1. SP33V2.0 KIT (battery and charger included)
Code# Z8CQ-AM2WJA-NC5RAQ
Code# Z85M-RJY8G7-6FXTAL
Code# Z8JZ-3UDZAY-8PW4AW
2.SP36 Anduril kit
Code# 56FZ-C8KV7B-MVWEAG
Code# 562H-ZA9YH3-43WKA7
Code# 56BJ-58PCZ6-JNS6AB
2.SP36 Anduril kit
Codes for SP40 Set on May 13th:
Code 1# 57VR-Z2PP4U-3HZ2AW
Code 2# 57VS-4KHTSD-HGX8AM
Code 3# 57T4-WUVCQV-QE4VAJ
Used code 1 . Thanks .
SP32AV2 need use 20% discount code plus CDN$3 coupon
Codes for SP32AV2 Kit:
9D3Y-4UFMG2-KB7QA5
9DKD-XYKKUW-MNR3A7
Code for LT1 lantern Kit:
TSYH-TRELXN-Z3D2AM
TSWA-KVYX2K-YUMMAY
SP32Av2.0, LT1 lantern and SP40, which one do you pick?
Just ordered a L1T kit. I used TSWA-KVYX2K-YUMMAY
Thanks
LT1 is a good lantern Hope you will like it
SP32AV2 Kit Code:
9D2A-R785TM-CWX6AR
9DQ5-RR4XF7-LGAWA7
LT1 lantern Kit Code:
TS83-P2FCMM-DKE8AY
TSH6-VHUWCE-6GUXAQ
SP31V2.0 features 5 modes and hidden strobe SOS with rechargeable 18650 Battery and USB charger
I just ordered the LT1 lantern.
(I think) I used the TSYH-TRELXN-Z3D2AM code.
Thank you for doing this Sofirn!
If code has been used, pls comment this post for more codes
I pulled the trigger on the LT1. This thing sounds insanely good. Code was TSEK-ULF6D7-AE66A8. Thanks and this will be my fourth Sofirn light. So far so good. Good on you for periodically remembering the Canuck hinterland market.
Order will be fulfilled by amazon. You don’t need to parcle strucks on transite.
Hi Sofirn.
It appears that the coupon can not be added to the discount code. At checkout I can only get one discount or the other. Is this the intention? The original post seems to indicate both can be combined.
Thank you.
Coupons can be added to discont code. I will send you a new code via PM.
Three discount codes will be shared here for SP10S, SP32AV2.0 and SP40 from July 16th-19th
