I had not thought about the FET direct drive. That is something a lot of us would not sacrifice.
Just a quick post, got around to uploading some photographs of the driver in action with aux LEDs.
I used cyan, pink and warm white LEDs. The above photo shows comparison with the glow gasket in my FW21 flashlight.
I also updated the first post of this thread with more details.
Some vendors who sell 0402 and 0603 LEDs for very low costs:
https://aliexpress.com/store/605870
https://www.aliexpress.com/store/1758868
You can also buy LEDs from digikey, mouser etc, but they typically don't have the 'unusual' colours such as cyan and pink.
Hi loneoceans
What about making a feeler thread for the aux boards, I’d be super interested in at least 2 And if they work perfectly with your driver board , everyone’s a winner
I’d like my fw3 series flashlight , just like the emisar d4v2
Being able to choose what colour aux leds are on
You sir are a genius !
Thank you so much
+1^^^^^^
You can add th to docs spreadsheet.
Looking forward to this. I’ve had to crank the temperature limit up quite high to stop the stock driver from thermal throttling simply due to the driver heating up, rather than the light itself becoming hot. At stock thermal config at top-ramp I was getting almost instant throttling even though the light itself was cold (yes the sensor is calibrated).
With low Vf emitters and a charged high current cell; by my maths there’s about 3W being dissipated in the driver itself at top-ramp, so it gets mighty toasty fast.
The problem with having the temp limit at 70 degrees though is that eventually the light becomes too hot to hold.
Hopefully this driver dissipating <1W in the same circumstances, I can use a sensible thermal limit.
Hello all,
I hope everyone has been well. Here are some new developments for the lume1 project!
Lume1 Driver on Nealsgadgets?
As you may know, I was planning a small 50-100x group order of drivers due to the large interest in the Lume1 driver.
Because of this group order and the interest garnered, Neal from Nealsgadgets has reached out to me and he will be picking up this driver for production. This will likely result in much better prices than this small group order, and also with better shipping / logistics! Discussions and planning are currently underway, so please hang tight. The idea is to be able to purchase these drivers directly from www.nealsgadgets.com, and perhaps also as an option in future flashlights. This also means that the group order will no longer proceed forward, since you should be able to purchase them for better prices too!
The details are still being finalized, and the timeline and other logistics are still being worked out. I will post more detailed updates when they come.
Lume1 Driver Datasheet (Preliminary)
In addition, I managed to get around to document the driver in this datasheet:
It's still preliminary; once I review it, I'll be able to make an official release. There may be some mistakes in the datasheet, so just be aware!
Finally, thanks everyone for your interest in this project, and for all the support! More to come soon.
the first "production" lights with the Lume1 driver will (hopefully) be the Damascus and Mokume versions of the FW3T
you still can enter the list - but the deposit phase already has begun!
https://budgetlightforum.com/t/-/61844
just looked at the datasheet...
very professional!
Wow. Thanks for that awesome documentation!!
Excited to get these in my hands and in some lights!
Does Neal have interest in doing the Aux boards as well? That would be pretty cool. He could even include it on the premium FW3A models
Can this driver be used also in other e-switch flashlights, assuming you would connect the e-switch to the inner ring on the back?
The multi-color aux leds are really an outstanding feature.
I assume so, and that’s what I was thinking of doing for some other lights, the via for the switch ring seems to start here :
Probably a bit small for soldering a wire there, but there is a tiny bit of space up north without components (blue) to make yourself another via.
Or even better loneoceans could add a solder pad for the switch, unused for the FW3X, but would allow to use the driver for other lights where it fits.
i am trying to make that happen ;)
Yes!!
that is good to hear, i have have had nothing but great experiences with Neal.
maybe Neal can source the springs from lumintop to sell together as a set ?
Neale confirmed on FB that he will sell FW3 driver and AUX boards also.
Spring should be included cause partially finished products are not attractive...
Spring should be included cause partially finished products are not attractive…
Could you please post a link, i can’t find it on fb
He answerd in M4D M4X deals and reviews post
It is possible to use this driver in flashlights with 22mm diameter driver cavities - just make sure that the shelf and retaining ring fit the driver and don't hit other components. Afterall, the Lume1-fw3x was designed specifically for FW3X flashlights only. thefreeman is right that you can solder the e-switch wire where the red arrow is drawn in the diagram. Perhaps more designs will be made for other flashlights in the future.
As for springs, yes, since Neal / Lumintop is fabricating the drivers, they will be able to use the same spring as the stock FW3A driver. It'll be nice if they sold the springs separately too, since I think they're the perfect size and profile for many small drivers. Individual drivers sold by Neal will of course come with a spring
Finally for AUX LED boards, I'm working with Neal to find the best way to get these produced. Most likely it'll be the RGB AUX boards - for the tri-LED boards, different LEDs will require different series resistors, and I'm not sure what the best solution is to sell that since there can be so many variants.
If I may I have one minor comment about your design. I’ve noticed that your pads for pogo key have switched places for mosi and miso against already standardized pattern. Look like you can easy fix this to be in line with other drivers on the market.
