The first 4 shipping options Ali offers for NL are free. Remember, you donāt have to be a diver to buy this light. I think these are great outdoor āall weatherā lights. Something I would not say about a flimsy ātacticalā zoomie. And the size and weight of this thing should be quite reassuring when walking the dog at night.
Ah, I missed the triangle indicating a pulldown menu for shipping options, but theyāve preselected the least expensive for my orders (Singapore Post, $1.16 for a single light)
What do yāall think about putting a little bit of lubricant into the grooves of the switch ring, to hopefully keep grit out?
One problem I can foresee with this design is cleaning out the moving parts eventually.
Had given it some thought. Itās a double sided dilema. Grease will trap sand and other foreign material. Having nothing should be easier to clean out, providing the moving spaces donāt wedge the particles. But the feel is not very smooth (slack).
Be very careful removing the magnetic switch as thereās a tiny spring and ball bearing underneath thatās easy to lose. The spring shot out and took me 30min to find
Unscrew the head. Put the light IN a towel, completely covered up. You donāt need to see the for the next step.
Note exactly how the magnetic control ring is made, so you know the front vs. back. Itās not quite symmetrical. Not SURE this is critical. I did not try it both ways. but the magnets need to align with internal sensors to work right. If you get it wrong, simply reverse the assembly position.
Slowly rotate and pull the magnetic ring toward the front. At some point the ring will clear the spring loaded ball bearing and they will pop out, both most likely. This is why you need it covered, to catch the parts.
Keep pulling and wiggling. The ring now needs to slide over the 2 O-rings behind the front threads to come off. You can remove them beforehand if you donāt want this little bit of extra resistance. Either way is fine.
Thatās it.
The ring has 2 magnets in cut slots. The spring goes in the hole with the bearing on top. I DO plan to dive the light so I packed the spring hole and magnet holes with silicone grease. Iāve had some cheap dive lights like this that used low carbon steel and the spring/bearing/magnets all rusted out in a year. Itās essentially impossible to fully flush out all the saltwater from these deeply buried crevices after a dive.
Silicone grease in the spring + bearing hole helps hold it in place for assembly. Slide on the magnetic ring (remember orientation) > when it bumps up against the bearing compress the spring with a thumbnail and slide it fully on. If you donāt feel completely confident of your skill, or you have not greased the spring + bearing you might do this inside a big paper bag so they donāt get away with a slip.
Replace and lube O-rings if removed. Check for any kind of lint or debris that might compromise water tightness. Replace the head. Put in a battery and test.
One thing to note is, donāt lube the front threads of the battery tube. Thereās no retaining ring giving a good connection and it relies on clean threads. Lube orings well but keep it off the threads. Had 5pcs start flickering and couldnāt figure it out for awhile.
Ended up grabbing 30pcs instead of the previously mentioned 50.
Addendum to my instructions on the magnetic ring removal. The [battery tube] @PiercingTheDarkness mentions is the long piece that the battery is installed in, NOT the front part you need to remove to take the magnetic ring off. The front threads on the battery tube are not anodized.
The part in front of that has anodized threads and you can grease it well, and probably ought to.
Did a burn test on high in a tub of water. A 2400mA (tested, not protected) cell lasted 90+ minutes on high. At the end it started blinking for a bit, then simply went out. Seems to be an inherent low voltage cut-off. Cell measured 2,91v when checked.
Finally got mine. Very nice flashlight for the price (recent discount). It is a bummer that thereās no lockout. While the selector ring is notched, it could be rotated by accident. I donāt plan on changing the emitter. The glass has a film on the insideā¦ but itās more of an annoyanceāI doubt itās affecting the lumens output much. No knurling except for the control ring, so I added a bicycle inner tube segment to the body. It was tough getting it on! Took me about 30 mins while I watched a TV program. But now it has good grip while still looking nice. Looking forward to testing this while snorkeling this summer.
