecore D10 R2, Extreme E3, EX11.2, TIP, and Tubes. Noctigon KR4.
turkeydance
turkeydance's picture
Last seen: 19 hours 53 min ago
another vote for CR123 as “set it and forget it” batteries.
i have four CR123 emergency use only flashlights.
twice a year i turn them on just to make sure.
once a year i check the charges and check for leaks.
no leaks and the oldest are still good at 11 years old.
dealgrabber2002
Last seen: 3 hours 37 min ago
9v cells. I remember someone said during a hurricane, he went to the store to get batteries for his lights, all batteries are gone except for 9v.
turkeydance
dealgrabber2002….that is right!
i had the same experience
after an ice storm.
what are some modern 9V flashlights
that are not the lantern-type?
Macka17
Last seen: 18 hours 19 min ago
I think too many people are overthinking too many things nowadays.
I bought some nice looking/fitting Zoomies yrs ago 18650.
Self charging socket in the side of.
One in each car.
Every “whenever”“ I remember them I stick the dash charger into them for a coupla days.
One was on for around 2 months. LG Laptop pulls. 22600.
Never missed a beat, they still reading 3.6.(Whoops 3.9 – 4.1v on multi,)
I keep 98% of my torches in area of computer desk. Go through all my installed battery’s every coupla months and recharge.
Come to think of it. ALL my lights with battery installed. Apart from a coupla AA/AAA sized that don’t allow rechargables. Have Li-Ion and Li-Po installed..
All controllers, mouse etc run Duracel Ultra.
Climate. warm to Hot mostly. Queensland Sub Tropics. High Humidity (some say. I don’t notice )
Our winter means a light cover over a sheet in bed. for maybe 5 to 7 weeks (Intermittently) of the yr.
jeff51
jeff51's picture
Last seen: 1 hour 34 min ago
From a test I ran a while back.
113F official high, 115F on my car thermometer.
Coolest: Under front seat – 126.3F = 52.4C
Middle: Dash Glovebox – 138.5F = 59.2C
Hottest: Center consul – 146.6F = 63.7C
I vote for 123s, I’ve never had any leaks from then and they seem to last forever.
Next I would go for Lithium non-rechargeable.
After that, a cheap 2xC maglight (or?). and change the batteries every 2 years.
C batteries seem to be less prone to leaking that the AAA-AA flavors.
As far as pocket lights, almost all are too big for EDC use as far as I’m concerned.
I like the Nitecore TUBE.
Small as a USB thumb drive, rechargeable, electronic lockout, 45 lumens on high.
Easy to hold in the mouth if you need both hands.
Best of all – about $9-$11
Some have found that the internals fail after a while.
The problem seems to be the battery rattles around inside and eventually strain hardens the wires and they fail.
The fix is to open it up an put a tiny dot of double sides tape in there to keep the battery from moving around.
Be sure to allow room for the battery to expand and contract.
All the Best,
Jeff
xxo
2C Mags run great on L91 AA ultimate lithiums. L91’s will handle 140F, have a 20 year self life and won’t leak.
wle
wle's picture
Last seen: 2 hours 14 min ago
CR123A = shelf life is like 15 years = even then they do not leak
NOT aa or aaa, they leak, they do it worse in heat
not really li- ion, they run down in a couple years, plus capacity goes down in cold
wle
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
Lightbringer
Lightbringer's picture
Last seen: 28 min 59 sec ago
Okay, just some accrued wisdom over the years…
Never ever ever ever ever keep alkaleaks in any light. Unless, of course, you hate the light and want a reason/excuse to throw it out.
Alkaleaks are inherently evil. It even says so on the packaging, right under the “Hecho en Chine” part. Their aim in life and death is to ruin every device they’re placed in, if given even the slightest chance to do so.
CR123As are long-shelf-life almost-leak-free cells that can be used in quite many lights. They also withstand heat/cold extremes quite well. A box of ’123s found in a pyramid in Cheops still had enough juice in them to light a P60.
Lights that can take a pair of ’123s might be a good compromise. Check the light’s maximum voltage first.
eneloops are also good all-weather cells, but are limited to lights that can take NiMH. amaloops used to be as highly-rated, but I’m not sure about the latest ones. Not sure about LADDAloops, either.
No matter what the cell(s) used, keep them and any spares outside the light and in separate baggies. Yeah, even ’123s if you want to be safer.
dealgrabber2002
after an ice storm.
Pak-light or search eBay. Plenty cheapy. Don’t recall seeing any high end 9v lights. Pak-light is good.
