[Update]Wurkkos dual LEDs 21700 Headlamp design Photos/UI update~
236 posts / 0 new
Wurkkos
Wurkkos's picture
Last seen: 1 min 49 sec ago
Thank you for all suggestion for HD20 and thank you Lux-perpetua to collect all information. And finally we have confirm the UI and the LEDs
Spotlight—Cree XPL 5000K
Floodlight—LH351D 5000K 90CRI
UI details (except the raming mode)
Hi Guys, Wurkkos will have a new products soon—————-
L sharp 21700 headlamp named HD20, here is the design, with 2 LEDs, realize both floodlight and throwing in one flashlight.
still not sure about the tint for each LED, planning 4000k or 5000K for floodlight and 6000-6500K for throw.
Floodlight use LH351D 4000K or 5000K
Throw mainlight will use SST20 5000K (give up the 6500k )
With magnet tail and USB-C charge port ( input and output )
will update the UI soon
Fortunately, the weight is not too heavy after test the first sample batch, 160 gram with 21700 battery included. probably will try different
color for body…
First sample batch Crown * hmm the blue color seems is not the one we need as the design
UI:
Edited by: Wurkkos on 07/07/2020 - 04:19
Wurkkos
Wurkkos's picture
Unheard
Unheard's picture
Last seen: 6 hours 13 min ago
I like 5000K for throw.
The Samsung is quite greenish at higher temperatures. I suggest 3500K.
Smile, you cannot kill them all.
vresto
vresto's picture
Last seen: 5 days 23 hours ago
and output? looks interesting
EDC-Amutorch X9 XHP50 nw,Sofirn If-25A cw
Headlamp-Thrunite TH30 nw
CM2010
Last seen: 37 sec ago
Interested in this.
bmengineer
bmengineer's picture
Last seen: 16 hours 52 min ago
I would use something like 4000-5000K for both LEDs – especially if you have a mode where both throw and flood are on at the same time, having them match would be nice.
Find all my reviews of flashlights and more gear at www.bmengineer.com
Nicolicous
Nicolicous's picture
Last seen: 55 min 23 sec ago
look nice ….blue is sexy.
design abit like zebralight but i like it Smile
ramping UI?
and price ?
Nico -.-
Agro
Agro's picture
Last seen: 12 sec ago
1. ~100g empty? That’s way too much.
2. General purpose flood should not have 180 degrees, you still need some collimation. With a TIR this small in LH351D it won’t be far from a mule.
TMaxxJJ
Last seen: 45 min 5 sec ago
3000k-4000k for flood, 4000k for throw is my preference.
Also, it looks like it will be quite heavy on the head side. Dual emitter headlamps look and function a lot better when they’re centred.
will34
will34's picture
Last seen: 1 hour 49 min ago
XPL HI for throw, LH351 for flood. Sst20 isn’t very efficient… 160gr with batteries is way to much, almost twice of a zebralight h600 with battery.
alex64
alex64's picture
Last seen: 4 hours 44 min ago
XPL-HI 5000k for Throw
Nichia 219C 4500k or LH351D for Flood
alex64
alex64's picture
It’s difficult to compare the weight of a flashlight with different battery and less features. Zebralight H600 doesn’t have dual led, magnet, USB charging and 21700 battery.
Parametrek
Parametrek's picture
Last seen: 1 week 2 days ago
Stuff like this makes me wish that Wurkkos had a website. Though if someone from Wurkkos does read this: I know you are close with Sofirn but please don’t use whoever did Sofirn’s website.
Try the largest, fastest, most flexible flashlight search engine: parametrek.com
43 brands, 2375 models and still growing!
NEW: US battery database and European battery database
Lightbringer
Lightbringer's picture
Last seen: 2 hours 33 min ago
Yep, looks a bit heavy for a headlamp, but I’d certainly use it as a right-angle flashlight.
As mentioned, it’s best to have both flood/throw match. You don’t want something lit up blue at a distance, then be lit yellower as you get closer.
And yes yes yes to that mount. I hate plastic C-clip holders, because they can snap, and the light often pulls out way too easily.
Rubber-loop mounts are the best. Easy to use, the light doesn’t fall out accidentally, and stays in place with the rubbery grip vs hard slippery plastic.
I’m scared to think about the UI, though. LOL
bmengineer
The smart thing to do for this would be to build ok the tint-ramping firmware Sofirn used in the LT1 and that one flashlight, there’s not much reason for it to be different.
Would be a nice added feature if double tapping for turbo always went to full throw or full both emitters.
AEDe
AEDe's picture
Last seen: 3 hours 10 min ago
6500K – please forget about such led! 4000-5000K and the same CCT for both led.
21700 why? 21700 good for EDC , pocket-roket… but not for 1000lm range L-shaped hadlamp. with 18650 you can get good weight and dimensions it is one of the most important things for headlamp!
Don’t try to make ‘laser’ from throw. Pay attention to shape of spot.
Design looks good but I not sure that it is convenient to use headlamp with big center of mass offset.
Lightbringer
The hotspot in the WK30 (small reflector, though, not TIR) is pretty nice with the ’351.
I like the idea of a TIR to be able to even swap them out if you want wider/narrower beam.
AEDe
AEDe's picture
I completely agree.
I saw a lot of TIR that give ugly square spot, so it is necessary to pay attention to that.
BurningPlayd0h
BurningPlayd0h's picture
Last seen: 3 hours 21 min ago
The features don’t change how to feels on you head. 160g is heavy for a headlamp. If I’m wearing a headlamp for a long period of time without a beanie hat to give padding, even 18650 Zebras get to be painful.
If this light aims to be a headlamp, the weight needs to come down some way. If the features stay the same marketing more as simply a right-angle handheld makes more sense to me personally.
The mock ups really do look great though, this could be a great light with the right UI.
AEDe
AEDe's picture
If 160g is weight with 21700 and full headband it is good.
Good example of headlamp with throw and flood is Ylp Panda 3 60g flashlight +40g headband. +50g 18650 = 150g
bts
Last seen: 2 months 4 days ago
Nice design. What’s the length? And does it comes with pocket clip?
Better to hv it and not need it than to need it and not hv it.
vinte77
Last seen: 1 month 1 week ago
Interested.
BurningPlayd0h
I strongly suspect it’s 160g for just the light + cell. No 21700 light I know of gets anywhere close to 120g loaded with that size of cell. For that matter 160g isn’t even bad for a light of with that cell format, but it’s way past suboptimal for a headlamp IMHO.
That means something like 130g when using an 18650 cell, so not as bad in that case assuming it has dual springs and/or a cell spacer included to operate with them.
JaronRH
Last seen: 4 days 7 hours ago
Neat design! Can you run both flood and spot at the same time? If so, why not aim for making both LEDs the same tint? (5000-5700k)
Wurkkos
Wurkkos's picture
1600lm max for throw light and 600lm max for floodlight
Wurkkos
Wurkkos's picture
Yes, both flood and spot could be turn on at the same time, and adjust different modes when both turn on
Wurkkos
Wurkkos's picture
the length is 12.1cm and yes it comes with a pocket clip
Wurkkos
Wurkkos's picture
yes, that is the point about size and weight when we decide to use a 21700, for a input and output 21700 with more power and runtime, here is beam for test sample, 4000k tint floodlight and 6000k spot
6000k spot beam
4000k floodlight beam on and off
Wurkkos
Wurkkos's picture
Yes, thank you, we will do a own website soon, till now our products are not rich enough
JaronRH
Looks like a good flood and spot! Definitely need to go for the same tint though for when both are used.
Wurkkos
Wurkkos's picture
Big Smile Big Smile
