New interesting SST20 leds found on KD: 5000K SST20 L5 DD , 4000K SST20 K2 FD2 , 2700K SST20 J3 JA3
That 5000K L5 DD would be amazing if bins are true. Highest possible flux bin with a tint similar to the Cree 3A!
I have serious doubt that FD2 is legit. I’ve come to believe that Luminus don’t even make this bin. But I will buy one just to try it.
The JA3 is a very nice 2700K. I tried Fireflies version and it is one of the better WW emitters I’ve tried.
FD2 bin?
Ban is this confirmed?
Yea, it is coming from the new wheel.
We are starting to use with this.
Thank you
is 5000K L5 DD below BBL?
Mostly, see here: https://download.luminus.com/datasheets/Luminus_SST-20-WxS_Datasheet.pdf
Seems like you need 3500K or lower to have bins 100% below BBL: https://www.mouser.com/datasheet/2/245/Luminus_SST-20-WxH_Datasheet-1499224.pdf, like for GA2 and GA3
Crap I was thinking FD1. FD2 is not rosier than FA3 :person_facepalming:
Looks even nicer with a slice. Hotspot get’s super small though.
I have not received any confirmations that the FD2 bin can be attained with the K2 brightness bin yet.
Hey BanL
can you get some 5050 LED or 3535 LED Lens Diameter 17mm 20 30 45 60 degrees Bead surface
i need about 5 to 10 pieces.
BanL, are the JKK lights your design?
I do not think so. They can be found in many strange stores on Ali. I bought in one of them.
Kdlitker 3x XPL HI 3000K U4 7A2 CRI80 P60 no lens | low | 34 lumens | 3014K | -0.0034 DUV | 84.8 CRI | Blue light relative amplitude 0.61 | 22.7 R9 | 72.6 R12 | 82 Rf | 101 Rg | 2xVTC6 in Kdliker E6-EX18 |
Kdlitker 3x XPL HI 3000K U4 7A2 CRI80 P60 no lens | M1 | 103 lumens | 3006K | -0.0033 DUV | 84.6 CRI | Blue light relative amplitude 0.60 | 21.9 R9 | 72.4 R12 | 81 Rf | 101 Rg | 2xVTC6 in Kdliker E6-EX18 |
Kdlitker 3x XPL HI 3000K U4 7A2 CRI80 P60 no lens | M2 | 448 lumens | 3032K | -0.0026 DUV | 83.7 CRI | Blue light relative amplitude 0.60 | 18.6 R9 | 71.1 R12 | 81 Rf | 101 Rg | 2xVTC6 in Kdliker E6-EX18 |
Kdlitker 3x XPL HI 3000K U4 7A2 CRI80 P60 no lens | Highest | 1,122 lumens | 3117K | -0.0040 DUV | 83.1 CRI | Blue light relative amplitude 0.63 | 16.7 R9 | 71.2 R12 | 80 Rf | 101 Rg | 2xVTC6 in Kdliker E6-EX18 |
Mines been ok from KD, pretty much normal, 2/3 weeks, sometimes quicker.
I know shipping times are kinda long now, but still gotta ask because one of my order got here pretty quickly which I ordered at 24/02/2020, but two other orders 17+18/03/2020 havent arrived yet. Same shipping method un-registered airmail. Anyone else has similiar waiting right now?
I waiting two orders (13/03/2020 and 29/03/2020), both SG registered shipping.
The one from 13/03/2020: 2020-03-26 Despatched to overseas (Country code: UY)
The one from 29/03/2020: 2020-04-04 Information Received – Item En Route to Postal Facility
I was going to say “pretty good R9 values” in the above table by SKV89, but after going to quote the post I see the 70+ figures are for R12. Now I see how it works, but it's weird to see that the table frame isn't shown or is set invisible. Maybe it is easier on the eyes to list the value identifiers, a colon, and then the corresponding value (R9: 22.7 R12: 72.6 Rf: 82…).
Received a package with a K6 flashlight host I was waiting for. Weighed 348.0g in my scale, which seems to be more or less well calibrated (also weighed a couple VTC5A cells multiple times and they ended up averaging 47.8916̅g).
Took some photos:
Beefy, tough host. Minus the knurlings tube wall thickness is ≈3.5mm, and it still hovers around 2mm at the back where the tailcap thread is (2.4 - 2.5mm thread included). Maybe it's not a tank, but it's armored.
Bezel diameter 62.6mm.
I was at first going to complain about the lens, but it looks that way because it comes with protective film either side…
The stock switch is a forward type one (17.9 × 12.9 × 13.5mm lenght × width × height). Will have to swap it.
All measurements taken with cheap Aneng caliper.
Host related question for BanL, is the S3 21700 using the same reflector size as the S2 21700 (also known as S21A)?
Took some photos:
Beefy, tough host. Minus the knurlings tube wall thickness is ≈3.5mm, and it still hovers around 2mm at the back where the tailcap thread is (2.4 - 2.5mm thread included). Maybe it’s not a tank, but it’s armored.
Hi
Their reflector is not the same.
Regards
Ban
Another little question.
Of course I am in need to replace the stock forward switch in the K6 host (can't say it makes me happy, honestly).
I am dealing with a little doubt concerning the most compatible replacement for the stock switch. I could use the PBS101C400 I have around here, but I'd like to get a more direct replacement, and stock a few spares. I have nailed this down to the
OmTen PBS101C190 or the OmTen PBS101
I couldn't find the PBS101C190 in OmTen's english website, PBS101 model list. Had to say, just in case the model went out of production or whatever.
Any other suggestion welcome.
Wed, 06/03/2020 - 05:50
