I would rate home made PCB considerable lower than ordered PCBâs with your own layout. It may be fun to make your own PCBâs, but the quality and complexity is rather limited, compared to a professionally manufactured PCB.
I have done a few home made PCBâs, but the quality has always been very bad. Very long time ago I got a link to a company that could do PCBs for a reasonable amount of money (<$50 for double sided, plated through) and since that time I have not done any PCBs at home.
I tried not to use too many words, but the idea was if you made it to the bottom of the list, you were also able to draw them yourself. The idea of milling a PCB you downloaded off the internet is not a choice on the list.
I updated the wording of the last two to include drawing. There is one vote each for those currently, hopefully that didnât mess with anyone
That is not really related, I have always drawn my own schematic and then layouted my own PCBâs, when I used Eagle to design the PCBâs* I mostly used the auto router. Now that I have changed to KiCad I do my own layouts without auto router.
*Very early I may have used something called Orcad, but that was on company time.
Breadboarder here, what do I win?
Tweaked a lot of CBâs back in the day as well.
Yeah, Iâm old.
I have drawn and ordered surface-mount style PCBs online
But in this case not more advanced than a flashlight driver
An assorted pack of SMD resistors :smiling_imp:
All of the above At collage 1993-96
Fixed modded many cbs, ham radios
Built amps from scratch With instructions for a collage project
Build Ariels
Build a music mixer from scratch
Fixed synths
Fixed all sorts really
Done board repairs and stuff that was crushed to death
Never. Do I win a booby prize?
I just bolted some new SSDs into my ancient Mac ProâŠ
Then I had to run some command prompts on my ancient MacBook Pro to get it to boot again after converting the filesystem.
Thatâs about as fancy as I get with electronics. Last time I tried soldering, I burned a bunch of holes in my guitar and ruined the pickup switch.
Six years college for computer science, computer and electrical engineering, then over the last 8 years turned a computer/monitor refurbishing business in my basement into a small-electronics design and manufacture shop with pick-and-place, reflow oven, even some CNC metalwork machines for heatsinks and cases. All electronics designed, PCBs laid out and firmware written by myself or my co-founder who left four years ago to design rocket engines in Texas. Projects range from 200A power supply breakouts to USB devices with sub-0.5mm pitch QFN. Currently working on a family of flashlight drivers, DC motor driver for an electric go-kart, powered USB hubs and a fourth generation of hobby-scale bitcoin miners.
Whatâs that good for?
In â85, I âput togetherâ both the David Hafler DH-110 preamp and DH-220 amp. While it was only âsoldering by numbers,â they were both working when I sold them 15 years later.
Good stuff.
Chris
Owned the David Hafler DH-101 preamp back in the 80âs driving a Harmon Kardon 100w per side power amp into JBL L100T floor standing speakers.
Good reliable rig withstood many parties
That was decades ago, as a teen in the 70âs⊠I started to buy kits in the UK, then went to draw boards with a special pencil that i would dip in some liquid to etch away the copper⊠Then i got bored with all that mess and for small projects without IC i came to use rows of screw connectorsâŠ
I have only wired / installed / repaired, electrical things like auto radio and speakers, house receptacles and switches, cnc machine spindles and proximity switches, flashlight drivers and leds. Always wanted to learn electronics, but its just too much for me. I donât see how resistors, capacitors, diodes, transformers, can make the music, tv, computer do its thing, so I rely on you guys to help me in the dark.
Please elaborate
I once clipped a resistor on a uniden bc200xlt scanner in order to receive cellular signals. I was also kicked out of devry technical institute twice
i have done all, except the milling one because i donât have CNC at home
My vote was for, âI have drawn and etched PCBs at home.â.
I have also done point-to-point soldering, at work for prototyping, and at home for hobby projects.
And letâs not forget hand wire wrap for work.
As a kid, I only had parts and supplies to spider wire my hobby projects.
Iâve been an electronics technician for 20+ years component level troubleshootingâŠproduction, test, and debugging circuit boards. I live under a microscope most of the day doing 0201MM, hot air, through hole and SMT, BGA rework, etc.
The hardest part I had to deal with was an $800 356 ball count BGA using lead free solder. The engineer was always screwing around with the profile on the rework machine leaving it unusable and not telling anyone. I would find out installing a chip and watch the the machine perfectly place it then squish down instead of releasing and bridge all the balls together. Fun times.
