Interested.
Jetbeam = Nitecore not long back, this would make a good D10/D11 replacement or even the new RRT01 Raptor Tactical especially.
Interested.
Interested.
Mode selection
Interested
Interested.
Interested.
Are the sections between “Low / Middle / High” infinitely variable (smooth ramping), or are they set indents (stepped output)?
If the latter, what occurs between the indents, ie. stays on existing output, moves to next output, or light is off/no output?
Many thanks for another cool Group Buy…,
Normal with all the Rotary Jetbeam lights I have seen when its listed like this it’s 3 modes L, M, H and it does nothing in between. By nothing, I mean It just stays in the existing mode until you turn it far enough to activate the next mode.
That would make a huge difference in the way this UI works, if its infinite brightness or not.
Freeme could you please verify the UI?
The JetBeam RRT-0, 01 and presumbaly 02 all had infinitely variable output with the magnetic ring. It’s why they are so highly coveted by many.
This light not having that in favor of discrete modes on the ring will be a hard pass for me.
interested
Any more?
Waiting for more details. Then maybe I’ll jump in!
Interested.
Interested.
Interested !
Freeme; As above, any details on the UI? Is it Variable dimming (like other RRT01 & SWM v11r) or Discrete steps (like TCR-10 & SWM M11R)?
Would like to know what happens between the labelled indents on the MCR...
Ta buddy, ARH
*EDIT: Corrected with info from moderator007 in below post. I mistakenly referenced the wrong SWM model for discrete steps/indents.
Also, the form is still returning error:
Form still not working for me either. My interest is also dependent on whether the rotary is infinitely variable.
[quote=ahirshy]
Freeme; As above, any details on the UI? Is it Variable dimming (like other RRT01 & SWM v11r) or Discreet steps (like SWM v10r)?
Would like to know what happens between the labelled indents on the MCR…
Ta buddy, ARH
The V10R was infinite variable brightness just like the V11R and RRT-01.
The Sunwayman M11R I have has 4 detents, one for each mode, off, low, med, and high with strobe (turn twice to high)
The Jetbeam TCR-10 I have has 5 detents, one for each mode, off, low, med, high, and 3 colored strobe depending on which color was used last. Which seems close to this one.
From the pics, this one appears to have modes and not the infinite variable brightness. Its not been comfirmed yet though.
An example of a rotary light with fixed modes instead of infinitely variable is the Sunwayman M11R.
Might be this Jetbeam is similar.
