Looks like that thing a gonna be crazy efficient! I’m a bit sceptical of the 13k figure though. Wonder how they fit such a powerful driver in there. Maybe they have multiple PCBs for the driver? If it can actually do 13k I might have to get one.
Edit: It’s so short. How is one meant to hold something that hot?
Gotta be somewhere in the region of 4.5-5A per emitter (if 6V). So we call it 30W per emitter, 90W total - Loneocean has developed a 100W boost driver. Now you just need to pull the whole ~30A/3V from a single cell, so toss your 30T in!
110mm long, bulbous XHP70.2 LEDs, driver with inductor (cause boost), 21700 long cell but it is not a mule?
The body has 1mm thickness everywhere or how is that not a mule?
really fugly light… the switch is too high up… u will probably burn yourself reaching for the button holding it with one hand…. and hardly any deep fins wow… where should all that heat go
No interest.Never bought their brand and never will.
-QC has bad reputation, lights blowing up/catching fire!
- Terrible spot for switch.You will be burning your finger when decreasing turbo!
-Lousy cooling fins for heat shedding
-Probably get about 30 seconds of turbo before your fingers have blisters!
- These small lights with overkill output are useless and not practical to me.
I stick to bigger lights that have great output, sustained for 5 to 20 minutes depending on the outside temp. and better heat shedding, QC and run time.
The beam in the photos looks very blue; quoted run-time of 45 seconds on turbo and 1 minute on high (8,000 lm). 72 minutes at 2,000 lm would be useful with NW emitters; a single cell version of the Haikelite MT03 and MT09.
Brief, maximum turbo in a flashlight is kind of like underwood 10 mm Glock 29. I don’t plan on using them much, I don’t use them much, but it’s nice to know that they’re there if needed.
I hate the usb-c rechargeable batteries. I wish the usb-c was on the flashlight host. Given this is Imalent, I’m pretty sure actual lumens is about 10-11k lumens. Their QA got better with the MS18 and R90TS so quality should be good.
