Yep, save yourself the angst.
I have the NSX3 with different emitters (I put high CRI LH351D led in it), but as an advice I very much suggest it over the Lumintop FW21 Pro. The nightwatch at least tries to make the most of shedding heat for this compact format (although at the full 120W nothing will be enough), the FW21 does not even make an attempt at it. While at these power levels heatshedding is the single most important design goal. Making 10,000 lumen is dead-easy these days, but making it actually usable is very hard.
Djozz, what are your thoughts on the NSX3 build quality? Seems like it could be a nice host.
Build quality is good. Modding was a while ago but I recall it was easy. I did not like the driver, I used a 17mm BLF-A6 driver soldered in a brass converter ring (from Simon) to bring it to 22mm. I did not get the leds perfectly centered in the three reflectors, that can be because the leds were not precisely centered on the pads during reflow, or the MCPCB is not perfectly tailored for the reflector, I don’t know which. With the big dies of the LH351D’s it does not matter, the beam is fine.
Hmm, tempting!
I have only the FW21Pro so I can’t compare, but, regarding turbo runtimes: with the FW21 they are not as bad as I’d have expected. I set the thermal regulation at 82°C and with a Molicell P42A I get 12-15 seconds before stepdown, at room temperature. And when it steps down, you can always kick it back to turbo by double clicking again, and get a few more seconds. Being so light, you can hold it cigarette style by the tailcap end, and you can get 40 seconds, maybe up to a minute of total turbo runtime before it becomes too hot to hold even by the tail… if you don’t fear frying the LEDs or battery, that is.
Even 12 seconds are more then enough I’d say, for the intended use of this light… this is essentially a quasi-EDC, it is smaller and lighter than the NSX3, it has a clip… it’s a light to carry around and use at a “low” level it can hold indefinitely, and if you need a few seconds at 10000 lumens well, you can have it.
The main drawback of this light would be the ugly tint and horrendous tint shift.
Heat dissipation is a bit overrated with this class of flashlights I think. Even the NSX3 won’t hold the 10000 lumens for more than… 30 seconds maybe? It’s still not enough to be an appreciable advantage over the FW21Pro in real world usage: what can be a real world situation where you need 10000 lumens for more than 15 seconds but 30 seconds is enough?
anybody know what is the amp draw this two light?
The 53A goes just over 30s on turbo before stepping down using a new 30T. You can re enable turbo repeatedly afterwards but it always steps down. 3 xhp50.2s is simply too hot for most lights outside of a gigathrower form factor.
I’ve been tempted by the 21PRO but am weary about quality control from what I’ve read about the FW3A series and also my HL03’s flaw. Anduril is really tempting though but I think I’ll hold off.
I just ordered this light (FW21 Pro)! I’m interested in your guys feedback as this will be my first 21700 light. (been using 18650 lights for years, started with a SSC P7)
Welcome to BLF!
We want to hear your feedback, too!
Is the 15% discount code good for the new NXS3 (near) 10k version?
Got the FW21 Pro with the offered Samsung cell.
Works well and the build seems solid.
The light could use a better tint.
The clips hoop slightly protrudes, and is a tad bit larger than the tail caps diameter.
It gets hot. Use 100% sparingly. I'll get some beam shots this week.
yeah the light does like the 10k lumens for like a second then drops faster in the blink of an eye the lumens… having the xhp50 in 5000k tint or so would be nice or even warmer.
Thank you so much for taking the time to do this comparison, it was really helpful. It showed that the lights were essentially identical in initial output and the decision comes down more to UI or preferred host. I ended up going with the Nightwatch NSX3 due to the decent body’s design for heat dispersion. You are much appreciated good sir.8
Just got my FW21 Pro in the mail today. The dang thing gets super hot. For longevity, I calibrated the sensor and set the limit to 40C which is pretty close to getting too hot to hold for me.
It smokes a black paper plate in 2 secs lol. I wonder if it can catch it on fire!
In my VERY unscientific ceiling bounce test and using a LUX meter app (phone placed on floor), it goes up to 1200 lux compared to my Convoy M3’s ~650 lux. Then it throttles to about 150 lux lol. (Please note that these are relative tests and the lux numbers are in no way comparable to other peoples results!)
This is with using a P42a Molicell 21700.
What a strange race we are facing in 2019/2020….the more lumens possible in a lowest possible time ?
It started with imalent flashlights 3 years ago…
i would like to see a small light that can sustain 3000lm for 10min.
Would be kind of hard in a small body.
You need mass for heat-sinking.
Now if I needed 10k lumens for work, I would be looking at 2x, 3x 4x 21700 Lights that are big and heavy.
I know I know…we are talking about 80 to 150w and even more than 200w for 10klumens ! Cpu cooler are much more bigger and feature fan designs…
I was talking with Dale from Haikelite about fan cooling for the big 3xxhp70.2 lights
But considering the current thread I would like to see the small light with exact time specs. For example a 3000lm light should sustain it for 5min mini. Like tig welder are rated with running coefficients…
The decent/honest manufacturers often list a estimated time until stepdown + output after stepdown on their FL1 runtime charts. Even the FL1 standard has it’s own issues though, like how Maglite games it to massively inflate their runtime numbers without making any mention of the huge stepdowns.
