LOL for this size light even with great heat dissipation we are probably looking at less than 10 seconds on Turbo before it gets uncomfortably hot to hold. No idea how much power is run through High, so no idea how long it will run. For such a small size, similar to Sofrin C8F (21700). Just not that practical a light, maybe a “Wow” factor light at inital startup :).
I totally disagree and this is because of my experience. I have the NI40 which has the same LED and a similar sized torch. So far I have been able to run that at least 5 continuous minutes on max output. As summer gets here, it will probably be around 2 minutes before I have to turn it down.
Does this have a tactical/forward “on/off” ability without going into another mode? You guys know how much that pisses me off. Otherwise, looks to be a great light.
Hi Martin, do you have any insight as to when Banggood is going to ship? I got a notice yesterday that it'll be another two weeks. I'm trying to determine if I can trust that and if I need to cancel and order from Neal.
Grey has been discontinued. Please the friends bought the gray version contact customer service to change to black, or ask for refund. The black version will be shipped next week.
Some lamp beads are difficult to order recently. So sorry to keep you waiting.
Doing runtime test right now. Did some measurements this afternoon, it draws 15,4 A on Turbo and does almost 5200 Lm at startup.
The thing is, i did some beamshots, but apparently on high, not turbo. I just found out doing current measurements that it needs a double tap when ON for turbo. Otherwise it just cycles L M H.
It looks like its regulated at 60 DegC after Turbo stepdown, since output is rising again and almost stable 60 degC now.
