hello, thank you for your support, you know we can do that, but is that necessary bucause if I replace micro usb with typc c, the cost will increase, and for function, no difference, usb-c cables has many functions like supporting PD charging and other things, using such a good port to achieve a single function is wasteful, we just use this port for pc software, so micro-usb is enough and cheap
Hello RDTECH.
Congratulations on the release a new version of the power supply.
I have a question.
You have many different power supplies, but you do not have a powerful electronic load. Do you plan to produce an electronic load similar to the design of the RD60 ?
USB C is the new standard for a couple of years, micro USB is obsolete by now.
Still, nice power supply, wish i had one, but i am frugal.
Thats why i’m on BLF
Do you do samples or discounts?
thank you so much for your suggestion, I will consider and tell our engineer
for discount , now it is very lower, because of first time publish , the price is very lower , it is less 10 usd than normal price
RD6012 will be more than 63 usd ,. now it is only 52 usd
if you like it , you can buy one to pay
thank you so much for your message , you are great , I like that
Does that include the RD6012 with case and psu?
Cant choose that combination on AE.
that price is only RD6012 price , for case and PSU , you need to make order seperately
where are you from ? it depends your country, I can decide to send them together even you make order together or not
works with a 24V source at 14 A?. thanks
¿funciona con una fuente 24V a 14 A?.gracias
hello, just make sure the input voltage is between 6-70V DC, the input current of RD6012 has no limit, but it is a buck power supply, if you use 24V input, you can only get 22V max output
RD tech, you’re violating the BLF Rule that states:
I count 25 of your threads already.
On a separate note, I recommend BLFers to not buy RD tech products.
The reason is that I did, once. Then they started spamming me on Aliexpress.
I asked them to stop, they apologized but spam kept coming from them.
I already reduced the post. I already know the rule… don’t need you to remind me
we have good quality products, they have their own chioce , why did they listen what you said ?
and for post on aliexpress, please tell me your order number , I will block all things for you
RD6012 review article in Russian
if you have time, you can have a look
https://mysku.ru/blog/aliexpress/80912.html
RD6012 link:www.aliexpress.com/item/4001053200176.html
