Interested.
Not possible to select this model from your form
Interested
Like djozz said, 4 colors/triple optic/spot&flood...??????
Definitely in for this. As mentioned the model is missing from the OP form.
I like it. Count me in.
Hope Jetbeam fixed the high stand-by drain issue.
The drain on my older model RRT-01 seems fine. I’ve left it for year with an 18350 installed and it still works and seems nearly full-charged.
Not sure about the 2019 RRT-01. Don’t think I’ve left mine that long. But I have left it several months with battery installed and it’s still bright.
Very interested.
Is it 3xRGBW emitters?
I heard the 2019 version drains the battery in a month or something like that.
2 emitters for white light and a third one for RGB?
That makes much more sense, what kind of options are out there for larger RGB emitters? I have only ever seen the XM-L Color but there has to be more from other brands right?
I have 3 of them - this has not happened on any of them
Keep getting error on that form. I’m interested though. Would like some more details though. Nice that it will cost somewhere between 10.99 and 99.99.
Interested depending on more details - The title does say XPL-Hi v3. so the only question is the aux lighing and how bright the aux lighting is. Assuming only white reaches 1200lumens. Not any of the aux colors.
Measured parasitic drain of the 2019 RRT01 and it was quite low, in the range of lights with electronic switches. Thought it was higher due to the sensor readings.
Interested.
Interested, form is not working. Would be nice if the floody led could be high cri.
works for me
Interested
Interested.
Jetbeam = Nitecore not long back, this would make a good D10/D11 replacement or even the new RRT01 Raptor Tactical especially.
