Flashlight body wall thickness?
25 posts / 0 new
Agro
Agro's picture
Last seen: 1 min 1 sec ago
Flashlights with thick walls are more sturdy, can stand more abuse.
They also conduct heat better.
OTOH they are larger and heavier.
But…what exactly is thick and what is thin?
What is the thinnest wall that’s thick enough?
My goal is lights that are tough enough to survive throwing around but nothing more than that – I’d rather reduce weight than overkill.
I haven’t seen that discussed but I don’t remember ever seeing aluminum flashlight that would crack or break.
I think I’ve seem some crushed but only after extreme abuse.
Thinking about it I came back to not so new thread:
http://budgetlightforum.com/comment/1482537#comment-1482537
Fireflies E07 is an example of extremely thin walls, 0.3 mm in the thinnest place in a not-so-lightweight 21700 light.
I haven’t seen one that would brake yet.
This makes me think that maybe all our regular lights have extremely thick walls?…
kiriba-ru
kiriba-ru's picture
Last seen: 6 hours 19 min ago
All depends from proportions. You don’t want 0.3mm wall in alu can-style flashlight, but it can be more than enough for 10180 or AAA light from stainless.
You can easily bent 0.5mm alu, but if this thin ring have supports like thicker material in both directions – you should not worry.
Unheard
Last seen: 46 min 21 sec ago
My fear with the 2019 RRT01 and 18350 is that when it falls and hit something with the battery tube, you’ll end up with a canned battery. Else I wouldn’t mind.
Firelight2
Firelight2's picture
Last seen: 8 hours 41 min ago
I recall reports of the Nitecore D10’s body tube cracking and sometimes breaking in half. Apparently it’s really thin.
Henk4U2
Henk4U2's picture
Last seen: 11 min 43 sec ago
Don’t limit yourself to the tube itself.
The critical point IMHO is the bottom of the slot for the O-ring between tube and threads.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
Agro
Agro's picture
Thanks for the replies. Smile
Interesting. Smile
I searched for that and failed to find any mention of such failure. Though I’ve seen a number of posts saying that lenses cracked from minimal abuse which some interpreted as the body being too thin around the lens. But a photo doesn’t confirm that:
The lens is thin though – just 1 mm.
And maybe the lens – body gap is too small and minimal flex of the body already stresses it?
MRsDNF
MRsDNF's picture
Last seen: 20 hours 41 min ago
This is usually the thinnest part from my experiences as well.
VaKo
Last seen: 1 month 1 day ago
I think the most overbuilt light I’ve seen is the Manta Ray C8.2, the shelf is 8mm thick
Scallywag
Scallywag's picture
Last seen: 7 hours 11 min ago
My DQG Slim AA has pretty thin tube walls
The thinnest measurement I can make out is under the O-ring of the battery tube. Outside diameter is 15.07mm, inside diameter is 14.64mm. The difference is 0.43mm, so the wall thickness should be about 0.215mm. (That’s thinner than a slice of cheese on a cheeseburger for my fellow Americans.)
The DQG Slim impressed me due to its thin walls and very slim form factor (my other 1AA lights have a wall thickness, at least at the end of the threads, of well over 1mm. I am very surprised the E07 has such thin walls. This DQG is also titanium, so it’s got a bit more strength there.
EDC Rotation: ZL SC62(w) | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01 | Purple FW3A, 4000K SST20
EagTac D25C Ti | DQG Slim AA Ti | Jaxman E3 | UF-T1 by CRX | Nitecore EX11.2
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special
Unfinished: Supfire M6 3xXHP50.2, Sofirn C8F, Sofirn SP70
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
Barkuti
Barkuti's picture
Last seen: 5 hours 43 min ago
VaKo wrote:
I think the most overbuilt light I've seen is the Manta Ray C8.2, the shelf is 8mm thick
This or that? I like it!
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts, namely with nested quotes. Trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
VaKo
Yeah, that’s the one. I only have the short version but it is essentially a C8 with a 26650 tube and massively overbuilt head. Even the one I modded with a copper spacer, 6x Luxeon MZ’s, and a 12A driver handles heat like a champion. It certainly isn’t a pretty host, but on a utilitarian level it’s fantastic.
Scallywag
Scallywag's picture
Barkuti, do you know how those compare to Kaidomain hosts (such as this one ) and how much space there is for a driver with a large inductor (I’m thinking XHP70.2…)?
Barkuti
Barkuti's picture
No idea Scallywag, though that K5S looks pretty close to the aforementioned Manta Ray C8.2. Submit an inquiry to BanL in KD (kaidomain): Deals and new products thread.
VaKo
Convoy’s XHP70 driver fits in the |C8.2 cavity fine, was the first light I built in this host.
hank
hank's picture
Last seen: 12 hours 30 min ago
Fenix TK20 (2xAA) has massively thick sidewalls.
Rexlion
Last seen: 15 hours 3 min ago
!{width:44%}https://i.imgur.com/8JNxlaM.jpg!
You beat me to it. One could probably run over the TK20 with a car and not hurt it.
Lightbringer
Lightbringer's picture
Last seen: 1 min 23 sec ago
The Xeno E03 (14500/AA) is pretty solid. Thick-enough tube-walls to let them sculpt the finger-grips, yet!
And the Tacklife generic flashlight (26650), https://www.amazon.com/dp/B07DS7PLTB/ , is built like a club.
As for AAA lights, that Oilight i3UV light is a solid moose of a light, seems bulletproof.
The Glaree E03 is so lightweight it almost levitates. You forget it’s even there.
Kinda hard to bust an AAA light, unless you really tried hard, so the Glaree is fine for what it does.
Yokiamy
Yokiamy's picture
Last seen: 6 hours 9 min ago
Eagle eye X6
Agro
Agro's picture
Yokiamy wrote:
Eagle eye X6
Yeah…indeed overkill:
http://budgetlightforum.com/node/33871
Not my style….but nevertheless I like how it feels in hand Wink
Ryzbor
Ryzbor's picture
Last seen: 3 hours 53 min ago
Does it make sense to build a C8.2 with XHP70.2 with Simon’s 4.5A driver but with removing the temperature protection?
I’m somewhat afraid it will stabilise the output below 1500lm.
virence.com Nichia E21A sw30+sw40 Wizard Pro ; Skilhunt H03 XP-E2 660nm Photo Red ; Wizard Pro E21A 2000K ; S2+ E21A sw40 d220 (for sale)
Barkuti
Barkuti's picture
Ryzbor, if you mean to use some ∅22mm Convoy SST-40 linear driver (12 groups or 4 modes) in a Manta Ray C8.2, could work. The drivers may need some modification to work properly with 2S cells, but if they're built with the same parts as other recent Convoy drivers they'll likely straight work fine. Check the Convoy XHP35 Driver Analysis / Testing / Schematic thread, onboard linear regulator investigation here.
The increased voltage drop in the MOSFETs could cause trouble, improve driver cooling as much as possible.
Ryzbor
Ryzbor's picture
No no, the new 1s 22mm 6v boost driver from Simon.
Barkuti
Barkuti's picture
Already tried and tested Ryzbor, really no need to ask then. The removal of the onboard NTC resistors is discussed in the Convoy 17/22 mm SST40 Driver temperature protection removal thread, and looks like someone found it in the XHP70x driver.
In my experience, though, you can place your multimeter's probes over the resistor pins, and blow some air with your mouth while looking at the multimeter's screen. Even if subtle, that will reduce the resistance 1 - 2% and will give you confirmation that you are peeking at the right thing.
MascaratumB
MascaratumB's picture
Last seen: 1 hour 17 min ago
BTW, if someone wants a bit of flashlight sexyness and toughness at the same time, you can get that C8.2 in red Wink
I guess the tube for the 2nd battery is not availble, though.
https://www.aliexpress.com/item/32953188982.html
About robust hosts, as a fan of AA lights: Convoy T2, Jaxman E3, Sofirn SF10 (Alonefire X360).
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior // ON THE ROAD: M1 / i3 / M3 Pro // ROVYVON: A2 + A5R / E300S / A8 // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 // XTAR: PB2 Charger // Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review's Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
Agro
Agro's picture
I see that Fireflies E07 can indeed break from a mild drop:
http://budgetlightforum.com/node/71977
